Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
05-17-2014, 06:26 PM | #43 |
Drives: '13 BRZ, '06 997, Other Things(TM)
Another update: I changed the oil a few weeks ago, sent a sample, and just got the UOA results back from Blackstone. Here they are:
No coolant! Wootles! |
05-17-2014, 07:22 PM | #44 |
Drives: Nevermorange FRS
Disappearing oil, if not leaking, might be from hard driving/corning and the PCV system.
This was absolutely the case with the s2000 engine. During cornering or sustained high rpms the oil splash pathway in the engine could be making its way into the PCV line and since the line is almost always under vacuum (or pressure from crankcase) any oil passing near the opening would get pulled in. Just spaghetti at the wall at this point.
SCCA T4 - FRS
05-18-2014, 10:14 AM | #45 | |
05-18-2014, 01:21 PM | #46 | |
There's the possibility that neither will reduce your oil loss problem because instead of being consumed by the engine the oil you lose will just sit in the catch tank instead.
SCCA T4 - FRS
The Following User Says Thank You to rice_classic For This Useful Post: | Ganthrithor (05-18-2014) |
05-18-2014, 08:42 PM | #47 | |
05-19-2014, 02:52 AM | #48 |
Drives: 2013 raven black fr-s
go with the catch can. This will trap some of that oil. I wouldn't recommend putting it back into the engine, but if it''s going into the intake, this will be an easy way to keep it clean
05-19-2014, 10:16 AM | #49 |
Drives: Black Panda BRZ
Is a catch can likely to cause any warranty issues though?
12-03-2014, 10:58 PM | #50 |
Just another update-- new UOA is in:
Pretty sure my car has no mechanical issues at this point. I've been doing a lot more commuting miles (~75mph on the freeway in 6th) lately and my oil consumption has been pretty negligible: haven't topped off at all since my last change (over a thousand miles ago) and the level is still ~2/3s of the way up the usable area on the dipstick. |
The Following 2 Users Say Thank You to Ganthrithor For This Useful Post: | jcw99 (12-07-2014), Ultramaroon (12-04-2014) |
03-15-2015, 09:30 AM | #51 |
Drives: An old Citroen Xantia TD
Have you got an oil cooler? Your oil reach high temperatures with wot. Use a sandwich plate oil cooler as on forester. There is the cusco oil cooler too !
http://www.ft86club.com/forums/showthread.php?t=33799 |
03-25-2015, 02:18 AM | #52 |
Drives: 2013 BRZ Limited
I was just thinking about this. My job has me working with large diesel engines, 1,000 hp and up. It is generally normal for the first bit of oil to be burned off after an oil change. As long as there are no leaks the oil generally stays at one level, if you add oil it will just burn it off. These are engines with 40+ gallons of oil. Each engine has its own happy spot for the oil level.
For those with problems I would as if they are constantly topping off their oil because its down by 1/4 of a quart.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears 1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust 1993 Honda CB750 Nighthawk |
03-25-2015, 11:40 AM | #53 | |
Sweeper
03-25-2015, 01:25 PM | #54 | |
Lubricate bearings, valve train, help create a seal and lubricate piston rings, aid in cooling. The biggest difference is really just oil weight.
The Following User Says Thank You to CoupedUpSubie For This Useful Post: | Koa (03-25-2015) |
03-25-2015, 02:05 PM | #55 | |
Sweeper
As far as oil differences go, I do know that typically additives too should be taken into consideration as diesels create significantly more soot/byproduct ay? Would these have any impact between differences in the two? you can tell I don't interact with many diesel mechanics baha. Sorry if the questions seem 'duh' or elementary, or able to be googled. I am in full lazy wednesday mode. |
03-25-2015, 02:29 PM | #56 | |
The big differences in diesels and petrol engines are combustion source, fuel injection, higher compression(14-22:1). You are correct on the oil additives. These are mostly to counteract any fuel dilution or soot that gets picked up in the oil. My theory on the oil consumption is basically just a theory. Some people seem to have actual issues that shouldn't happen. In a 6 quart engine I'd have no issues with a .5 quart drop after an oil change as long as it doesn't get lower.
Similar Threads | ||||
Oil Consumption? | smbstyle | Tracking / Autocross / HPDE / Drifting | 42 | 10-08-2019 04:50 PM |
Oil consumption? Please chime in | OnTheFence | Issues | Warranty | Recalls / TSB | 48 | 10-01-2019 08:42 PM |
86 / BRZ Oil Consumption | ZZT86 | AUSTRALIA | 1 | 04-29-2013 08:53 PM |
Tune before 1000mi break in? | Bg8780 | Engine, Exhaust, Transmission | 16 | 02-20-2013 03:11 PM |
Weight, fuel consumption and 0-100. | Loki556 | AUSTRALIA | 15 | 07-16-2012 09:06 PM |
