Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
08-08-2013, 11:21 PM | #1 |
Drives: 2013 BRZ Limited
Oil consumption? Please chime in
I'm hoping that this is an "engine is still new" thing because the lack of references to oil consumption in this section of the forum has me a little concerned (I found only this one). I just completed a ~300 mile trip, almost exclusively consisting of highway driving, and had to add 250ml (.25 quarts) of oil to bring the measurement back up to top dot. I checked my oil before departing, so I know it where it was before hand (top dot), and, additionally, the oil was changed 4 days ago.
Was: <-- top of dipstick ==0|===========0== bottom --> 300 miles later: <-- top of dipstick ==0====|=======0== bottom --> Details:
Last edited by OnTheFence; 08-08-2013 at 11:25 PM. Reason: added oil grade, 'cause maybe that makes sense in a thread on oil consumption |
08-09-2013, 01:07 AM | #2 | |
Proud of BOXER
Drives: Subaru Boxer
Mine consumed a good amount on the factory fill. I changed it at 4k with Eneos 0w-20 and my consumption seems to have gone down.
I attribute the consumption to my soft never go above 4k break in. Should've just had fun with it instead of babying it the first 1k.
08-09-2013, 09:27 AM | #3 |
Troll Level: Expert
Drives: '13 BRZ, '18 F150 3.5EB, '07 Cayman
I was told by the head mechanic at the dealer that you have to wait up to four hours for all the old in the engine to return to the pan. "Due to the complexity of this new engine"
Verbatim. Whether or not he's full of shit or not is yet to be determined. But this is the first of 4 Subaru's I've had that doesn't consume oil.
Nick K.
NASA ST5/TT5 #130 Southeast Region |
08-09-2013, 10:09 AM | #4 | |
08-09-2013, 02:18 PM | #5 |
Drives: WRB BRZ Sport Tech
Is your car MT or AT? Also, it may be worth while to try a more moderate style break in(or continuation of one) like described on this forum. This may help seat the rings a little more thus helping to increase cylinder pressure and reduce consumption. IMO the "by manual way" is way to conservative, but I understand why they did it( brakes, clutch, and assembly lubes need to be either bedded or burned off) before hard driving occurs.
08-09-2013, 02:59 PM | #6 |
Drives: SWP Subaru BRZ
I just completed a 560 mile trip and my oil levels are still normal and this is checking after letting the car sit for a day and half. I am on vacation not driving haha. But in all honesty still good levels of oil.
Edit, sitting at 6800 miles ish, first change at 1k, next at 4k, then one after I return home tomorrow 560 miles later.
2013 SWP BRZ full STi Lip kit installed. Tons of other mods from interior to exterior. One of the cleanest BRZ's around in the midwest! Enjoy the build thread below. Full of pictures, exhaust clips, garage shots, and walk around video encasing its beauty. |
08-09-2013, 03:25 PM | #7 |
The Answer
Drives: Mazda 2
This is my first car that doesn't burn / leak oil. over 12 000 KM on it.
I find this engine's dipstick quite shitty to read...make sure you read your oil with the car parked at the same place everytime. I also find it quite easier to remove the dip stick for about 10-15 min. so the oil drain down the tube and then check the oil. Much more accurate.
The Following User Says Thank You to Rayme For This Useful Post: | Marchy (08-09-2013) |
08-09-2013, 03:51 PM | #8 |
Drives: '89 911, '06 GTI, '13 BRZ
I'm at 11,500 miles now. Did first oil change at 5,000 miles. I know...but after 40 years of car ownership I finally got away from all the "got to change the oil after 1,000 miles" mantra.
Anyway at 5,000 miles oil level was right at the full mark. Did the second change at 10,000 miles (5,000 on the oil, 0W-20 Amsoil SS) and still at full mark. Running Eneos 0W-20 Sustina now. My break-in was simple, just stayed below 5,000 the first 500 miles but used the engine fully. Then stayed below 6,000 from 500-1000 miles. I run the car hard after its fully warmed up. Heck all my cars over the past 40 years have been great on oil consumption. Even my wife's 2002 PT Cruiser with 130,000 miles uses 1/3 quart in 10,000 miles (OCI on that car).
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe 2006 VW GTI/DSG 2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten 2014 Nissan Murano SV |
08-09-2013, 05:59 PM | #9 |
The Answer
Drives: Mazda 2
Yes this too. Read the side with the lowest mark.
08-09-2013, 06:58 PM | #10 |
08-09-2013, 07:16 PM | #11 | |
Thupercharged
After sitting overnight, I registered a good 8-9mm above the max fill line(where I filled to). Seems like the oil needs time to drain back after a shutoff. i waited about 5 minutes too when I checked after the oil change.... seems to take longer to get all the oil back into the pan.
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
08-09-2013, 09:48 PM | #12 |
I Love custom Turbo kits
Drives: Limited BRZ
This is what my Catch Can "catched" after 2.5K turbo miles
08-09-2013, 09:58 PM | #13 |
If you spend a lot of time idling/low rpm you're gonna burn a lot more oil through the PCV system. 0w-20 slings around pretty good at temp and gets sucked out when in constant vacuum.
08-09-2013, 10:00 PM | #14 |
Drives: Scion FR-S | 6MT | Ultramarine
I've autocrossed the car and change the oil about every 6k miles or so, and I get zero oil consumption. Way better than my stupid '08 Accord V6. That thing drinks oil.
Similar Threads | ||||
Oil Consumption? | smbstyle | Tracking / Autocross / HPDE / Drifting | 42 | 10-08-2019 04:50 PM |
Fuel consumption figures too | PuGZoR | AUSTRALIA | 25 | 02-16-2014 05:36 PM |
86 / BRZ Oil Consumption | ZZT86 | AUSTRALIA | 1 | 04-29-2013 08:53 PM |
Tyre Pressures/Fuel Consumption | Vic_RSA | AFRICA | 11 | 12-11-2012 01:20 PM |
Weight, fuel consumption and 0-100. | Loki556 | AUSTRALIA | 15 | 07-16-2012 09:06 PM |
