04-22-2016, 01:32 AM | #1135 |
Drives: 2015 CWP BRZ Limited
04-22-2016, 01:54 AM | #1136 |
Drives: Toyota 86 GTS
Easier to just learn to read from left to right.
The Following User Says Thank You to Wayno For This Useful Post: | jawn (04-22-2016) |
04-22-2016, 04:40 AM | #1137 |
Drives: Toyota GT86 6M/T
04-22-2016, 10:09 AM | #1138 |
Drives: 2014 BRZ sterling silver
Cool, they have helped me bunch too. listen to them they know what there talking about.
04-22-2016, 10:26 AM | #1139 |
04-22-2016, 07:11 PM | #1140 | |
Fuel system status tells you if your in open or closed loop fueling mode usefull for maf scaling, you can also generally pick open loop fueling mode as stft will go to zero their is some good suff on the romraider forums on subaru knock and i thunk i linked to it in the knock link below or the flashing reset learning l |
The Following User Says Thank You to steve99 For This Useful Post: | oldgunfan (04-22-2016) |
04-22-2016, 07:52 PM | #1141 |
If the fbkc is bad or often enough to drop iam, it will transfer to flkc.
As i said before, unless you have fuel dialed in already, have a flat kca map to reference and have lots of miles on the car followed by hundreds of miles of logs, all you will do by pulling timing for every minor knock event is detune your car.
04-22-2016, 08:40 PM | #1142 |
Best explaination of knock correction here although its pretty heavy reading, its for 16 bit ecu, but appears to apply to our 32 bit ecu code as well, the main difference is on 32 bit ecu iam is 0 to 1 and on 16 bit iam is 0 to 16.
http://www.romraider.com/forum/topic1840.html http://www.romraider.com/forum/topic5371.html the ecu operates in two different modes fine correction and coarse correction, the ecu switches between these modes , and can do so very quickly but never in both modes at same time Feedback correction FBKC only negitive not storred but used to drop iam Fine learning correction FLKC stored in feedback correction table can be +or-, can only be + if iam is less than 1 IAM coarse correction IAM is considered coarse correction but drops can be triggered by flkc or fbkc or likely a combination of both fed into some weird algorythm that takes into accout size duration and how often it occurs. IAM returning to one, also likely due to some weird calculation that takes into acount how knock free rpm\load area have been for a period of time. |
04-22-2016, 10:01 PM | #1143 | |
04-22-2016, 10:21 PM | #1144 |
Drives: 2014 BRZ Limited
Hey guys, been lurking for awhile learning as much as I can. New to OFT and just wanted to post my datalog to see if there's anything standing out I should look at. Let me know if I need to add any other variables and such. Thanks in advance
Here are 2 runs: http://www.datazap.me/u/gliderx/log-...1?log=0&data=1 http://www.datazap.me/u/gliderx/log-...1?log=1&data=1 |
04-23-2016, 12:11 AM | #1145 | |
04-23-2016, 01:35 PM | #1146 |
Drives: Subaru BRZ
Got the new OFH tune. Only mods are OFH, drop in filter, and catback. How does my log look? I tried doing a 3rd gear redline pull but I ran out of room on the road.
http://www.datazap.me/u/ernesteaux/l...5-6-7-11-12-13 |
04-23-2016, 02:59 PM | #1147 | |
The Following User Says Thank You to oldgunfan For This Useful Post: | eSOLOR (04-23-2016) |
04-23-2016, 04:26 PM | #1148 | |
Drives: '22 BRZ
The Following User Says Thank You to DocWalt For This Useful Post: | eSOLOR (04-23-2016) |
Similar Threads | ||||
RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 01:15 AM |
Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 12:55 PM |
VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 09:21 AM |
Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 04:57 PM |
ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 09:27 AM |
