Old 04-05-2024, 10:10 AM   #239
Racecomp Engineering
Originally Posted by RToyo86 View Post
Couldn't help my self and ordered. Is there any recommended hardware I should replace not included in the kit?
Originally Posted by autoracer86 View Post
Yeah I think so. I will probably snag some new bolts myself as most of my stuff is pretty crusty looking
I've made it a practice to order new bolts/nuts for pretty much every install to just make life easier especially with crusty subframe pieces. Sometimes I even remember to use them!
For the traction mod install, I do recommend supporting the subframe with a jack (or a big strong friend if you're on a lift) even doing it 1 side at a time. Just to be safe and it does make it slightly easier. Not a lot of extra effort to do it that way.
I do also recommend getting the STI pillowball trailing arm to go along with this mod if you can. Certainly not required but I think it really makes the most of the change.
- Andrew
The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post:
autoracer86 (04-05-2024), kevaughan (04-12-2024), RToyo86 (04-05-2024), Tokay444 (04-10-2024)
Old 04-05-2024, 10:20 AM   #240
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Originally Posted by Ohio Enthusiast View Post
Yep, that's what I was referring to.
Cool so what's the point of loosening the two smaller bolts that connect on the body side ? I would think removing the big bolt would be enough. That bracket doesn't need to move as the traction mod connects to it.
It's not a major deal but I know one of my smaller bolts is stripped so I am hoping to not touch it lol. Else I need to get a tap/die kit along with a new bolt lol
autoracer86 is offline   Reply With Quote
Old 04-05-2024, 10:55 AM   #241
Ohio Enthusiast
Drives: 2018 BRZ
Ah, now I see what you mean. Yeah, I don't see a need to loosen them. This installation video shows the two small bolts loosened, but when they actually install the MCA mod it doesn't seem to matter. The GP Sport mod replaces the OEM bracket so those smaller bolts have to be removed, but for the MCA mod looks like you could leave them. I'd start from just removing the subframe bolt and see if there are any issues with bolting on the MCA mod and only touch the smaller bolts if needed.
Timestamp at 3:25 (damn embedding not doing the timestamp right...).
Ohio Enthusiast is offline   Reply With Quote
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
Old 04-05-2024, 11:04 AM   #242
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
- Andrew
I couldn't find the STI pillowball trailing arms in stock anywhere when I did mine
Old 04-05-2024, 11:15 AM   #243
I remember loosening but not removing those 2 bolts as well, not sure why I needed to but I think I did have to for some reason.
Check japanparts.com
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
Old 04-05-2024, 11:44 AM   #244
autoracer86
Drives: Toyota GT86
Yeah I watched that along with another video someone posted where MCA did the install for him. At least I think it was MCA lol and both time it just seemed like they over complicated the install
I am pretty sure I can get away with it I did ask MCA for instructions to see if I am missing something
Old 04-05-2024, 11:50 AM   #245
autoracer86
Drives: Toyota GT86
- Andrew
Is this the part you're talking about ? Seems cheap!
https://www.rhdjapan.com/sti-trailin...-ball-zc6.html
Thanks for the heads up on the bolts!
Old 04-05-2024, 12:15 PM   #246
Yeah that's the one. It's just the OEM arm with a nice sealed pillowball on the one end.
- Andrew
Old 04-05-2024, 12:40 PM   #247
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
- Andrew
Edit...
Part ordered, I'm doing SPC toe arms at the same time, I may as well refresh everything while Im there
Old 04-05-2024, 01:11 PM   #248
TurboLag23
TurboLag23's Avatar
Drives: 2018 BRZ w/Performance Package
Originally Posted by M0nk3y View Post
I ordered last night, will be sure to take photos but like others said looks like they revised the bushing slightly
Are these STX-compatible, per the verbiage regarding suspension geometry changes? Curious for my own STX car.
TurboLag23 is offline   Reply With Quote
Old 04-05-2024, 01:18 PM   #249
autoracer86
Drives: Toyota GT86
I don't think they are
Old 04-05-2024, 01:24 PM   #250
M0nk3y
They aren't, my signature is old...this car is very much beyond STX legal at this point...
Kyle H. - #89 STX
The Following 2 Users Say Thank You to M0nk3y For This Useful Post:
strat61caster (04-05-2024), TurboLag23 (04-10-2024)
Old 04-05-2024, 09:04 PM   #251
norcalpb
norcalpb's Avatar
I think they loosen those two bolts so that if the subframe sags when you remove the big bolt it doesn’t bend the bracket or put a lot of stress on it.
Also having those two small bolts loose allows you to wiggle the bracket side to side to make sure the big bolt threads back in perfectly.
Since you have a small bolt that’s been stripped I would probably just leave it tight and make sure the subframe is strongly supported on that corner.
The Following 2 Users Say Thank You to norcalpb For This Useful Post:
autoracer86 (04-06-2024), Ohio Enthusiast (04-05-2024)
Old 04-06-2024, 01:15 AM   #252
autoracer86
Drives: Toyota GT86
Yeah that makes a lot of sense. I was planning to support the frame anyway and was kinda surprised they didn’t. Thanks !
Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? davidchoi Cosmetic Modification (Interior/Exterior/Lighting) 49 11-22-2014 10:17 PM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 02:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) -- General Topics 48 08-09-2013 06:34 PM
Factory suspension "sticktion" andrew20195 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-02-2013 02:49 PM
"Official" Suspension/Brake Thread NYC BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 06-27-2012 09:14 PM
