follow ft86club on our blog, twitter or facebook
FT86CLUB.COM
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Suspension | Chassis | Brakes
Suspension | Chassis | Brakes Relating to suspension, chassis, and brakes.
Old 05-28-2012, 09:02 AM   #1
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
"Official" Suspension/Brake Thread
So I have seen a ton of different info on the stock suspension/brake setup on the twins. I want to create a 1 stop shop for info on the stock BRZ/FRS suspension/brake setup. Also any companies that are working on upgrades please chime in! Hopefully if the mods feel its worthy it can become a sticky.
What I'd like to see:
Stock shock manufacturer
Stock spring manufacturer
Stock spring rates BRZ
Stock spring rates FR-S
Stock brake caliper manufacturer
Stock pad manufacturer
I'll start: Can anyone 100% confirm or deny that the stock calipers/rotors/pads are 2011+ WRX or something different? A lot of magazines seem to think so. If I can order high bite WRX pads day 1 and they'll fit then it makes my life and everyone else who wants to upgrades life easier lol.
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 RTR~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 05-28-2012, 09:57 AM   #2
EmilGH
FIA Licensed Rally Driver
EmilGH's Avatar
Drives: Lots...
Send a message via ICQ to EmilGH Send a message via AIM to EmilGH Send a message via MSN to EmilGH Send a message via Yahoo to EmilGH Send a message via Skype™ to EmilGH
Great idea for a thread… Wish I had something to contribute. Brake upgrade will certainly be early in my modding.
EmilGH is offline   Reply With Quote
Old 05-28-2012, 10:27 PM   #3
Racecomp Engineering
and GTWORX
Drives: 2013 BRZ, 2012 Paris Di2 & 2011 WRX
Since we were lucky enough to have a preproduction car for a little we figured a few things out:
Stock shock manufacturer - Showa non inverted twin tube
Stock spring rates BRZ - 185 lbs/in front and rear
Motion ratio in the rear around 0.75
19mm front sway bar
14mm rear sway bar
Fronts are 2011 WRX pads and rotors. Rears need confirmation (I think Legacy GT though).
6 inches total suspension stroke front (bump + droop).
About 2.5 inch bump travel and 3.5 droop, but that bump travel includes the bumpstop.
shock dyno for BRZ
I have more info coming soon and more things to work on with the car but we are incredibly busy this week and I'm at home now. Will try to post some next weekend.
- Andrew
Be a fan on facebook for news, rants, ravings, videos, etc.
https://www.facebook.com/RacecompGTworx
410-846-5407
www.racecompengineering.com
The Following 12 Users Say Thank You to Racecomp Engineering For This Useful Post:
Bristecom (06-17-2012), civicdrivr (05-29-2012), coyote (05-28-2012), Dimman (05-28-2012), Fly Guy (05-28-2012), Lonewolf (05-28-2012), NYC BRZ (05-29-2012), Primo86 (05-30-2012), Ryephile (05-29-2012), Slartibartfast (06-09-2012), SonnyBRZ (05-29-2012), Symbiont (05-30-2012)
Old 05-28-2012, 10:43 PM   #4
and GTWORX
added rear motion ratio.
410-846-5407
Old 05-28-2012, 10:49 PM   #5
Lonewolf
Resident Nice Guy
Lonewolf's Avatar
Drives: Moped
Thanks for the helpful information Racecomp. Do you guys need a donor vehicle for R&D?
***Can anyone confirm if the rears pads are from the Legacy GT?
Old 05-28-2012, 10:50 PM   #6
coyote
coyote's Avatar
Drives: Slowly
Great news on the front and hopefully the rear too.
coyote is offline   Reply With Quote
Old 05-28-2012, 10:54 PM   #7
and GTWORX
Myles picked his up this weekend, and we've got a few local peeps who have offered to help if we need them.
We'll try and confirm rear pad fitment but someone will likely beat us to it!
- Andrew
410-846-5407
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
Old 05-29-2012, 08:38 AM   #8
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
19mm front sway bar
14mm rear sway bar
shock dyno for BRZ
- Andrew
Top shelf information, thanks a bunch for sharing!
More total stroke than I was expecting, and that's a good thing.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
The Following User Says Thank You to Ryephile For This Useful Post:
blu_ (06-04-2012)
Old 05-30-2012, 05:38 AM   #9
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
I'm most excited about the fact that they're 2011+ WRX pads and rotors. I've been in touch with the boys at Carbotech. Now I need to get a set of AX6 pads. Thanks RCE!
Old 05-30-2012, 05:53 PM   #10
Primo86
Primo86's Avatar
Drives: '05 Toyota Celica (Sold) Scion FR-S
Showa has some good engineering, and their products seem to be of good quality. Just from their website I have one or two questions regarding the suspension set up:
1. For clarity, since the suspensions are "tuned" differently on the BRZ/FR-S, do they use the same shocks/ struts but with different spring rates?
2. If they do, then Shows produces both cars' shocks/struts. Earlier Racecomp Engineering said,
19mm front sway bar
14mm rear sway bar
under Double Wishbone The "conventional" model is listed as a double-tube non-inverted. Is this the shock on the twins?
Conventional
Double-tubed construction filled wish low pressure nitrogen gas. This type of shock absorber is supple and provides stable riding comfort.
Under "struts," the same option looks to be the correct counter-part.
Conventional
Double-tubed shock absorber with a function as part of the surpport structure of the suspension. Like the double wishbone type, it is a shock absorber filled with low-pressure nitrogen gas that is supple and provides stable riding comfort.
My question is, are these the shocks/struts on the FR-S/BRZ? If not, what are on the FR-S?
3. Do they share the same brand of springs? even though the rates are different? If not, what brand spring is the FR-S, and what brand is the BRZ?
thank you!
'05 Toyota Celica (sold)
Scion FR-S ((arriving shortly!! June 1st - 12th.))
Asphalt Grey, Manual Trans., Upgraded Audio, and TRD air filter.
Primo86 is offline   Reply With Quote
Old 05-30-2012, 05:54 PM   #11
Primo86
Primo86's Avatar
^ Those are actual pictures of the Shows shocks/struts from their website...
Old 06-01-2012, 07:03 PM   #12
Dimman
Kuruma Otaku
Dimman's Avatar
Drives: BD Legacy and Mk3 Supra Turbo
Does TEIN use stock spring rates for their H-Tech line?
The FR-S H-Tech springs are listed as 3.0kg/mm (167 lbs/in) Front and 4.6kg/mm (257 lbs/in) Rear.
This would fit in with what we've been hearing about the different suspension settings, as well as identify why the FR-S is said to be a bit more tail-happy.
Because titanium.
Old 06-01-2012, 08:54 PM   #13
dsgerbc
Drives: WRB BRZ, STI on order
They are not from LGT.
I have 08 spec.b, rear brake are the same for all 05-09 LGTs.
Here's a pic of some rear EBC Yellowstaff I had on my legacy at some point and stock rear BRZ pad.
Pad size is a bit different, and the 'ears' on LGT pad are thicker, so it does not fit into BRZ bracket even with clips removed.
dsgerbc is online now   Reply With Quote
The Following 2 Users Say Thank You to dsgerbc For This Useful Post:
Fly Guy (06-01-2012), Lonewolf (06-01-2012)
Old 06-01-2012, 09:11 PM   #14
Lonewolf
Resident Nice Guy
Lonewolf's Avatar
Drives: Moped
I appreciate the time you took to post this...
Old 06-01-2012, 09:43 PM   #15
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Looks like a '10+ LGT rear pad.
old greg is offline   Reply With Quote
The Following 4 Users Say Thank You to old greg For This Useful Post:
blu_ (06-04-2012), Fly Guy (06-01-2012), Lonewolf (06-02-2012), Racecomp Engineering (06-04-2012)
Old 06-01-2012, 09:50 PM   #16
dsgerbc
Ah, there's THAT LGT too
I keep forgetting it exists...
Looks pretty similar to BRZ though.
Old 06-02-2012, 02:14 AM   #17
danscar
danscar's Avatar
Drives: Jeepney
Here's a write up about the FRS/86 from Import Tuner.
Go to the 'Big Brake Kit' portion regarding similarities between WRX's and FRS/86's brakes.
http://www.importtuner.com/features/...05-30-08-46-00
danscar is offline   Reply With Quote
Old 06-02-2012, 02:24 AM   #18
OrbitalEllipses
I'm different, yeah I'm..
OrbitalEllipses's Avatar
Drives: Attitude
STI Brembo brake upgrades have been mentioned a billion times; while Import Tuner is correct in that they are direct BOLT on, they are not properly functional.
Dimman (06-02-2012)
Old 06-04-2012, 02:19 PM   #19
DarrenDriven
Evil Asphalt
DarrenDriven's Avatar
Drives: 2013 FR-S Asphalt
Topic is a good idea, but someone has already put together a pretty comprehensive spreadsheet:
http://www.ft86club.com/forums/showthread.php?t=5511
Old 06-04-2012, 02:32 PM   #20
and GTWORX
That's just a parts list though, doesn't really have any data. Gonna try and keep up with posting gory tech details in here.
- Andrew
410-846-5407
Old 06-04-2012, 04:11 PM   #21
Dimman
Kuruma Otaku
Dimman's Avatar
- Andrew
Have you guys tested any FR-S springs/shocks yet? I'm curious if they are 160/260 lbs like the Tein H Techs...
Because titanium.
Old 06-04-2012, 04:17 PM   #22
and GTWORX
Not yet. I was under the impression the rears are identical to BRZ with softer fronts.
160/185 wouldn't surprise me, but 260 lbs/in in the rear would be a big time surprise IMO. We'll get on it soon.
- Andrew
410-846-5407
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
Dimman (06-04-2012), Fly Guy (06-04-2012)
Search this Thread:
Advanced Search
Limited gets brake "upgrade" over Premium - Canada only? Sport-Tech Subaru BRZ General Forum 25 05-14-2012 11:35 PM
The Official "E-Peen" (BRAG) Thread S2kphile Off-Topic Lounge 46 03-31-2012 08:49 PM
New Official WRB Subaru BRZ Video from Geneva "Lift" gt86mods Photos, Videos, Wallpapers, Gallery Forum 13 03-06-2012 09:25 PM
The *Official* "I'm Back!" thread BoostJunkie Off-Topic Lounge 34 02-02-2012 06:21 AM
The "if you wanna kiss the backside of white musicians make a thread about it" Thread aliphian Off-Topic Lounge 8 12-19-2011 06:59 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
