10-05-2019, 03:11 AM | #197 |
Dismember
Drives: 2013 Red Scion FR-S
OK, I want an EV drivetrain.
The Following User Says Thank You to EAGLE5 For This Useful Post: | Dadhawk (10-05-2019) |
10-05-2019, 04:12 AM | #198 | |
I might not agree with other peoples opinions all the time, but I like hearing them. I'm always up for new ideas and information. As for the Mustang, I find them to drive like a V8 Commadore or a RWD Skyline, fun to cruise around in, fun boosting on a straight line, fun at the track, but to fat to be fun and flickable on tight tracks or the street.
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
10-05-2019, 08:01 AM | #199 | |
Weight Weenie
Drives: 15 FR-S
The Mustang GT is an understeering pig on track. It would take some $ to change that. I would take the 86 in a heartbeat! They would make a nice street car though. |
The Following User Says Thank You to new2subaru For This Useful Post: | 86MLR (10-05-2019) |
10-05-2019, 10:23 AM | #200 |
ProCrastinationConsultant
turbo isn't the answer.
ITB IS!
The Following User Says Thank You to soundman98 For This Useful Post: | Clutch Dog (10-05-2019) |
10-05-2019, 10:34 AM | #201 |
Drives: Subaru BRZ
I hope the gestation period is short... I can't wait 7years...
10-05-2019, 12:23 PM | #202 |
1st86 Driver!
I'm slowly coming around to this. In my case, as an 86 replacement (which is primarily my daily driver) I wouldn't have an issue with it, but I would never road trip it outside of the round trip range. I still prefer hydrogen fuel cells for road trips (assuming insfrastructure, etc, but I have to make that assumption for EV as well). You just can't beat ICE for road trips, and I don't think you will be able to for at least 10 years.
I just can't bring myself to buy a car that doesn't have the infrastructure support I need, and electric still doesn't have that. Also, I'm not going to compromise and accept hour long stops on road trips. When driving solo, I don't stop for more than 10 minutes at a time, including meals. If they can get 80% charge down to 15 minutes, and I don't have to plan my trip based on where charging stations are, then I'm all in.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
10-05-2019, 12:26 PM | #203 | |
1st86 Driver!
The Following User Says Thank You to Dadhawk For This Useful Post: | Irace86.2.0 (10-05-2019) |
10-05-2019, 01:00 PM | #204 | ||
Drives: Q5 + BRZ + M796
If they replaced the current motor with an off-the-shelf, low-compression, lower-displacement, turbocharged motor then they could do it for a similar price just like others have done, as I mentioned before. The one off FA20 has a D4S system on a high revving and high compression motor that was expensive to engineer. They could use an existing, high-production motor to reduce costs like others have done with an output of 220hp and 200tq. Unfortunately, Subaru doesn't have a 1.5T. They had the EL 1.5 back in the day, but who knows what they could be developing for an electric/hybrid architecture with Toyota.
10-05-2019, 01:02 PM | #205 |
Is it too much to ask for both?
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | soundman98 (10-05-2019) |
10-05-2019, 01:15 PM | #206 |
Wayward Member
Drives: Hot Lava 86
Man, if they made a fastback version and stuck ITBs on the engine I wouldn't be able to pull out the cash fast enough. I'll never be able to explain the obsessions but I absolutely love both and deeply want them.
The Following 2 Users Say Thank You to Nevermore For This Useful Post: | Dadhawk (10-05-2019), soundman98 (10-05-2019) |
10-05-2019, 03:12 PM | #207 | |
pessimistic skeptic
What is the problem with this beautiful profile? |
The Following User Says Thank You to mrg666 For This Useful Post: | humfrz (10-05-2019) |
10-05-2019, 03:47 PM | #208 |
Drives: Halo 86, '19
I'd like to see what a two seater chassis of this car would look and drive like instead of a 2+2.
It'd be lighter, more compact, which means it could be snappier and on the power quicker to make up for its low power to weight ratio without altering the engine itself. You'd still have good seating space and trunk space, but no idea on how it would handle if it had a much shorter wheelbase. I feel like the FA20's already pushing its limits stock and I don't see much room available for the designers to get more power/refine it further than it already has. Maybe it's time for a different one, but I'm not a fan of the boxer engine as a concept. An I4 to my knowledge can accomplish all the same things while being lighter. The car, while well balanced for the boxer, already has a heaver front bias and is probably one of the heaviest components of the vehicle. Considering engine swaps rarely upset the car's design and balance I see changing out the boxer as only a boon. But being a subaru toyota collab I don't see the boxer getting changed out. If the AT unit isn't changed out, at least a shorter final drive would be hugely beneficial. As for the MT, it could at least do with a taller 6th and slightly more spacing from 3-4-5. Wishful thinking: adaptive dampers/suspension. One year as an owner and the thing that annoys me the most is needing to avoid lanes and even small roads in a commute. If you hit a bad bump it feels like an alignment appointment in the making. |
The Following 2 Users Say Thank You to OwlDance For This Useful Post: | Irace86.2.0 (10-05-2019), winstonscifi (10-08-2019) |
10-05-2019, 04:08 PM | #209 |
I mentioned the same thing here. A two seater could shorten the wheelbase, move the engine back, make the car 50/50, reduce weight, etc. They should do it.
https://www.ft86club.com/forums/show...&postcount=167
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | winstonscifi (10-08-2019) |
10-05-2019, 04:58 PM | #210 | |
pessimistic skeptic
I will post here as well, then. I need the rear seats to take my kids to school and still get those "idiot of this school!" looks from the minivan and SUV drivers. |
The Following User Says Thank You to mrg666 For This Useful Post: | Yoshoobaroo (10-05-2019) |
Similar Threads | ||||
BRZ/FR-S Second Generation? | JGalp | BRZ First-Gen (2012+) -- General Topics | 17 | 02-06-2015 01:32 PM |
Do you think there will be a second generation FRS? | NikostC | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 05-25-2012 08:18 PM |
Next generation Wrx info | sparrowhawk | Other Vehicles & General Automotive Discussions | 10 | 03-25-2012 10:33 AM |
first generation model | Audi | BRZ First-Gen (2012+) -- General Topics | 7 | 01-06-2012 10:58 PM |
