#141 |
@Element Tuning the log that you posted with 'waves' - was the DI issue from failed seals or a different DI issue? Wondering what the latest on seals are as it's giving me some concern regarding tracking this summer.
#142 | |
Well that sucks, was there a part number or casting number change?
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
#143 |
Drives: 2013 Subaru BRZ
#144 | |
Drives: Hydra EMS Powered FRS Raven Black
Sorry I don't know as the tech had told my customer that this was the third different revision or part number that he had to install. |
#145 |
Drives: Attitude
If there's a superseded P/N any number of Subaru (or Toyota) techs we have kicking around on the forum would be able to provide that knowledge. So let's get a few into this thread?
#146 | |
![]() What is unique to this over the EJ is the ability to "lock" the cam in place and as we've seen with tuning you have both advance and retard of the cam unlike the EJ which can only advance from the centerline. Hope that helps. Thanks, Phil Grabow |
#147 | |||
From my earlier post: Quote:
#148 |
You do see the FRS document picture I've attached with the "Advance Hydraulic Chamber" and the "Retard Hydraulic Chamber" right? I've attached another image showing the structure of the hydraulic chambers.
![]() I'm not making this up and I happen to have both the intake and exhaust cams and actuators sitting on my desk ![]() Those are the facts, let's move on |
#149 | |
For those of us out in he skicks I don't think the localish Scion dealership will have a cue, just insist on new heads if something is wrong?
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib Last edited by regal; 03-08-2014 at 04:53 AM. |
#150 |
Drives: car
I know the AVCS is not totally on topic, but just for clarification before we move on:
These systems are called "cam torque" activated, but they still use oil as a control mechanism (see attached paper). As the cam hits the bucket (in Ford's implementation) or the roller finger follower (Subaru), the force makes the oil slosh inside the chambers. The spool valve is there to coordinate that sloshing in a controlled way. In a conventional AVCS system, the oil is basically forced by hydraulic pressure to phase the cam. The source of energy is ultimately the oil pump. With this system, the oil is a way of transferring the force of the cam by sloshing in the desired direction at the right time. The intermediate locking position, which I didn't realize the FA20 was using, is a cold start emissions countermeasure, especially for meeting 2013 model year MSAT regulations of HC/NMOG at 20F/-7C testing. Aisin also uses that type of technology for Nissan applications. By dialing in overlap during cranking you get reburn of HC emissions that normally would have been thrown out the exhaust and unconverted. The above image compares running no intake cam advace, versus hydraulically moving the cam at startup, versus having an intermediate lockpin with no delay. |
The Following 4 Users Say Thank You to arghx7 For This Useful Post: | andrew20195 (03-08-2014), DAEMANO (03-08-2014), Ralph Spoilsport (03-08-2014), SkullWorks (03-11-2014) |
#151 |
Drives: 2014 Whiteout TRD FR-S 6MT
So in plain english, have we come to a consensus if the OFT/Perrin noise is detrimental to the life of the engine?
I've read the entire thread but got lost pretty quickly in the technical language! |
The Following User Says Thank You to calmtigers For This Useful Post: | topazsparrow (04-07-2014) |
#152 |
Sarcastic SOB
Very unlikely detrimental. But some possibility it will reveal a weakness in the fuel systems ability to maintain constant pressure at throttle tip-in. Nothing to worry about.
#153 |
IMO, it sounds like the bad noise might be the sound of a DI pump wearing out, but is more likely to annoy you than actually accelerate pump failure.
#154 |
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Having logged a cumulative 65,000 test miles on Perrin tunage I can only say that there is no likelihood of damage from the VVT or tune settings
SOLD THEM BOTH
Hers: 2007 987S Mine: 2012 991S That was fun, thanks Hachi ![]() |
The Following 4 Users Say Thank You to kiichiro For This Useful Post: |
Variable Valve "Butterfly" Exhaust | dlux | Southern California | 19 | 02-22-2016 06:21 PM |
First tank OFT E85 tuning. Noise? | Tromatic | Software Tuning | 2 | 02-20-2014 05:43 PM |
Exhaust Cut Off Valve | beagoodruslan | Engine, Exhaust, Transmission | 2 | 01-01-2014 01:47 AM |
Exhaust Noise that goes away after warmed up | FastLane1000 | Engine, Exhaust, Transmission | 10 | 08-15-2013 10:06 PM |
Knock/valve slap/crick noise under accel | yomny | Issues | Warranty | Recalls / TSB | 47 | 01-07-2013 08:53 PM |
