03-18-2013, 04:59 PM | #281 | |
i'm sorry, what?
Drives: Canada
its a democratic process and you lobby your interests through SCCA representatives to bring it up to discussion. thats why you're required to wear seatbelts and helmuts now.
03-18-2013, 05:13 PM | #282 |
AutoX-10/10ths every run
Agreed. But you can't make a part change for any given class unless the rules explicitly allow it, I think. There's an order of operations that applies here. Change the rules, then change the parts.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
03-18-2013, 05:28 PM | #283 | |
Drives: Whiteout FRS- autocross ready
03-18-2013, 07:32 PM | #284 |
People want to change the rules because right now and since the current rules were put in place people spend absurd amounts of money on "stock" cars. Even cars good out of box like the 86 or Miata people spend thousands on stock class prep. I think we are on the same page with that one.
The radiator and engine cooler is a bone for those running HPDE which is wildly poplar these days. Cars like the 86, WRX/STI, 350/370Z really benefit from an oil cooler for HPDE especially in warmer climates. Has nothing to do with autocross really other than it punting those people into a class like street modified. It's easy to write a rule saying the component has to weigh as much as stock or have the same volume as stock, it's done for a ton of other rules in solo. |
The Following User Says Thank You to xwd For This Useful Post: | 7thgear (03-18-2013) |
03-18-2013, 08:21 PM | #285 |
i'm sorry, what?
Drives: Canada
bang on!
03-18-2013, 09:22 PM | #286 | |
Drives: 2012 Miata
Shocks for example are almost impossible to legislate...look up the cost for a brand new strut for ANY car through your local dealer & compare that cost to a new Koni. Not only is the Koni MUCH cheaper than OEM, it's a performance benefit. Sure, the chances of needing a new shock on any car built in the past few years is slim, but I don't think anyone would argue that a new shock is going to work better than one with 50K+ miles on it...so what happens when the fast guys with unlimited budgets are putting new OEM shocks in their car every year? What if in some cars the difference between new shocks & 20K mile shocks is a half second? What I do think can be done is to revise the shock rule to at least minimize the theoretical advantage between the fastest shocks & OEM. IMO, the difference between an off-the-shelf Koni/Bilstien/Tokico & the best Moton/Penske/AST/Ohlins/Pimpy-aluminum-bodied-double-adjustable-custom-valved-remote-reservoir-$8K set of shocks is very little...guys like Sam have proven time and again simple set-ups can win. So my idea is to eliminate remote reservoirs & limit adjustments to only one...unless the car came OEM with those options, in which they would need to run OEM shocks in order to keep those functions. Sure, some will spend the money to custom valve their Konis, or even carry multiple sets for different conditions...but the performance delta between best & worst would be much less than it is now. Anyway, point is, gong to 100% OEM shocks could actually make stock more expensive, yet definitely less fun. The rest of the stock-legal mods are actually quite in-expensive, don't make the car un-drivable, & can easily be sold off for most of your investment. Tires on the other hand, that is a completely different story....
Mark Scroggs
Edge Motorworks 2013 Subaru BRZ STX #30/130 Special thanks to Edge & Perrin Performance https://www.facebook.com/EdgeMotorworks |
03-21-2013, 03:35 PM | #287 |
Drives: 2013 FR-S Asphalt Auto
The Following User Says Thank You to mo8ius For This Useful Post: | shaunsweeney (12-21-2013) |
04-11-2013, 09:11 AM | #288 |
I installed new shocks (MCS) a couple months ago and afterwards had the car aligned at a shop I trusted to do mechanical work, but this was the first time I had them do an alignment. I gave them specific alignment settings, but I didn't watch them do the work since I had to go to an appointment.
I did a quick check of the alignment the other night just to double check things before this weekend, using strings, but not to high precision. It seemed like the toe was off front and rear. So I went to a local tire shop known to do good alignments to your spec yesterday morning and verified it was indeed way off. Like 1/8" out front left and 1/8" in on the front right, but the overall front was around 0. Rear was a little over 1/8" out on the left and 0 on the right... I only did one event with the alignment that way. I was on A6s and it was 45 degrees and wet so I don't think any alignment would have made much difference, but I'm glad I got it checked before this weekend. I wish I had more room at my place to do the string method with more precision or else I'd just do it myself. Guess the moral of the story is always double check someone else's work. Camber was the same as it always has been, about -1.2 on both sides in the front with the bolts, -1.1 both sides in the rear. |
04-11-2013, 09:13 AM | #289 |
Drives: 2021 Supra / 2022 Tundra
Oh that alignment would make quite a difference. Just going from zero rear toe to 1/8" total in on my bone stock BRZ at the time made a very big difference in composure and throttle-on oversteer.
TomR
04-14-2013, 08:45 PM | #290 |
Drives: ND2, formerly BRZ (MT/CBS)
WDCR Event
Well, this wasn't a 'national' level event, just a big 'local', but I figured some folks might find it interesting.
We decided to take the BRZ on a bit of a road trip from western-ish PA to FedEx field to preview the site prior to the DC ProSolo and just to get some quality seat time in before the NJ Pro, which will be only our third weekend out this year. After watching SS run 2nd heat, I knew a decent time would be ~70 and fantastic (for me) would be ~68. I ended up running a 69.9xx, which was good enough for official P1 in RTR and 25/~190 on pax. Pretty boring story so far, right? Well, here's the good part: Sam Strano jumps in the car for a couple non-comp runs during 4th heat. Taking only 2 runs and not changing a thing on the car, he puts down a 67.856 and then a 67.708! His top time in the BRZ would have paxed the entire field including his own times in his own Grand Sport!! Here's how not to do it: [ame="https://www.youtube.com/watch?v=RiN3zL4SOFo"]WDCR_4-13-13_J_r4 - YouTube[/ame] Here's how to do it right: [ame="https://www.youtube.com/watch?v=muzykY7DXIo"]WDCR_4-13-13_S_r1 - YouTube[/ame] full results here: WDCR_Event#1 PS: The basic setup on the car is the Strano front bar, off the shelf Koni's (also from Sam), and last fall's 235 Z1's. PPS: I did a little better on Sunday |
04-14-2013, 10:35 PM | #291 |
Thanks to John for the runs in the car. Thanks x2 for believing in me to set it up.
DC is not a flat lot. This wasn't a short course, and had a few good uphill pulls (like the start). For comparison, here is my fast run in the Grand Sport (Jason Burns won the day with 2 different 64.2's. This is a coned 64.1... I stood on 64.4 on this day). Here's the run for direct comparison, and there is speed data on it. Other numbers you ought to know: Eric Kreimelmeyer in a Z0K Solstice indexed 3rd behind me. I set that car up, it was on Hoosiers. He is a very good driver. Coned a 66.0. Stood on a 66.4. Remember, I ran a 67.7 in John's car on Z1's on the same course, same day. I don't think this is an noncompetitive car in CS. Now onto today. I didn't drive a BRZ or an FR-S today, but I did drive another CS car. Course was faster (I can post video of it if you want to see from the Corvette). I paxed 1 today. Learic Cramer had me make some runs to help her make some changes to here 370Z. I ran 65.6 in her car, 62.4 in mine (she is in Hoosier's). For comparison, Eric K in the Solstice ran a 65.521. John, for comparison again, did have a MUCH better day today (I think I finally got him to believe that the tail needs to be a little alive....) ran a 67.816. That's only about 2 seconds off of two top flight cars on A6's, and that was on z1's. You can take this stuff for what it's worth. And I'm sure there will be nay-sayers... but it's hard to argue with the video and the results. I'm 100% thrilled with the sway bar I've built, and that's on both CS/RTR and STX cars (different tires too). I think Jadrice was pretty happy with the bar with race tires too. I have more being made now. Why pay more for heavier bars when you can see how well the cars work on mine? |
04-14-2013, 11:28 PM | #292 |
Drives: '22 WRB
Well Pallotta finished 3rd in pax and I finished 4th today at OVR PE1. I got 1st in RTR over a well set up, well-driven MX5 by over a half second. That's not comparing to competing against a national champ driver in an MSR or Z0K, but I'm not a national champ driver either.
Very interested to see how this works out. PS, Sam, I might bug you for advice for Holly's car this week if you're ok with that My run today: [ame="http://www.youtube.com/watch?v=GUdVV6JMpGg"]2013 OVR PE1 - YouTube[/ame] |
04-14-2013, 11:54 PM | #293 |
This weekend rocked for a whole lot of my customers/setups in all kinds of cars at a number of events.
FWIW, Holly's car and John's car are pretty much setup the same, but for tires (and both could have a little more done). I'll be around Dave. |
The Following User Says Thank You to Sam Strano For This Useful Post: | Areddi (04-15-2013) |
04-15-2013, 07:37 AM | #294 |
Drives: Yes
It was nice meeting you John. I was in the orange FR-S, and you spanked us all pretty good. I guess the next thing for me to do is call Sam for a set of Konis even though I've blown my (very limited) parts budget for the year. I've got no other excuses except that it's time I work a bit more on my driving.
Similar Threads | ||||
2012 BRZ/FR-S Stock Class Autocross Discussion | EMguy | Tracking / Autocross / HPDE / Drifting | 183 | 01-04-2013 03:17 AM |
What SCCA autocross class will the FRS be most competitive | SVThis | Tracking / Autocross / HPDE / Drifting | 5 | 07-30-2012 04:29 PM |
Share/discuss (this mornin) 86 Newsletter... | RebootWindows | AUSTRALIA | 6 | 07-19-2012 04:15 PM |
SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 10:03 AM |
Discuss.... | carbonBLUE | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 02-11-2012 12:55 PM |
