Member's Car Journals Car journals by our members. |
10-06-2023, 05:03 PM | #57 |
Drives: Toyota GT86
Haha yeah just testing everything before install. I was shocked the aim config was correct on my first attempt lol
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
The Following 2 Users Say Thank You to autoracer86 For This Useful Post: | DocWalt (10-06-2023), RedReplicant (10-08-2023) |
10-22-2023, 06:45 PM | #58 |
Drives: Toyota GT86
Oil pressure sensor is now installed and tested. Both on road and track unfortunately the track day I did this past Friday was very wet so getting the car past 230f wasn't happening.
From the data I did collect everything seems fine. Pressure is as you would expect with no dips due to load. I will be doing another track day on Nov 25 hopefully it's dry so I can get a better data set.
10-22-2023, 07:04 PM | #59 |
Drives: Toyota GT86
This past Friday was the first track day since installing the suspension upgrades. Was hopefully for a nice gain in lap time but instead was gifted a very wet track day
Wasn't easy for me to form any real opinion on the new setup beyond it's pretty oversteery. I felt like I was driving on a knife edge any more throttle and the car was going to spin. Most likely this was more me being nervous and the car probably would have just went into a very controllable "drift". I ended up disconnecting the rear sway bar which did seem to help in both feel and time. I took the car out for a bit of a blast around my local roads since it was the first nice day since the alignment and the ride comfort is just great. Handles the bumpy back roads without issue. Loads of grip yet still quiet and well mannered. I threw together a video covering all this ending with my best lap from Friday's track day.
The Following 2 Users Say Thank You to autoracer86 For This Useful Post: | DocWalt (10-23-2023), villainous_frx (10-22-2023) |
10-22-2023, 07:14 PM | #60 |
Drives: Toyota GT86
I had the car aligned and corner balanced at LOH motorsports. Was a string alignment so no printout.
My local Toyota dealer is going to toss it on their rack tomorrow because printout and trust issues lol Also waiting on pictures of the cars weight. Will share when I get them Alignment Specs Front Camber -3.8 Front toe 0 Rear camber -2.3 Rear Toe IN 0.10 per side Center of hub to fender Front ride height 355mm Rear ride height 352mm
The Following 3 Users Say Thank You to autoracer86 For This Useful Post: |
10-23-2023, 01:04 PM | #61 |
Drives: '22 BRZ
Interesting with the 12mm OEM bolts, I think that plus crash bolts would have gotten me the -4.9 degrees I wanted. Soft 200tw tires so obviously different there than yours.
Glad to hear things are working well! Curious how much droop/bump travel you have on the new long body shocks if you're able to measure sometime, I'll be sending mine in next winter for a refresh/service but wondering if it makes sense to just buy the new stuff... No complaints right now, but I haven't been on track with the car yet hammering curbs. Sad that it was so wet for the track day, car looked fun besides the "well it's really sketchy" haha I forget, do you have a stiffer front swaybar yet?
The Following 2 Users Say Thank You to DocWalt For This Useful Post: | autoracer86 (10-23-2023), RedReplicant (10-23-2023) |
10-23-2023, 03:09 PM | #62 | |
Drives: Toyota GT86
I can measure the droop next time I have the car in the air. My ride heights are pretty high which I assume affects the drop travel. But again happy to measure. My sway bars are stock all around. Didn't plan on changing them so fingers crossed this setup works well in the dry LOL
The Following User Says Thank You to autoracer86 For This Useful Post: | RedReplicant (10-23-2023) |
10-23-2023, 05:27 PM | #63 |
Drives: Toyota GT86
Oh and I almost forgot... Doing my best to copy @RedReplicant
haha
The Following 4 Users Say Thank You to autoracer86 For This Useful Post: | DocWalt (10-23-2023), NoHaveMSG (04-13-2024), RedReplicant (10-23-2023), villainous_frx (10-24-2023) |
10-23-2023, 05:58 PM | #64 |
Drives: None
I think Doc had some good notes on the Shaftworks knobs over here: https://www.ft86club.com/forums/show...1&postcount=68
The Following 2 Users Say Thank You to RedReplicant For This Useful Post: | autoracer86 (10-23-2023), DocWalt (10-23-2023) |
10-23-2023, 06:26 PM | #65 | |
Drives: Toyota GT86
The Following User Says Thank You to autoracer86 For This Useful Post: | DocWalt (10-23-2023) |
11-07-2023, 01:41 PM | #66 |
Drives: Toyota GT86
October 20th Track day
Track Temp 56.2F/13.4C(Wet) Max Speed: 79MPH/127KMH Down from 93MPH/149KMH Max RPM: 7107 Down from 7459 Max Brake Pressure: 739PSI Down from 852PSI Max Oil Temp: 237.2F/114C Max Coolant Temp: 194F/90C Oil Pressure: 34.9PSI - 60.2PSI AVG 52.0
The Following 5 Users Say Thank You to autoracer86 For This Useful Post: | alex87f (11-07-2023), DocWalt (11-07-2023), RedReplicant (11-07-2023), RToyo86 (11-07-2023), villainous_frx (11-07-2023) |
03-18-2024, 10:07 AM | #67 |
Drives: Toyota GT86
Just a small update... Over the weekend I changed the Oil, Brake fluid, Trans and Diff fluid To prepare for my upcoming track events. So far I have 3 events booked and paid for.
April 10th local track day at Mondello Then a double header Oulton Park/Donington in August. Hopefully I get good weather as I still have yet to drive on track in the dry with the new suspension setup! For those who care...
Same as I used last year. I am not sure I can easily get the Mobil one anymore so might switch it up when I run out.
04-13-2024, 07:12 AM | #68 |
Drives: Toyota GT86
First track day of 2024. The lap wasn't the best under drove a bit and left around a second on the table after reviewing the data maybe closer to two with a better driver. I just lacked confidence not sure if that was due to the track itself or the tires either way lessons were learned and I have a few ideas for next time assuming I get nice weather
April 10th Track day Track Temp 61.0F/16.1C(Raining in the morning) Max Speed: 93MPH/149KMH Max RPM: 7386 Down from 7459 Max Brake Pressure: 833PSI Down from 852PSI Max Oil Temp: 248/120C Max Coolant Temp: 198F/92C Oil Pressure: 40.3PSI - 56PSI AVG 48
The Following 4 Users Say Thank You to autoracer86 For This Useful Post: | DocWalt (04-16-2024), NoHaveMSG (04-13-2024), RedReplicant (04-13-2024), villainous_frx (04-13-2024) |
04-16-2024, 11:16 AM | #69 |
Drives: '22 BRZ
Lap looks pretty solid, especially considering the damp morning and still puddly patches!
The Following User Says Thank You to DocWalt For This Useful Post: | autoracer86 (04-16-2024) |
04-16-2024, 11:44 AM | #70 | |
Drives: Toyota GT86
Even if the grip was the same I definitely didn't feel confident to push much harder then I did. I am planning to go again on May 6th and again on June 20th.... If things go to plan I will have the traction mod along with upgraded wheels and tires for the June event.
The Following User Says Thank You to autoracer86 For This Useful Post: | DocWalt (04-16-2024) |
Similar Threads | ||||
Scratchy Noise and Peddle vibration | Sovereign | Issues | Warranty | Recalls / TSB | 7 | 07-19-2022 05:36 PM |
Beginner STX Build Whiteout FRS Build Thread | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 21 | 03-31-2020 07:52 PM |
JC's hot lava/burnt orange 2014 GT86 build thread | GT86NZID | Member's Car Journals | 11 | 08-25-2016 10:41 PM |
Superpenguin's "Not Another Build Thread!" Build Thread | superpenguin | Member's Car Journals | 7 | 06-17-2015 04:00 PM |
Orange you glad you checked this thread?!? | BlaineWasHere | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 23 | 04-09-2013 05:02 PM |
