Tracking / Autocross / HPDE / Drifting What these cars were built for! |
07-09-2022, 11:07 AM | #57 |
Drives: '23 BRZ
Different drivers, even at the highest level of motorsports, can use the brakes very differently while turning same lap times in the same car. Always annoys me to hear it suggested that faster drivers are harder on brakes. Drivers can be slow and HARD on brakes, and fast drivers can be relatively easy on brakes. It's a very individual thing, surprisingly so. Combine that with the fact that some drivers prefer more aggressively "grabby" response while some prefer more linear response, and it turns out optimal brake pad choice is very much driver-specific, even for the same car and same lap times.
Hats off to @CSG Mike for encouraging me to try different pads a few years back from the Carbotech XP10s I'd been running for years and years! Tried Winmax W5 (good but noisy), Project Mu CR (not as much bite, particularly when cold), then finally CSG Spec C2 which I *love*, great bite, not too too noisy or dusty, IMO pretty "streetable" for between events, and last me a LONG time with the PP Brembos. |
07-09-2022, 02:56 PM | #58 | |
Drives: 2013 frs base
I'd like to see a lab test where pads are put on a test machine to determine who's observations are more correct. A lab test would minimize the variables and answer the question once and for all. It could also be a good teaching tool for endurance racers trying to maximize their brake life over the course of an event. |
07-11-2022, 03:32 PM | #59 | |
This data already exists; it's just not my data to share. Jerk is rate of change in acceleration. Snap tends to go beyond any reasonable application. |
The Following User Says Thank You to CSG Mike For This Useful Post: | blsfrs (07-11-2022) |
07-11-2022, 03:36 PM | #60 | |
"Your engine lasts longer because you're more experienced and are being easier on the engine". or "You need an engine oil cooler because you drive your car harder than me" |
The Following User Says Thank You to CSG Mike For This Useful Post: | ZDan (07-11-2022) |
07-11-2022, 08:14 PM | #61 |
"Snap tends to go beyond any reasonable application." So does crackle.
07-16-2022, 09:49 AM | #63 |
This would be cool but probably heavy.
The next generation of brakes: activated electromechanically instead of pneumatically The Boeing B787 Dreamliner is the first commercial passenger aircraft to use electrically activated brakes instead of hydraulically activated ones. A system used in military aircraft since 1998 moved into the first airliner in 2011. Depending on the aircraft model, the electromechanically activated brakes replace several kilometers of hydraulic lines with cables. As a result, hydraulic fluid is no longer used anywhere in the entire brake system. This is considerably easier to maintain and compatible with the environment. Possible leaks are completely eliminated. Last edited by blsfrs; 07-16-2022 at 10:18 AM. Reason: wording |
The Following User Says Thank You to blsfrs For This Useful Post: | Ultramaroon (07-16-2022) |
07-16-2022, 02:29 PM | #64 |
chicken tonight
Should read "Possible leaks are replaced by possible electrical failures."
07-18-2022, 04:15 PM | #65 | |
Drives: 2013 FR-S, 2017 BRZ
are you downshifting to second near redline for a slow turn and had on the gas to exit, or are you staying in 3rd and carrying more speed? are you jerking on and off the throttle and banging off the rev limiter before you shift? As you mentioned before, it's looking at the 2nd derivative (and sometimes the integral), not the first or just the max/min. |
07-18-2022, 04:29 PM | #66 | |
The Following User Says Thank You to CSG Mike For This Useful Post: | TommyW (07-18-2022) |
07-18-2022, 07:50 PM | #68 |
Drives: '13 Whiteout
I've been using PowerstopTrackday pads since I started doing track days. I went through a set my first 3 days I now get 7 or more. I attribute it to better braking and general driving technique and not using the nannies.
The Following User Says Thank You to TommyW For This Useful Post: | blsfrs (07-19-2022) |
07-18-2022, 08:31 PM | #69 |
The Following 4 Users Say Thank You to CSG Mike For This Useful Post: |
07-19-2022, 08:59 AM | #70 |
GIVE ME STICK OR GIVE ME DEATH! I don't care if it's slower. Driving a GTR is like a freaking video game- it's just not real. turn the wheel, mash the gas mid corner, noise happens, flip little paddle on the steering wheel, different noise happens, brain smashes into the seat, car stays on track. no. unpossible!
Similar Threads | ||||
PMU NS400 front pads, StopTech Street rear pads, Motul RBF600 fluid | Darth Vaden | Brakes, Suspension, Chassis | 1 | 06-17-2022 08:27 PM |
DIY - Changing Your Brake Pads (Race Pads upgrade) | PMok | DIY (Do-It-Yourself) Guides | 53 | 09-03-2021 05:17 PM |
Safe oil temps for daily driving and spirited driving off the track? | MilkyWitness | Engine, Exhaust, Transmission | 15 | 06-12-2019 08:21 AM |
Interior Red Stitched Knee Pads Door Pads 2016 brz limited Rear View Mirror | sokol | Interior Parts (Incl. Lighting) | 11 | 12-25-2018 09:37 PM |
First time driving manual, some questions after one month of driving | kyto31 | Engine, Exhaust, Transmission | 10 | 06-24-2018 10:57 AM |
