BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ |
03-08-2022, 01:14 PM | #29 |
Drives: '22 BRZ
The connector used on the body harness for the ASC:
https://www.te.com/usa-en/product-1318386-1.html Here's the list of wire-to-wire connectors that are compatible (note you'll need to buy the right pins) https://www.te.com/usa-en/product-CA...ible=1318386-1
The Following 2 Users Say Thank You to DocWalt For This Useful Post: | dragoontwo (03-08-2022), MacSpeed (03-08-2022) |
03-09-2022, 03:51 PM | #30 |
Drives: '22 BRZ
Constant B12 works, and the IGN wire is +12 when ignition is on (not in ACC, it seems)
The Following User Says Thank You to DocWalt For This Useful Post: | dragoontwo (03-10-2022) |
03-09-2022, 11:51 PM | #31 | |
Drives: 2022 GR86
LMAO
I'll also do my best to find out the IDs and encoding for other channels I'm interested in. |
The Following User Says Thank You to timurrrr For This Useful Post: | DocWalt (03-10-2022) |
03-15-2022, 09:03 PM | #32 |
Drives: '22 BRZ
Parts list for the ASC connector/patch harness:
Male connector (plugs into factory harness): - AMP/TE Connectivity Connector Housing P/N: 1376106-1 (Quantity 1) - AMP/TE Connectivity Pins P/N: 1376109-1 (Quantity 8) - I'd suggest ordering a couple of spares though in case you mess up crimping Female connector (same as factory harness if you're making a patch) - AMP/TE Connectivity Connector Housing P/N: 1318386-1 (Quantity 1) - AMP/TE Connectivity Pins P/N: 1123343-1 (Quantity 8) - I'd suggest ordering a couple of spares though in case you mess up crimping I used this wire: https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1 I used this RJ45 breakout (for RaceCapture Track Mk2, you'll use something else for other devices): https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Use something like this to crimp the connectors. It's fiddly and annoying but way cheaper than the "right" tool: https://www.amazon.com/Qibaok-Termin.../dp/B089LW7MWT If you're wiring to a breakout like I was, this will work to make the ferrules on the wires. Way nicer to insert than stranded wire twisted together or whatever: https://www.amazon.com/TICONN-Insula...dp/B09F94TPRV/ My patch harness (made a second for a friend that I owe a favor to): My RaceCapture "install" after I routed the RJ45 cable along the passenger side rocker under the carpet, down in front of the seat, and out the flap that exposes the chassis VIN. Data into SoloStorm! Matching temps on the dash for comparison:
The Following 10 Users Say Thank You to DocWalt For This Useful Post: | Aroundomaha (04-25-2022), bcj (03-16-2022), eyeballs (03-15-2022), Goingnowherefast (06-03-2022), jongers (09-01-2022), justinco (06-14-2022), MPot (03-16-2022), Re_Invention (03-16-2022), timurrrr (03-16-2022), whataboutbob (09-02-2022) |
03-16-2022, 03:33 AM | #33 |
Drives: 2022 GR86
Awesome, thank you so much @DocWalt!
Now if anyone can find an easier way, like that hidden connector behind the head unit that some of us used on the 1st gen... |
03-16-2022, 06:07 PM | #34 | |
Drives: '22 BRZ
It doesn't get much easier to access than the ASC connector. Taking the radio out on a Gen 2 is "tear the entire damn dash apart" soooo.....
06-03-2022, 01:16 AM | #35 |
Drives: 2022 GR86
Since I've figured out the most relevant parts of the CAN bus logging (not without @DocWalt's help!), I decided to document them on my various GitHubs.
Connections: https://github.com/timurrrr/ft86/blo...an_bus/gen2.md [will also have more data on various CAN IDs in the future] IDs and equations for the most useful data channels: https://github.com/timurrrr/RaceChro...b/ft86_gen2.md How to make a DIY CAN bus reader if you don't want to spend $$$ on an AIM: https://github.com/timurrrr/RaceChronoDiyBleDevice [The project is being actively updated with 2022 specific tweaks.] Demo:
Follow the build thread for my GR86!
06-03-2022, 10:04 AM | #36 |
Drives: '22 BRZ
Thanks for taking it and running! Glad to help get the ball rolling with some of my local friends helping out
If RaceCapture ever gets little-endian data working properly I can keep helping sniff data out!
09-01-2022, 03:10 PM | #37 | |
Drives: 2022 GR86 Premium Track bRed
Really appreciate the instructions here, and I look forward to making one of these for myself. I saw in the config you limited some channels to 25 Hz. Is there a risk of saturating the bluetooth connection? (also asked this on github) I think 100Hz swa, throttle pedal/valve, wheel speeds, brake pressure would be interesting to explore |
The Following User Says Thank You to andys_garage For This Useful Post: | timurrrr (09-02-2022) |
09-01-2022, 05:33 PM | #38 | |
Drives: '22 BRZ
RaceCapture guys got me a beta firmware with little-endian working properly, so I can get back to work on this after nationals
The Following 4 Users Say Thank You to DocWalt For This Useful Post: |
09-01-2022, 11:29 PM | #39 | |
Drives: MR2, Sliver BRZ
Always looking to tinker with something..
The Following User Says Thank You to geraldjust For This Useful Post: | timurrrr (09-02-2022) |
09-02-2022, 01:09 AM | #40 | |
Drives: 2022 GR86
The Following User Says Thank You to timurrrr For This Useful Post: | Blighty (09-02-2022) |
Similar Threads | ||||
Data Log | czellers | Software Tuning | 0 | 09-02-2021 01:11 PM |
Here's My Data Log(s) | czellers | Engine, Exhaust, Transmission | 5 | 04-02-2021 09:17 PM |
IAT OEM PID/CAN Data - RC MK2 | M0nk3y | Tracking / Autocross / HPDE / Drifting | 7 | 07-20-2020 01:47 AM |
Data log | snk828 | Software Tuning | 1 | 07-10-2020 03:36 PM |
OFT Data log.. Are these okay | HSayaovong | Software Tuning | 2 | 03-25-2014 06:56 PM |
