Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
06-01-2021, 04:15 PM | #1 |
Camber question
I adjusted the angles at a garage today, the front camber was adjusted to -2.4 degrees at both wheels with me sit at the driver's place.
This leads to -2.5 and -2.3 when nobody is in the car. Is this a correct procedure? It's the first time it's been adjusted like this... |
The Following User Says Thank You to gpvecchi For This Useful Post: | norcalpb (06-01-2021) |
06-04-2021, 10:25 PM | #2 |
Dismember
Drives: 2013 Red Scion FR-S
A local tire shop that outfits race cars across the world told me that they never have a person in the driver's seat when aligning. They don't get returns when the car is empty, but they do get complaints when somebody is in the seat during alignments.
The Following User Says Thank You to EAGLE5 For This Useful Post: | gpvecchi (06-05-2021) |
06-07-2021, 12:13 PM | #3 | |
Every alignment I've had in my car has been with me actually sitting in the seat. OP - the alignment changes without your weight in the car because camber changes through compression and rebound, and with you out of the car the ride height changes.
Light travels faster than sound, so people may appear to be bright until you hear them speak... flickr Last edited by wparsons; 06-07-2021 at 12:32 PM. |
The Following 2 Users Say Thank You to wparsons For This Useful Post: | Goingnowherefast (06-10-2021), gpvecchi (06-07-2021) |
06-07-2021, 02:17 PM | #4 | |
Dismember
The Following User Says Thank You to EAGLE5 For This Useful Post: | gpvecchi (06-15-2021) |
06-07-2021, 03:28 PM | #5 |
Drives: Crapcan
With 7kg springs my car was stiff enough my weight didn't really effect ride height. With 10kg springs, lol. Setting alignment static with no weight in the seat hasn't mattered to me.
06-07-2021, 03:29 PM | #6 |
Drives: '13 FRS - STX
Kraus?
OP is seeing what I'd expect, about a tenth of a degree difference, it's close enough that your driving conditions will make a bigger difference in terms of wear and life. If you're sweating a tenth of a degree of camber you should probably book the time to test back to back multiple alignments before you freak out, if you can't do that then it's really not serious enough to worry about it. |
06-15-2021, 01:33 PM | #7 |
Drives: 2017 BRZ PP, 2004 WRX
Mine was done with a person in the driver's seat. Something like 1.1* front driver's side and 1.2" passenger side, which went to 1.2* even with a person driving. SCCA DS class, so no adjustable camber beyond a OEM camber bolts available from Toyota/Subaru.
The Following User Says Thank You to cmiovino For This Useful Post: | gpvecchi (06-15-2021) |
Similar Threads | ||||
Question About Negative Camber: More Negative Camber == More Grip at Corner? | Figo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 38 | 03-10-2019 02:08 PM |
SPL Rear Camber Arm Question | cruizin01 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 07-26-2016 07:49 PM |
Camber Question | Ryeong86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 04-12-2013 12:05 PM |
Question about adjustable LCA's vs Camber Plates vs Camber Bolts | djdnz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 03-27-2013 11:38 PM |
Camber Question | subaruatheart | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 03-24-2013 01:49 PM |
