05-13-2019, 11:29 PM | #897 |
Feeling like thinking....
I just come in here to be surrounded by and interact with people who own and drive, or at least drove recently, an FRS/BRZ. I used to, but I believe it disappeared into a black hole at the dealership about two months ago. Thankfully, I still have the insurance bills to prove I still own one, although the memory is fading fast.... I think it was grey/silverish... "Asphalt," if I remember correctly.. but it's been a long time since I've seen it.
Drive like everyone's life around you depends on it...
The Following 3 Users Say Thank You to MuseChaser For This Useful Post: |
05-14-2019, 07:23 AM | #898 | |
Drives: 2019 Mazda Miata RF
I've had good luck bypassing the usual route, and emailing top executives at some companies, when I have had issues that customer service wasn't solving. |
05-14-2019, 07:31 AM | #899 | |
Drives: frs
05-14-2019, 09:46 AM | #900 |
Drives: 13' Lightning Red Brz
I agree, I just got mine back yesterday after not seeing it for over 3 months due to the recall. They ended up replacing, headgaskets, 4 rod bearings, 4 intakes and exhaust valves, 8 rocker arms, 8 rocker valves, entire camshaft assembly, oil pan, oil pickup, cam and knock sensors, 2 cylinder heads, and more i'm forgetting off the top of my head. I thought it would've been easier for them to replace the short block at this point.
05-14-2019, 10:00 AM | #901 | |
Drives: 2017 Subaru BRZ PP WRB
05-14-2019, 11:11 AM | #902 | |
What caused them to need to replace all that? Did you have a failure prior to going into the recall or did something come about after they did the original round of replacements? Also, did you have to cover any of the non-recall parts replacements out of pocket? Im wondering because my car is in right now to have the engine matched to the car prior to them doing the recall, but once they start the recall I know I have at least 1 failed rocker/spring and quite possibly a messed up valve. |
05-14-2019, 12:54 PM | #903 | |
05-14-2019, 12:54 PM | #904 |
Makes sense now, I am not completely intelligent when it comes to this. I'm just hoping that with the repairs done, there isn't any long term damage with the oil starvation.
05-14-2019, 01:07 PM | #905 | |
Drives: 2013 pearl white FR-S
The Following User Says Thank You to DarkSideFRS For This Useful Post: | shiumai (05-14-2019) |
05-14-2019, 01:21 PM | #906 | |
That is a very interesting thing to suggest that also gets replaced... and 1000 bucks? Oh boy... I am not feeling too optimistic about my repairs at this point. |
05-14-2019, 01:31 PM | #907 | |
05-14-2019, 01:35 PM | #908 |
His head gasket item is an isolated incident and should not be confused with the actual required repairs. He got took on the gaskets.
05-14-2019, 01:37 PM | #909 |
^ Not only the engine out but also the heads half-taken apart... Not sure if the camshaft assembly has to come out or be disassmebled to a certain degree for the recall (this would be the involved labor add for the dealership) but for the most part not only is the engine out, but the top end (... well side ends? lol) is already half apart too..
05-14-2019, 01:51 PM | #910 |
Definitely understood on his scenario. I was only referring to my situation not being optimistic as I am about 90% certain the one cylinder head will need to come off and a valve and maybe guide will need to be replaced (basically same work as redoing a head gasket) and if they are looking to have me pay anywhere near that to get a new valve in I'll probably crap a brick .
The Following User Says Thank You to aemravan For This Useful Post: | Tcoat (05-14-2019) |
Tags |
brz, failure, frs, i cant even, j02, recall, so much glue |
Similar Threads | ||||
Registry Thread: Failure After J02 Recall | DarkPira7e | Issues | Warranty | Recalls / TSB | 489 | 05-26-2023 02:46 PM |
Is the fad threads ruining our fad threads? | Andrew025 | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 10-04-2017 09:12 PM |
CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 05:18 PM |
BRZ or FRS (yes, another one of those threads) | lisaaaxo | FR-S / BRZ vs.... | 19 | 04-11-2015 02:44 PM |
Vs. threads.... | TwinscrollGT35R | FR-S / BRZ vs.... | 34 | 05-22-2012 08:21 PM |
