Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
11-12-2015, 11:53 PM | #1 |
installing sensor/adapter for oil temp and pressure - how?
i currently have a Perrin Oil Cooler kit and i want to install an oil temp and pressure gauge. if i understand correctly, you need to install a sandwich plate or sensor adapter so info can be read and sent to the gauges i have. how do i do that when i have the Perrin kit installed? do i remove the oil filter spacer?
i hope those with the Perrin kit can share what they did so they can monitor oil temp and pressure btw, i plan to get Defi gauges if this info will help in determining what to do thanks!
2013 Toyota 86
Sterling Silver Metallic IG: @pcuerpo.images |
11-13-2015, 10:50 AM | #2 |
Drives: 2014 Whiteout FRS
12-20-2016, 10:47 PM | #3 |
Drives: World Rally Blue BRZ
Apologies for thread revival.
I am also looking for a solution for the Perrin Oil Cooler setup as it does not come with sensor ports. Did anyone stack the TRD oil filter sandwich sensor plate with long term useage already? Am worried by stacking plates, it might be prone to leakages. |
01-06-2017, 03:53 PM | #4 |
Some say.....
Drives: 2007 Subaru Impreza 2.5i
@Brzerker instead of stacking, I replaced the Perrin sandwich plate with this TRD one.
http://www.ft86speedfactory.com/trd-...l#.WHADYuz4-Hs |
01-06-2017, 05:32 PM | #5 |
Drives: 2013 Subaru BRZ
I just recently installed an Oil Temp Gauge. I used an oil galley adapter plug. The oil galley plug is right by the throttle body on the block.
This is what i used. https://www.rallysportdirect.com/par...il-galley-plug |
The Following User Says Thank You to TheDetailer718 For This Useful Post: | 8R6 (01-06-2017) |
01-08-2017, 10:35 PM | #6 | |
01-10-2017, 05:34 AM | #8 |
So it's the same plate as the one on my Perrin oil cooler. Thanks
05-21-2017, 08:29 PM | #9 | |
Drives: FRS
05-22-2017, 08:22 AM | #10 | |
Some say.....
05-22-2017, 10:20 AM | #11 | |
Drives: 2016 Halo FRS
01-30-2018, 03:12 AM | #12 | |
02-02-2018, 03:35 PM | #13 |
Some say.....
02-04-2018, 08:52 PM | #14 |
Thank you!!
Similar Threads | ||||
pressure and temp oil in this car? | pepe | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 08-25-2015 05:02 PM |
Oil pressure and Oil Temp sensor - where did you mount them and how | philooo | Engine, Exhaust, Transmission | 11 | 05-29-2015 02:41 AM |
Installing oil pressure/temp probes | xwd | Engine, Exhaust, Transmission | 12 | 03-14-2015 12:07 AM |
Help Installing Oil Temp Gauge | k.houan | Engine, Exhaust, Transmission | 1 | 11-10-2014 11:57 PM |
Addition of a radiator hose sensor temp adapter & coolant bleeding | FutureFT86 | Engine, Exhaust, Transmission | 9 | 07-21-2014 11:50 PM |
