Old 11-29-2017, 10:58 AM   #43
gtpvette
Drives: 2015 FRS - FFR GTM
Nice work,,,,, thank you!
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
The Following User Says Thank You to gtpvette For This Useful Post:
ILLSMOQ (11-29-2017)
Old 11-29-2017, 02:24 PM   #44
ILLSMOQ
Drives: 2017 WR BLUE BRZ
Originally Posted by DustinS View Post
His Pinion Angle is at ~1.3 degrees. (More precisely 1.2 on diff and 1.3 on Trans)
He removed the heat shield, then used a large pipe in conjunction with heating the tank to push it in to clearance it for the exhaust.
@ILLSMOQ Hopefully you don't mind me answering those questions.
I zero’d the angle finder on the pinion
Then put it on the flat part at back of the transmission
It’s pretty much dead on parallel.
ILLSMOQ is offline   Reply With Quote
The Following User Says Thank You to ILLSMOQ For This Useful Post:
DustinS (11-29-2017)
Old 11-29-2017, 03:26 PM   #45
ILLSMOQ
Whoops missed the pic
Old 12-04-2017, 08:36 PM   #46
ILLSMOQ
Started working on the mufflers
Something like that
Fit good
I’ll work on the tips later. Gotta wait on the tips. Once the rest of the exhaust is done, and I see where the mufflers end up I can finish the tips. The whole thing can be moved forward or backwards like the stock muffler...hangs exactly the same.
The Following 2 Users Say Thank You to ILLSMOQ For This Useful Post:
DustinS (12-05-2017), tehShirt (12-05-2017)
Old 12-07-2017, 12:36 AM   #47
ILLSMOQ
Got the Sikky oil pan. Clearance is good but the oil cooler line adapter it comes with still leaves me in the same predicament...it hits the steering rack and would hit the sway bar.
I need something like this.
Here’s how it worked out
Hopefully this leaves me with enough clearance for the headers.
DustinS (12-11-2017), Zer0 (12-07-2017)
Old 12-07-2017, 03:57 AM   #48
Zer0
Drives: 2015 frs
Looks like a good fix. Thanks for posting solutions to issues you are running into.
Zer0 is offline   Reply With Quote
The Following User Says Thank You to Zer0 For This Useful Post:
ILLSMOQ (12-07-2017)
Old 12-07-2017, 11:51 AM   #49
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Great progress!!
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 12-09-2017, 08:52 PM   #50
cf6mech
Drives: FRS Silver LS1 swapped.
Originally Posted by gtpvette View Post
Awesome build.
Two questions if you don't mind. I'm obsessing about driveline angles on my build. In particular the engine/transmission angle. Now that your mounts are in,,, have you put an angle finder on your transmission to see the angle???
I'm planning true duals as well. Based on your pictures, after removing the shield from the gas tank,, the both sides are recessed from the factory allowing a pipe on each side????
Pictures please of this recess....it would be a problem solver.
cf6mech is offline   Reply With Quote
Old 12-09-2017, 09:03 PM   #51
cf6mech
Maybe i should read first....see how u did the tank��......890 B ?????? Hilarious worked with that stuff my whole career as a Aircraft Mechanic........Good stuff.
The Following User Says Thank You to cf6mech For This Useful Post:
ILLSMOQ (12-10-2017)
Old 12-10-2017, 01:10 AM   #52
ILLSMOQ
So I’ve read after hours of surfing the web...and yes, you would know hahaha! I only added it (alot of it) as a precaution. Tank didn't leak after I re-formed it...but if it decides to leak later, this stuff should keep it sealed I think.
86Tony (01-19-2018), cf6mech (12-11-2017)
Old 12-11-2017, 10:49 AM   #53
cf6mech
Jonesing about your work on corvette CAI set up.....was going to start ordering parts but decided to wait for your findings.....noticed also if you remove OEM hood latch and do some sheet metal trimming there is a lot of room above radiator....I have noticed an extreme loss of power in Texas heat with my set up.
Old 12-11-2017, 11:35 AM   #54
ILLSMOQ
Yes there is plenty of room.
Latch needs to go for sure and some of the sheet metal.
I’m finding my current problem is I have so many different projects going on with the car my efficiency in getting things done has gone down haha... I figured I need to stick to a category.
Right now I’m trying to focus on all my AN lines...oil cooler and fuel and coolant but @DustinS brought up AN heater lines the other day, so now I’m doing those and that led to steam port lines (want to do a 4 corner system) ...still need to figure out what I want to do on the AC lines.
But I’ll jump back in the intake today to work on the throttle body coupler.
I ended up with 8 different 45 degree couplers and settled on this one.
https://www.summitracing.com/parts/ppe-515404045
It was the most rigid of them all and had the most usable bend radius for my setup. I need to trim up the length.
Old 12-11-2017, 12:57 PM   #55
ILLSMOQ
Here’s where I’m at.
Front of the hood hits the rubber coupler and maybe the k&n ducting. Pretty sure the fast 102 intake and the 102mm throttle body aren’t helping matters.
k&n fits pretty good otherwise so far
Flipped the k&n over
Options are; cut the hood. Heat up the k&n and reform it a bit or both...to be continued lol....
Old 12-11-2017, 02:02 PM   #56
ILLSMOQ
So patience isn’t my thing lol
Cut the hood and trimmed the coupler
I’ll clean it up later. But yeah it fits.
The Following 4 Users Say Thank You to ILLSMOQ For This Useful Post:
Code Monkey (12-11-2017), DustinS (12-11-2017), NOHOME (12-11-2017), Zer0 (12-13-2017)
Pure Automotive's MoTeC Plug and Play V8 Swap Thread Pure Automotive Engine Swaps 51 11-25-2017 11:10 AM
Pure Automotive's 2017 Race and Show Schedule Pure Automotive Mid-Atlantic 4 01-21-2017 12:07 PM
Pure Automotive Performance's White Street Fighter- 2JZ Swap - Formerly the FRSS LS2! Pure Automotive Member's Car Journals 53 03-05-2015 06:11 PM
Pure automotive pre meet KslayFRZ Mid-Atlantic 0 07-19-2013 11:32 AM
Anybody want to help me pick up my car at Pure Automotive? TyperRspec789 Mid-Atlantic 4 01-31-2013 02:07 PM
