Engine Swaps Discussion of engine swaps. |
11-08-2017, 05:07 PM | #1 |
Drives: 2017 WR BLUE BRZ
2017 BRZ VORSHLAG/PURE AUTOMOTIVE LS SWAP
Finally! The swap begins. This is an LSX/T56 swap into a BRZ using Vorshlag Motorsports LS swap Hardware as well as Pure Automotives MOTEC plug and play LS swap computer and wire harness. @Pure Automotive @modernbeat @Fair!
Sold the motor so might as well start. Transmission crossmember mount was pretty tough to get out The shifter mount and drive shaft center bearing mount came out super easy. Used an air chisel. Cut them out with the chisel and then chiseled out the left over spot welds With the tunnel cleaned out, the front subframe is next Need to remove these engine mount pads from the subframe, grind the welds, smooth it out then bolt up the mounts Something like this Need to pull the center console and front seats to start drilling holes. Transmission mount goes here. Mount brackets are located in place with the single bolt from the bottom for the plastic under body covers...should make things easy...easier. Here is what’s going in. Texas Speed 418ci making somewhere between 600-700 hp. And Vorshlags specified version of the T56 magnum XL Car already has. A Fullblown Motorsports Ford 8.8 rear end Vorshlag also supplied the clutch hydraulics which look really nice, the slave cylinder even has a nice coupler to make removing the transmission easier. Adjustable Tilton clutch master cylinder Engine mount brackets bolted on |
The Following 16 Users Say Thank You to ILLSMOQ For This Useful Post: | 86 South Africa (11-28-2017), cf6mech (11-16-2017), CxG (05-15-2018), Draco_PR23 (02-23-2018), DustinS (11-09-2017), Guff (11-09-2017), Irace86.2.0 (11-11-2017), Lonewolf (11-11-2017), mkivsoopra (11-09-2017), mrg666 (11-15-2017), MyGT86Yas (11-21-2017), Sportsguy83 (11-08-2017), Teseo (11-09-2017), TofuJoe (11-08-2017), whataboutbob (11-16-2017), wooly35 (11-15-2017) |
11-08-2017, 05:09 PM | #2 |
I Love custom Turbo kits
Drives: Limited BRZ
Awesome!!!!
The Following User Says Thank You to Sportsguy83 For This Useful Post: | ILLSMOQ (11-09-2017) |
11-08-2017, 05:34 PM | #3 |
MOTEC plug and play |
11-08-2017, 06:42 PM | #4 |
Cutting off the factory engine mount pads to fit the Vorshlag mounts
Need to clean and Paint but should look something like this Last edited by ILLSMOQ; 11-08-2017 at 07:19 PM. Reason: Painted |
The Following 6 Users Say Thank You to ILLSMOQ For This Useful Post: | cf6mech (11-16-2017), CxG (05-15-2018), Draco_PR23 (02-23-2018), DustinS (11-09-2017), mrg666 (11-15-2017), Pure Automotive (11-09-2017) |
11-08-2017, 07:05 PM | #5 |
Drives: between cars...
Just awesome!
The Following User Says Thank You to imnotsureaboutbrz For This Useful Post: | ILLSMOQ (11-09-2017) |
11-09-2017, 09:19 AM | #6 |
Drives: 2013 Ultramarine FR-S
Thats some good progress! Can't wait to see more.
The Following User Says Thank You to DustinS For This Useful Post: | ILLSMOQ (11-09-2017) |
11-09-2017, 11:22 AM | #7 |
11-09-2017, 11:48 AM | #8 |
Drives: Brz
Been waiting for this build! Glad to see it coming along so nicely!
Daily Project: Honda s2000
Track: 707 WHP Turbo Honda Civic EG Old: Kraftwerks Supercharged Subaru Brz |
The Following User Says Thank You to JoeeStacks For This Useful Post: | ILLSMOQ (11-09-2017) |
11-09-2017, 12:47 PM | #10 | |
Since I sold the motor, I figured now is as good a time as any to get started and at least I can have plenty of time to get all the other details handled exactly the way I want. |
11-09-2017, 01:22 PM | #11 |
CAN Bus Sniffer
I see a lot of folks going with TSP engines, I'm looking at them as well. Can you share your build list/specs for the TSP engine? Also can you share the part number for the T56 Magnum XL? Looking nice so far!
11-09-2017, 01:52 PM | #12 | |
This is the engine package I started out with, I changed a few things (intake, cam, skipped the computer and harness since I knew I was doing the motec) Though mine is a 418 (light overbore I think) and mine has a compression ratio of 11.25...seems like they’ve changed it up a little. https://www.texas-speed.com/p-3584-t...y-package.aspx Texas Speed has a pretty good track record from what I seen online...my other choice was MAST but it would have been another $10k or so. Last edited by ILLSMOQ; 11-09-2017 at 04:33 PM. |
11-09-2017, 04:15 PM | #13 |
Awesome! Debut at the Dec 86CUP event?
The Following User Says Thank You to mkivsoopra For This Useful Post: | ILLSMOQ (11-09-2017) |
11-09-2017, 04:32 PM | #14 |
Would love to.... but I’ll be jumping for joy if I even have the headers by then! I still need to ship them to swaintech to be coated...and then finish assembly and then tune...so realistically, I expect to be driving it sometime in Jan/Feb.
Really want to see your car in action too! |
The Following User Says Thank You to ILLSMOQ For This Useful Post: | mkivsoopra (11-09-2017) |
Similar Threads | ||||
Pure Automotive's MoTeC Plug and Play V8 Swap Thread | Pure Automotive | Engine Swaps | 51 | 11-25-2017 11:10 AM |
Pure Automotive's 2017 Race and Show Schedule | Pure Automotive | Mid-Atlantic | 4 | 01-21-2017 12:07 PM |
Pure Automotive Performance's White Street Fighter- 2JZ Swap - Formerly the FRSS LS2! | Pure Automotive | Member's Car Journals | 53 | 03-05-2015 06:11 PM |
Pure automotive pre meet | KslayFRZ | Mid-Atlantic | 0 | 07-19-2013 11:32 AM |
Anybody want to help me pick up my car at Pure Automotive? | TyperRspec789 | Mid-Atlantic | 4 | 01-31-2013 02:07 PM |
