12-01-2016, 01:50 PM | #463 |
Drives: RHD Gt86
Any companies do rhd gauges pods?
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission |
01-07-2017, 05:34 PM | #464 |
Drives: Black Limited JDM BRZ
Any photos of Block8Head with 60mm gauges, guys?
01-10-2017, 04:24 PM | #465 |
Drives: BRZ + Ducati M796
Bought the Ortiz custom dual pods. I plan on running oil pressure and oil temp there and running a 60mm boost gauge in the vent. It'll be a few months before it comes in. Any tips on where to port the gauges to?
01-11-2017, 01:43 PM | #466 |
Drives: 2013 Scion FRS
http://www.ft86club.com/forums/showthread.php?t=108488
I did the Ortiz dual pod a while back. Works great. |
03-17-2017, 02:38 AM | #467 |
Drives: Q5 + BRZ + M796
https://goo.gl/photos/T5UtodbPqQkNqtHt5
I got to installing my Defi gauges in the ATI ring vent pod and the Ortiz pod. I'm running boost/vac, oil pressure and oil temp. |
03-21-2017, 12:25 AM | #468 |
05-15-2017, 01:13 PM | #469 |
Drives: None
I waited long enough for something like this to be released, and gave up. Fits 3 52mm gauges perfectly. I'm relocating the USB/AUX to be under/above the 12v in the center console. |
The Following 2 Users Say Thank You to Njjawn For This Useful Post: | BigHugeFatGuy (08-25-2017), michaelxchristopher (06-28-2018) |
05-15-2017, 01:29 PM | #470 | |
05-15-2017, 06:32 PM | #471 | |
FYI, I finally got the relocation bezel with the new glued on switch. Im not sure if I will attempt to do the same job they did better because their cutouts looks like an amateur Dremil job. I could imagine I could do better. Also, in retrospect, I probably could have wrapped the new cluster bezel fake carbon fiber like the rest of my interior to cover blemishes. I may try that but it isn't high on my priority list. |
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | reeves (05-16-2017) |
06-08-2017, 09:46 PM | #472 |
Just spotted this while browsing ebay
I thought to share for someone if anyone like this. http://www.ebay.com/itm/13-15-Subaru...FYr19S&vxp=mtr |
06-08-2017, 10:24 PM | #473 |
Drives: 2005 Toyota Camry
06-09-2017, 07:54 AM | #474 |
Drives: RHD Gt86
Thanks for the reply, I already got a custom 3 gauge pod made
06-26-2017, 12:57 AM | #475 | |
I decided I didn't care for their repainted switch relocation bezel so I modified the stock one. Their bezel left only one of four tabs. Mine has three of four, including the screw. I made an aluminum cutout so when dremeling I wouldn't over-cut. It isn't perfect of course but an improvement without needing to paint and looks good enough that I can live with the imperfections. Sent from my iPhone using Tapatalk
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | Breadman (05-08-2021) |
06-29-2017, 10:17 PM | #476 |
Drives: 2016 FR-S
http://www.ft86club.com/forums/attac...1&d=1427586304
With this set up, do you need to modify to car to make the gauges fit or is it as simple as putting them in? |
Similar Threads | ||||
oil pressure gauge | onemorelap | Engine, Exhaust, Transmission | 69 | 03-04-2023 05:46 PM |
LHD 3-meter gauge-pod? | TuxedoCartman | Cosmetic Modification (Interior/Exterior/Lighting) | 27 | 02-11-2015 06:19 PM |
Gas Gauge Issue | Jruex22 | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-04-2013 10:28 PM |
Temperature Gauge a dummy gauge? | bambbrose | BRZ First-Gen (2012+) -- General Topics | 40 | 08-19-2012 04:29 PM |
Gauge Sweep? | himbo | BRZ First-Gen (2012+) -- General Topics | 17 | 12-12-2011 11:39 AM |
