BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
06-11-2012, 08:44 AM | #1 |
Wiring Nerd
Drives: 1994 Supra
Temperature Gauge a dummy gauge?
For those who have taken delivery, can you tell if the temperature gauge is a dummy gauge just like most cars on the road now, or does it move with the coolant temp?
Does it warm up quickly and then sit at the same spot always?
Looking for BRZ FR-S in Wake County NC for testing. PM me. |
06-11-2012, 10:16 AM | #2 |
Drives: 2013 WRB BRZ Premium 6MT
Who said it was a dummy gauge? It sits in the middle, but I don't see why it wouldn't be functional.
06-11-2012, 10:30 AM | #3 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
I've never seen a dummy coolant gauge. Every one I've owned moved with the coolant temperature.
The one in the BRZ is no exception. It warms as it should and fluctuates slightly depending on driving conditions. But you have to keep in mind that modern cooling systems are very efficient. They do a good job of keeping the coolant at a steady temperature so you won't see large fluctuations in the coolant needle. |
The Following User Says Thank You to Draco-REX For This Useful Post: | HunterGreene (06-11-2012) |
06-11-2012, 10:32 AM | #4 |
That guy
Drives: Ultramarine mt FR-S
A dummy gauge sounds like a huge potential lawsuit against the manufacture to me.
06-11-2012, 10:43 AM | #5 | |
1st86 Driver!
06-11-2012, 11:35 AM | #6 | |
Wiring Nerd
Drives: 1994 Supra
Perhaps I should have been more clear.
Almost all, as in 95%+, modern cars use dummy coolant gauges. Your Astro is no exception as GM has been doing this for a long time, since 99 I believe. From another website: Quote:
I'm sure the BRZ is no exception to this standard, I was just hoping that some of you could confirm what you have seen your own gauges do. I ask because most of these dummy gauges are inadequate for track events, as they only warn you at 230+, usually after you are getting too hot for your cooling system.
The Following 2 Users Say Thank You to bambbrose For This Useful Post: | Daemione (06-11-2012), Sportsguy83 (06-11-2012) |
06-11-2012, 11:41 AM | #7 |
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
I wasn't really paying attention, but I expect it probably works within a similar range to most other cars, which is as you described. The gauge in most cars does not really much from center unless the engine's temperature is outside normal operating range. As I said, I expect the BRZ/FR-S to be the same.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD 1986 Toyota Corolla GT-S Supercharged |
06-11-2012, 11:53 AM | #8 |
Drives: '13 Subaru BRZ Limited WRB
I've noticed that the BRZ takes significantly longer to reach nominal operating temperature as compared to my Altima. The Altima would warm up in just a couple minutes at 25-30 mph. Maybe the FA20 runs cooler than the VQ35?
06-11-2012, 12:00 PM | #9 |
Drives: 2009 135i
I would be more concerned with oil-temps than coolant, as it takes a bit longer for oil to get up to its normal operating temperature.
06-11-2012, 12:05 PM | #10 |
Registered you sir
Drives: 99 impreza coupe
I think you concerned some people when you called it a "dummy" gauge, haha... But yes, it is an idiot proof gauge, only moving when it passes a certain threshold just like the types you are thinking of.
06-11-2012, 12:16 PM | #11 | |
1st86 Driver!
Surprised it isn't more linear than that because the one in my Astro would vary "slightly" in its later years as the temp outside increased, depending on the coolant level in it at the time. |
06-11-2012, 12:46 PM | #12 |
Drives: SSM LT MT BRZ
the resistance vs temp looks like a reverse supra Dyno,
The OEM's did this intentionally because the costs of dealing with in warranty cars where the owners were freaking out because the needle moved all over the place. so they defined safety zones and let the ignorance of the consumer drive the whole market...status Quo I think these days. for track use you can always get an OBD II reader that feeds info from the ECU sensors (much higher accuracy than the "dummy" sender) and displays them in a gauge type format, ARK makes the nicest ones http://arkdesign-us.com/products/ele...unction-dash-2 but a quick OBDII gauge search on Google will reveal some less baller but probably still fine for pure data examples aswell. |
06-11-2012, 01:06 PM | #13 |
Corner Junkie
If you mean a simplified gauge, then yes, it has one. But they still move a little within the "ok" zone. The trick is ignoring any idea of linearity and using it as behavioral monitor.
However, because today's cooling systems are so good, you're not going to see a problem via coolant temperature until the temp swings wide enough for a "dummy" gauge to report anyways. |
06-11-2012, 01:28 PM | #14 |
Drives: 2013 BRZ ordered!
Dummy gauge, I like it. That's exactly what consumers want. Same as a fuel gauge that stays on Full for a really long time when the tank's not really full so people think the car is getting great mileage, regardless of what is actually happening. That's what consumers want. Car manufacturers will build anything we want to buy.
Similar Threads | ||||
Seat heater temperature? | milenko11 | BRZ First-Gen (2012+) -- General Topics | 29 | 09-20-2012 01:19 PM |
Aftermarket gauge placement | CyberFormula | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 08-18-2012 01:01 AM |
European fuel/coolant gauge face | arbnpx | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 05-31-2012 12:23 AM |
Gauge Sweep? | himbo | BRZ First-Gen (2012+) -- General Topics | 17 | 12-12-2011 11:39 AM |
