Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
01-10-2017, 12:45 PM | #43 |
Drives: Toyota GT86
It would be great the see force/velocity curves for the dampers as well with the rebound set to the extreme positions, if it's not too much to ask.
01-10-2017, 02:06 PM | #44 | |
Drives: 2005 Toyota Camry
According to Greddy, the spring rates are indeed 6F/7R and what was sent so far is all wrong. Greddy will send me the correct springs later. -alex |
01-10-2017, 04:14 PM | #45 |
Drives: Toyota GT86
So they are just going to exchange the springs or are you getting re-valved dampers to match as well?
01-10-2017, 04:57 PM | #46 |
01-18-2017, 01:12 PM | #47 |
Drives: '14 WRB BRZ | '17 CB STi
I'm looking at getting these very soon. Did GReddy USA confirm these were incorrect and that they'd ship you new rear springs, or was this a vendor? I'm trying to figure out if it matters who I order them from, so I can make sure I get the correct rear springs when they become available.
01-19-2017, 12:05 AM | #48 | |
Drives: 94 civic hatch, Whiteout frs
01-19-2017, 01:59 AM | #49 | |
Greddy is having the correct spring produced and is in the process of having them powdercoated, once it is done it will be exchanged. Since the rear uses stock top hats, I strongly advise you to wait until the correct springs are out before buying, because the rears are easy to exchange now in the box, but will require you to disassemble the entire rear suspension if you have it on the car. -alex |
01-31-2017, 05:59 PM | #50 |
Drives: 17' CWP BRZ ------- 15' GLA45 AMG
Interested in grabbing a set of these as well... Hoping to get these over the Tein Street Flexes.
Waiting on your guys' reviews!! |
01-31-2017, 09:12 PM | #51 |
No review because I don't have a BRZ anymore, but here's how they dyno...
Full hard Full hard minus 3 adjustments Full hard minus 6 adjustments |
01-31-2017, 09:45 PM | #52 |
I have no idea how to read the shock dyno... can someone smart explain it? lol
The Following User Says Thank You to ryoma For This Useful Post: | meWant (02-01-2017) |
02-01-2017, 11:03 PM | #53 | |
great read! http://www.ft86club.com/forums/showthread.php?t=81062 In the end, its up to what you want out of your vehicle. You can see how the rebound on -6 is a softer rebound earlier on the rebound where as full stiff gives max rebound which would effect body roll. not a pro here, thats as much as i got to. Defiantly need to check and compare against other shocks you are looking at. |
02-01-2017, 11:14 PM | #54 |
Drives: Legacy GT
Not very much low speed compression there. I would have expected more and some digression out of them. The t2s and v3 get a pretty good amount when you turn up the bump a little.
02-02-2017, 09:16 PM | #55 |
Drives: Toyota GT86
Thank you very much. Would you happen to have charts for KW V3 too for comparison?
02-03-2017, 03:09 PM | #56 |
Similar Threads | ||||
Greddy Base Map for FRS Greddy Turbo Kit | hiranak | Software Tuning | 10 | 10-27-2014 06:55 AM |
*** [DECIDED] GReddy *** Full Blown vs GReddy | slisgrinder | Forced Induction | 31 | 08-13-2014 02:24 PM |
GReddy T518z+Greddy CS GTS Ver 2. Video + pics (not tuned) | NOTORIOUS.BRZ | Engine, Exhaust, Transmission | 21 | 09-24-2013 06:09 PM |
GReddy in on-deck circle. GReddy turbo for FR-S/BRZ first up. | 2JZ-DNA | Engine, Exhaust, Transmission | 46 | 04-19-2012 08:13 PM |
