12-07-2016, 09:16 PM | #2031 |
Drives: 2014 Subaru BRZ
Sorry. 18x9.5 +38.
Sent from my SM-N900W8 using Tapatalk |
12-08-2016, 12:29 PM | #2032 |
Country Boy 4 Life
The Following User Says Thank You to Leonardo For This Useful Post: | Jive Turkey (12-08-2016) |
12-08-2016, 07:19 PM | #2033 |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
yeah a 9.5 up front on stock struts just won't work.
255/35-265/35 those are the tire sizes to consider... |
The Following User Says Thank You to Jive Turkey For This Useful Post: | Leonardo (12-08-2016) |
12-08-2016, 08:08 PM | #2034 |
Thanks!
12-09-2016, 11:16 AM | #2035 |
Drives: 2013 BRZ black
Haha. So Mark @RavSpec had to stop me 3 times to confirm I knew what I was ordering. They keep insisting my offsets are too high and conservative. 18x9+47 R disk / 18x10+50 A disk.
Ill be buying 265/35 and 285/35 respectively and dont want to roll fenders on a 1.5-2.0" drop and -0.5F/0.0R camber. Crossing my fingers I havent made a HUGE mistake. I guess we'll see in 12-15 weeks when they get here. Ill post pics as soon as they get mounted. #turbocarfitment
12-09-2016, 04:58 PM | #2036 | |
1337
Drives: 2013 BRZ WRB S/C
The Following User Says Thank You to djdnz For This Useful Post: | xkalelx (12-11-2016) |
12-12-2016, 12:11 AM | #2037 | |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
12-13-2016, 09:46 AM | #2038 |
Yeah, I posted pictures on pg145. Im running Ohlins and measured how much room I had to play with before ordering. I should have plenty of room... Ill move the brake line brackets if they get in the way but I doubt they will. Only concern right now is full lock rubbing. Ill post results!
12-14-2016, 08:25 AM | #2039 |
You have to wait HOW LONG for wheels? 😱
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
12-15-2016, 03:02 PM | #2040 |
Yeah, I know... the only thing they have in stock is the 18x9.5+38. So they are being built to my specification request. Doesnt cost anymore to do it that way, just takes 3-4 months to get them custom wheels in mah hands.
12-16-2016, 08:07 AM | #2041 |
Drives: Subaru BRZ 2017 (almost)
I got mine after around 12 weeks from WORK custom made
Sent from my Nexus 6P using Tapatalk |
12-16-2016, 11:08 AM | #2042 | |
Drives: Boner Garage
still new to the site. |
12-20-2016, 10:47 AM | #2043 |
Drives: 2013 BRZ Limited
To anyone else running 265/35/18 in the rear, what are your alignment specs? I'm sitting on factory settings now after getting new wheels and was having rubbing issues with the tire sidewall actually hitting the fender. I took the car in for a realignment and they said they couldn't add any more rear camber without rubbing the inside??
I'm only lowered about 3/4" in the rear, something sounds fishy. |
12-20-2016, 12:20 PM | #2044 |
Drives: 2014 UltraMarine FRS
My plan is to go with 265's as well, and from what Ive gathered on this site, as long as you have coilovers/atleast a +40 offset/and -2 degrees camber, you should be fine. Hmmm...
Similar Threads | ||||
Winter Tire Review Thread (Please contribute) | pastuch | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 344 | 03-13-2024 05:49 PM |
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 97 | 09-09-2015 06:32 PM |
Meaty rubber on flush spoke rims? | red_comet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 06-14-2013 12:21 PM |
Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 01:40 AM |
The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 03:05 PM |
