Old 11-28-2016, 02:54 PM   #2017
nima314
Drives: Subaru BRZ 2017 (almost)
Originally Posted by xkalelx View Post
CR2P!!!
What specs did you go with and what tire sizes are you going to run? Im looking hard at buying a set!
TIA
I went with 18x9.5+38 and going for a 255/35. 245 will be too much stretch and 265 is too much meat for me hahaha. Hope you get them, what colour were you looking at?
Sent from my Nexus 6P using Tapatalk
nima314 is offline   Reply With Quote
Old 11-29-2016, 02:12 AM   #2018
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Need some advice! 18x9.5 with 255s how much negative offset can I run? I'm pretty low but I've been on 17x9 with 245 and I'm running -28 offset. The 18x9.5s I just got are -38 but I don't want to keep switching spacers all the time, can I run -23 F and -28 rear without rubbing on the fender like mad? I have -3 F camber too.
I have ARP studs and 5,10 and 15mm spacers but I don't want to shuffle them around when I go back in forth between my 17 and 18" set-ups.
Old 11-29-2016, 03:23 AM   #2019
swarb
I think you mean positive offset. Not many negative offset wheels. Our car does not fit wheels like a s14 240sx sadly... It also depends on what tire you are planning to run.
I'm on 18x9.5 +34 on 255/35 with around -2.9f/-2.7r camber. I rub on the bumper tabs on the rear and front clears. If you can rephrase the question with what tire size you plan to run, maybe I can give a better example. But for 9.5's, mid to high 30's and low 40's positive offset it what is needed without extreme(4+) camber.
Old 11-29-2016, 09:15 AM   #2020
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
Since Im turbo, I am wanting a staggered street set. Im thinking about ordering 18x9+47(max available) R Disc / 18x10+48 A Disc on 265/35 and 285/35 respectively. I want to run minimal camber on the street set. I am digging the bronze barrels with GT silver discs. What did you go with? Matte black discs on polished barrels? Looks good!
I run -3.0deg square on my square set of 17x9+35 WedsSports on 245/40. These are currently my dailies/track set. Soon to be track only with 255/40 R888r's
Heres some shots of what I have to play with. I can come in as much as 1.5" on the rear before making contact with the E-brake cable or fender liner and about 1.25" up front on the Ohlins.
I dont think I will have any issues with fitment unless someone wants to chime in.
xkalelx is offline   Reply With Quote
Old 11-29-2016, 11:19 AM   #2021
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Those offsets seem to be high. +35 on a 9" would be flush with the fenders, so somewhere around there would be better. If you are looking at 265 in the front, why not use a 9.5" et38 up front? the 18x10 is done with a +40 to +44 so the +48 isn't that bad, but I would be worried about rubbing the inside with camber added especially with that wide of a tire. Unless you want the tucked look/looking to use spacers to get the fitment you want?
The Following User Says Thank You to DustinS For This Useful Post:
xkalelx (11-29-2016)
Old 11-29-2016, 01:16 PM   #2022
xkalelx
xkalelx's Avatar
I know they seem high, but my 17x9+35 TC105Ns poke up front. I have to have -2.0/2.5 camber up front to bring them flush. And I only want to run about -0.5 camber on this setup up front. I would also prefer to have a little tuck to compensate for meaty tire bulge. While I know a 9.5 will fit up front, I just see it as unnecessary weight.
In the back, I already measured (see pics above) and should plenty of room. Ill be running close to zero camber so it shouldnt come anywhere near the coilover. Im trying to stay out of contact with the fender with this offset basically. Think a +40 would be better?
Old 11-29-2016, 01:27 PM   #2023
Kordless
Drives: '13 BRZ Limited
Really need help, I have 265/35/18 Federal RSRRs in the rear on a 18x9.5+30 wheel, its rubbing the fender A LOT. I'm on Tein Flex Z with no LCA or camber bolts, my car is dropped. Do i need to raise or lower the car to make them fit?
Kordless is offline   Reply With Quote
Old 11-29-2016, 01:58 PM   #2024
xkalelx
xkalelx's Avatar
Raising the car may not help. When I was still on OE control arms, -2" ride height gave me -2.5deg natural camber. Going up to -1" ride height made my natural camber -1.7deg. I would think you would still be eating your fender. Better solution may be adj lower control arms to add more negative camber.
Old 11-29-2016, 03:54 PM   #2025
Kordless
My friend had the same setup I had and he didn't rub before he got LCA. He said his ride height was higher than mine and they fit, do you think itll be fine?
Old 11-29-2016, 06:32 PM   #2026
nima314
Yeah matte black with polished lip. Thanks a lot man, i love the bronze, go for it
Old 11-30-2016, 01:02 AM   #2027
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
as i said in the original post, EVERY CAR is different, even if its the same model.
i can't stress dialing in some camber enough. +30 is quite aggressive for that tire to be practical in my opinion. i was running +40 with same specs and that was tight fitment. You should roll your fenders to gain some clearance if you'd like and then pull some more camber all around.
or go to a 255/35 tire. you can also raise it a bit to help elevate some rub.
Jive Turkey is offline   Reply With Quote
The Following 2 Users Say Thank You to Jive Turkey For This Useful Post:
Leonardo (11-30-2016), PandaSPUR (11-30-2016)
Old 11-30-2016, 01:33 AM   #2028
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
^ +1, I heard that a lot when trying to decide if I needed to get adjustable rear LCAs. Ended up going with SPC LCAs for like $200 installed.
No problems here, but I guess my setup isn't as aggressive as yours. 17x9 +35 with 255/40 tires on Tein Monosport with minimum drop (.5" I think?).
Old 11-30-2016, 09:21 PM   #2029
amaciose
amaciose's Avatar
Drives: 2013 BRZ Limited
Finally joining the club!
SPECS:
Rays Gramlights 57xtreme
Front: 18x8.5+45 w/ MPSS 235/40/18
Rear: 18x9.5+40 w/ MPSS 265/35/18
Factory alignment specs
Lowered ~1" front, ~0.75" rear (due to tire rubbing in rear, need to add a bit more camber)
amaciose is offline   Reply With Quote
The Following 2 Users Say Thank You to amaciose For This Useful Post:
slow15frs (12-04-2016), yberther (12-21-2016)
Old 12-07-2016, 09:01 PM   #2030
adrixe
adrixe's Avatar
Drives: 2014 Subaru BRZ
I have a question regarding the size of tires I'll get.
Im planning on buying another members ambit re02. I have 1" lowered springs and stock struts.
I like a little meaty tire but also doesnt want to have issues on rubbing. What is the best tire setup I should go for?
Appreciate it.
Sent from my SM-N900W8 using Tapatalk
adrixe is offline   Reply With Quote
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
