Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
11-05-2016, 07:08 PM | #15 |
Panda Trueno
Drives: No twin now.
I would get a second opinion on the install itself, as well as the alignment.
If all else fails here are some adjustable rear lcas for a decent price.....http://www.ft86club.com/forums/showthread.php?t=112652 |
11-05-2016, 07:23 PM | #16 | |
LMGTFY
Drives: 13 FRS, 91 Miata
11-05-2016, 07:25 PM | #17 |
Panda Trueno
11-05-2016, 07:30 PM | #18 | |
Drives: 2013 frs
I did overlook this step last night. Does the pic work? Ill have to get under there when its dry out and see wich ends are pointing which way Sent from my iPhone using Tapatalk
2013 silver frs, injen intake, agency power header, hks exhaust, no kitties, ecutek tune
11-05-2016, 07:37 PM | #19 |
Panda Trueno
That is probably your issue. One spring isn't situated correctly.
3:06 or so... |
11-05-2016, 07:50 PM | #20 |
Drives: 2013 frs
We shall see. I guess that will be my issue if so!!
11-05-2016, 07:55 PM | #21 | |
Drives: 2013 frs
Yeah watched every video on youtube before i did the install. Did you see my photo. Says one end needs to point to rear other to front. Which he doesnt mention. Nor does any other installer. The springs are seated properly in their perches. I just will have to see if the ends are pointing in the correct direction Sent from my iPhone using Tapatalk
11-05-2016, 08:55 PM | #22 | |
Frosty Carrot
Drives: The Atomic Carrot
IIRC, we ended up with 2.1 & 1.0 degrees. It has felt great for daily driving and autocross this season. If you need it even, SPC is the cheapest lower control arm option. It's hard to justify other LCA's unless you're dropping much lower (or you just like car jewelry).
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX Wall of Shame - aFe Takeda, Wilwood, FA20Club |
11-05-2016, 09:21 PM | #23 | |
Drives: 2013 frs
Rear camber crazy from .75" drop
Yah toe is great. Its just rear right camber thats in the red. I dunno man it looks really weird. One tire is tucked into sidewall and the other pokes out quite a bit. Im assuming the direction the coil end is pointing is off. If its not the coils and its installed correctly. What about lca bushings? Dont they allow for +\- .5 degree? Would let me get one side to -1.5 and -2.0. Much closer. Sent from my iPhone using Tapatalk
11-05-2016, 11:58 PM | #24 |
Drives: 2013 frs
I also think theres a little clunk on rear corner that is -2.5. Im going to re install the rears making sure ends are pointed in proper direction. Then pay for another alignment
11-06-2016, 08:53 AM | #25 | |
Drives: 2017 BRZ
Did you have similar difference in the tires before the springs? If not, something seems to have changed somehow with the install. I am unsure what it might be since there really is very little wiggle room on the rear install. I suspect the camber has always been off. |
11-06-2016, 11:05 AM | #26 | |
Drives: 2013 frs
Not that i noticed. Looked fine before!! And how will i payvwith bushings jn labour? I dont want new lca as i dont want to be any lower in rear!! Sent from my iPhone using Tapatalk
11-06-2016, 11:13 AM | #27 |
Panda Trueno
Bushings have to be burned or pressed out for replacement. So there is labor costs.
Only certain rear lcas lower you. |
11-06-2016, 11:20 AM | #28 | |
Drives: 2017 BRZ
Rear LCA won't make you lower unless you go with a lowering LCA like the Stance. Whiteline won't, and is among the lower cost options. There really is no room for geometry change in the back beyond bushing compliance. That's a possibility, you mention noise IIRC. Verify full range of motion without binding without the shock, and be sure it installs easily as a place to start checking. |
Similar Threads | ||||
FS: New H&R TC112 Rear Camber Bolts, PAC 2.5" Helper Springs | customfab87 | Brakes, Suspension, Chassis | 0 | 02-08-2016 10:41 PM |
Fitment with -2 Camber and 1" Drop 18x9.5? | ajcarson11 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 10-26-2015 01:29 PM |
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! | Corner3garage | Southern California | 188 | 04-24-2015 01:10 PM |
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! | Corner3garage | Mechanical Maintenance and Tools | 6 | 10-31-2013 03:40 PM |
