Old 03-05-2016, 01:48 AM   #967
steve99
Drives: FT86
Originally Posted by Dru670 View Post
can anyone tell me if there is anything wrong here most especially the highlighted rows which is when I hit 2nd gear it feels like it bogs or hesitates for a second and then smoothens out as rpm or speed picks up. I'm a total noob sorry.
BTW i'm running a drop-in filter, UEL header, and catback exhaust on stage 2 91 tune.
it will likely be load limits , see reply to your other post for full details
Old 03-05-2016, 06:23 PM   #968
JB86'd
JB86'd's Avatar
Drives: JAWS
Just wanted to post a little BEFORE and AFTER here of my OFT Stage 2 tune with JDL UEL header.
My current Load Limits, and MAF scale (compared to the standard OFT maf scaling):
Before- OFT stage 2 tune, 91 oct with no modifications.
http://datazap.me/u/joshbustos86/jdl...zoom=1592-1718
After- OFT stage 2 tune, 91 oct with custom OL maf scaling/ Load Limits and modified DI/PI tables based on Wayno's modifications.
http://datazap.me/u/joshbustos86/jdl...4&zoom=609-733
Many thanks to @Wayno and @steve99 for the guides and assistance.
JB86'd is offline   Reply With Quote
The Following 2 Users Say Thank You to JB86'd For This Useful Post:
sav (03-06-2016), Wayno (03-07-2016)
Old 03-07-2016, 06:02 PM   #969
cawith
Drives: Toyota GT86 6M/T
Originally Posted by Rezi View Post
@cawith
I have exact the same Knock (or false knock) around that Area (between 3400-3600rpm@0.5/0.6 load). Stg1 Wayno's 98 v96 (no MAF-Scaling).
With Shell V-Power (100 octane EU) and BP Ultimate (98 octane EU) i have a lot of minor -0.65 FLKC and little FBKC of -0.69. IAM at 1 all the time.
With OMV MaxxMotion (100 octane) i have zero FLKC. Only little FBKC of -0.69. IAM at 1 all the time.
Maybe the sensor goes on because my bumper is hitting the chassis at higher speed (broken clip).
With stock OTS Stage 1 91oct i had a lot of FLKC/FBKC and IAM drops.
I did not log higher rpm's, but monitored it. Zero FLKC/FBKC with OMV MaxxMotion.
I would leave it as it is now (also thought of pulling about 0.7 degree of timing, but i let the ECU handle it). Or investigate it at higher outdoor temperatures. Steve also "calmed me down" that i do not have to worry about FLKC/FBKC if it is less than -1.
Shell V-Power: http://datazap.me/u/rezi/stg1-a00g-w...og=0&data=1-10
OMV MaxxMotion: http://datazap.me/u/rezi/stg-1-a00g-...og=0&data=1-10
Okay, thanks.. Well I guess I'll just leave it as it is right now, and then maybe (if it annoys me too much) pull some timing myself some time in the future.
Unfortunately I can't fill up with anything else than Shell V-Power, which is also "only" 99 oct here.
cawith is offline   Reply With Quote
Old 03-07-2016, 08:50 PM   #970
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
0.6 timing pulled at 3200/0.6. Also literally nothing to worry about.
I'd only pull timing
1. If it's in the power band AT STREET TEMPS.
2. If it causes IAM drop AT TRACK TEMPS.
@cawith
The Following User Says Thank You to Wayno For This Useful Post:
cawith (03-13-2016)
Old 03-07-2016, 08:58 PM   #971
Wayno
Wayno's Avatar
Did you try 1.02 at 3800?
Attachment 132567
Attachment 132565
Attachment 132566
Old 03-07-2016, 10:16 PM   #972
JB86'd
JB86'd's Avatar
Drives: JAWS
I've had it at .9, 1.0, 1.1, and differing between 3600, 3700, and 3800. When it's set to a place where the load limit exceeds it, it helps the AFR but only for a short 100 RPM range and the rest is still rich. So I gave up and just left it at 1.05.
Old 03-07-2016, 11:36 PM   #973
Wayno
Wayno's Avatar
Move 1.17 to 3000 rpm, make 3800 1.0. It doesn't matter very much if WOT is lean below 3000.
Or if it feels fine, leave it as is.
Old 03-08-2016, 03:15 AM   #974
Rezi
Drives: GT86
Pulled some degrees just for a test to see if it is false knock detection.
And yes, again between 3200-3500@0.5/0.6
http://datazap.me/u/rezi/0703165?log=0&data=1-4
and this is where the knock sensor learned the "vibrations" after fresh flash
http://datazap.me/u/rezi/0703161?log=0&data=1-4-10
This happened only one time. After 20km it was gone.
Rezi is offline   Reply With Quote
Old 03-08-2016, 03:29 AM   #975
steve99
Drives: FT86
Yes it quite possible ecu does some kind of background learning in relation to knock sensor ,so knock seen directly after flash may be "false"
Old 03-10-2016, 06:38 PM   #976
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
on a base tune for my supercharger... can anyone see why i have 'hiccups' under load?
http://datazap.me/u/rifle/log-1457652873?log=0&data=6
@sales@delicioustuning.com @steve99
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
Old 03-10-2016, 07:00 PM   #977
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Mind sharing who made the base map?
Sincerely,
Zach
Old 03-10-2016, 07:09 PM   #978
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Link doesn't work for me. Is the log public?
Old 03-10-2016, 07:10 PM   #979
steve99
Drives: FT86
i cannot access log suspect you did not check the public check box
Old 03-10-2016, 07:13 PM   #980
Rifle
Rifle's Avatar
Sincerely,
Zach
oops! made public
295WHP/220TQ
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
