Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
01-17-2016, 05:15 PM | #1 |
Drives: 2013 Raven FR-S
Nasty Enginer Noise - Help needed
Hello guys, have this nasty engine noise that I need help diagnosing. Hope it's not the awfulness I'm imagining. Happened on a fresh tank of E85, at about 6500 rpm on second gear.
Mod list: Borla UEL headers Nameless hi flow cat uppipe Isis catback K&N drop in filter Moto east E85 tune |
01-17-2016, 05:29 PM | #2 |
Seriously don't leave it on.
Any smoke when it happened? Do you have a flex fuel kit? How reliable is your fuel? Did you put the wrong fuel in? Are you 100% sure? Do you have any thing to read from the ecu? fuel trims etc? Did you immediately make a pass after fueling? Check your oil. If you think it is the fuel, drain it from the tank and refill and hope the damage hasn't already been done. |
01-17-2016, 05:47 PM | #3 |
Didn't see any smoke. No flex fuel kit. Filled up with e85 with gas gauge reading empty and drove about 30 miles before I got on it. Not sure what the mix exactly was when it happened but it was definitely ethanol i put in because of the smell. Will check oil, and hook up ecutek cable to see if i can grab anything
01-17-2016, 05:55 PM | #4 |
Could it be a manifold leak? Header has been rattling for the past couple days
01-17-2016, 05:57 PM | #5 |
Drives: Raven FR-S 6M
Sounds like a hole in your exhaust.
“The World is Flat”
[||•]=(86)=[•||] |
The Following 2 Users Say Thank You to Apoc For This Useful Post: | strat61caster (01-17-2016), Ultramaroon (01-17-2016) |
01-17-2016, 06:06 PM | #6 |
chicken tonight
cracked flexible coupling on the Borla? Sounds like you filmed a cold start. Smell exhaust in the engine bay?
The Following User Says Thank You to Ultramaroon For This Useful Post: | Aztec (01-17-2016) |
01-17-2016, 06:36 PM | #7 |
Yeah, it was a cold start, that's why you hear the noise go away when the idle dips. Was trying to smell for the exhaust but didn't smell it as too obvious, possible it was there though. When I first installed my Borla, I had a nasty rattle/resonance from the flexible couplings. I covered them up with exhaust wrap which helped a lot with the rattle. It could be that they finally cracked.
01-17-2016, 06:42 PM | #8 |
Lost in the twisties
Drives: 2014 BRZ Dark Gray Metallic
+1 for exhaust leak. Jack that thing up and take off the header
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft Aztec's Build Thread |
01-17-2016, 06:54 PM | #9 |
01-17-2016, 07:16 PM | #10 |
chicken tonight
The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (01-17-2016) |
01-17-2016, 08:56 PM | #11 |
The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (01-17-2016) |
01-17-2016, 10:07 PM | #12 | ||||
Sounds alot like a manifold exhaust leak to me as well, as you increase revs the sound becomes faster and more prominent?
01-17-2016, 11:06 PM | #13 |
Drives: Firestorm 2013 FR-S
Almost certainly an exhaust leak-- so about the cheapest of the possible problems to fix.
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
01-18-2016, 09:50 AM | #14 |
Thanks guys, I have to go out of town this week but I will put it up on the jack and check this Friday.
Similar Threads | ||||
Nasty sweat like odor from HVAC system when engine is off? | PandaSPUR | BRZ First-Gen (2012+) -- General Topics | 56 | 01-12-2016 02:30 PM |
Very nasty grinding on fast corner exit from LSD? | JaguarXJ6 | BRZ First-Gen (2012+) -- General Topics | 10 | 12-07-2013 03:06 PM |
The Nasty FR-S Review Part 2 | Dezoris | Scion FR-S / Toyota 86 GT86 General Forum | 150 | 02-09-2013 10:10 PM |
Volvo 245 with a Supra Enginer | Asphalt~86 | Off-Topic Lounge [WARNING: NO POLITICS] | 0 | 01-29-2013 10:29 PM |
