Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) Wash, Wax, Details, Repairs |
Drives: Brz
Side Marker came out
Side marker came out cause of a car wash
![]() any ideas what I could do if the clip is broken? For the time being I put a little bit of glue + tape to keep it on but going to remove it soon to take a look. Anyone has any easy fixes for if the clip is broken? I'm hopeful it just came loose but I doubt it could come loose without the clip being broken. anyone else deal with same issue? Thanks, HK |
#2 |
Drives: brz limited sterling silver 14
I had a driver side side marker that kept coming loose. Finally end up just using a double side tape.
Sent from my D6603 using Tapatalk |
#3 | ||
http://www.fteightysix.com/appearanc...er-clips-pair/
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | Bramick (10-25-2015) |
#4 |
hey you, yeah you <3
Drives: 2014 37J FR-S
Time for clear ones!
#5 |
Drives: Brz
#6 |
Car N00B
Drives: Honda Accord (2002)
Mine are a bit loose (or something) but the clips are still there, I just added some double-sided tape which hope keeps them firmly in place.
#7 |
Drives: 2014 BRZ MT (Sold); 2006 V70R
the clips suck on these.
Fill the hole for the clip w/ epoxy or super glue after you install the clip. That should keep the clip securely in the side marker housing. I think there's a place you can buy replacement clips if you lost yours.
'14 BRZ LTD MT DGM
#8 | |
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#9 |
Drives: 2014 BRZ Limited SWP
I drilled a hole in mine and ziptied it to my bumper.
fker is not going anywhere
#TrackDayBro
#10 |
Drives: JAWS
I recently had to replace my sidemarker bulbs and the clips on one side were dunzo. I used some clear silicone rubber on the contact points, shit isn't going anywhere, but is mellow enough to come apart if I need to take it off.
#11 |
Drives: 2014 Scion FR-S
If the clip is broken, you can try replacing it; @fteightysix sells all three of the clips in individual pairs for jsut $5.00 USD - http://www.fteightysix.com/appearanc.../#.VjLTgberSUk. Otherwise, a few of the suggestions offered in this thread are a decent option - or just upgrading the clear side markers
The Following User Says Thank You to Ammunition For This Useful Post: | MTeator (10-29-2015) |
#12 |
Car N00B
So I used double-sided tape on both markers - one marker is firmly in place (after 600 mi) the other one still gets loose... So for the cheapest easiest solution, I'd just go with the tape but take the time to do it right.
No real drawbacks to using it... |
#13 |
JDM Vaping Stance Nation
Drives: 2013 White
I have smoked sidemarkers. Transferred my clips over from OEM and they're still loose
#14 |
Just bend them out, releasing the clips sometimes bends them in with the effect of making the markers loose on reinstall. Actually take the clip off and heat it up then bend it. Apparently they tend to break when cold. Heating them then re attaching the clip to the marker should reduce the breakage chance.
WTB: Passenger Side Clear Side Marker | Sheepdog | Want-To-Buy Requests | 0 | 08-03-2015 08:56 PM |
wtb oem side marker | WATCHMEHEAL | Want-To-Buy Requests | 0 | 07-30-2014 11:37 PM |
WTB side marker | jupillam | Want-To-Buy Requests | 4 | 07-25-2014 11:32 PM |
WTB: orange OEM side marker (passenger side or both) | Kayzer Soze | Exterior Parts (Aero, Lighting, Etc.) | 4 | 09-05-2013 04:46 AM |
WTB: smoked side marker (driver side) | vincent201089 | Exterior Parts (Aero, Lighting, Etc.) | 2 | 07-29-2013 04:29 AM |
