Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
08-22-2015, 08:42 PM | #1 |
Drives: Whiteout FRS
Winmax W2 Brake Pads Sticking
Hey guys,
I was wondering if anyone can help me out with this issue. I just installed some Winmax W2 pads and it appears that they're sticking. The pistons were retracted and put back into their place and when I slid the caliper over the brake pads they were slid right in. Any advice? Thanks! |
08-22-2015, 09:10 PM | #2 |
Power Ranger Elite
Drives: '13 WRB Sport-tech
@WingsofWar didn't you have these pads at one point?
08-22-2015, 09:55 PM | #3 |
What makes you think they're sticking? Were the pads easy to insert into the caliper carriers?
08-22-2015, 10:04 PM | #4 | |
I have a pretty steep driveway and when I leave the car in neutral it'll roll back. However, when I installed the pads the car did not roll back. I figured it out. I took off the shims and it now works perfectly. Thanks all! |
The Following 2 Users Say Thank You to shellslinger For This Useful Post: | CSG Mike (08-23-2015), jimmillion (08-24-2015) |
08-23-2015, 11:41 PM | #5 |
Drives: Frs
Is it required to remove the shims? I just installed some winmaxx pads and left the shims. The car is still on jack stands as I still have some more work to do.
TIA Sent from my iPhone using Tapatalk |
08-24-2015, 01:19 AM | #6 |
I would leave off the shims. Although, my car is at 38k miles the brake pads had about 80% life on them. I compared the OEM pads with the Winmax pads and the Winmax pads are really thick, so with the shims it made the pads drag.
08-24-2015, 01:21 AM | #7 |
No, but it may make the shims + pads "too thick", which will ersult in pad drag until it gets thin enough.
The Following User Says Thank You to CSG Mike For This Useful Post: | strat61caster (10-21-2015) |
08-24-2015, 01:24 AM | #8 |
in orbe terrum non visi
Drives: violent
@csgmike yeah winmax seems to have made then as absolutely thick as they could. Some people get lucky and it all fits new. Sometimes the shims only fit after a few miles.
08-24-2015, 08:16 AM | #9 |
Drives: Frs
I think I misunderstand. I am talking about the anti-rattle "shims" that are on the side of the pads, not the backing plate.
Thanks CSG Mike! I finally got around to installing the pads I bought from counter space garage. I signed up for subiefest, as all the 86cup's left are really far from me. I never reuse that backing plate. Am I using the incorrect terminology? Sent from my iPhone using Tapatalk |
08-24-2015, 12:13 PM | #10 | |
Where are you located? Everyone generally makes at least a 2 hour drive for most 86CUP events, with the Vegas guys regularly making a 5+ hour drive to make it... |
08-24-2015, 12:15 PM | #11 |
Drives: Frs
Yeah I know. I'm in San Diego.
I'm excited to try out the new pads and tires. Thanks again for all your great help and advice. I'll post a review of the pads after my first session Sent from my iPhone using Tapatalk |
08-24-2015, 01:04 PM | #12 |
After bedding these brakes in, they feel great kinda like oem but they bite a little harder. Also not to mention without the backing plate and shims they look awesome on the car
The Following User Says Thank You to shellslinger For This Useful Post: | CSG Mike (08-24-2015) |
08-24-2015, 04:14 PM | #13 |
you don't leave the backing plate on? I heard it is supposed to dissipate heat and protect the piston seals from melting. that's why I kept mine on, but I do agree the gold looks awesome lol
08-24-2015, 07:11 PM | #14 |
Sorry about my post, I was referring to the two shims. Not the backing plate.
Similar Threads | ||||
Winmax Brake Pads SOLD | Lunatic | Brakes, Suspension, Chassis | 11 | 05-13-2015 11:00 AM |
FS: Winmax W1 Stage 1 Brake Pads | bobsacamenoh | Brakes, Suspension, Chassis | 6 | 04-26-2015 12:44 AM |
My Review of Winmax Brake Pads | ichitaka05 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 12-31-2014 12:11 AM |
FS: Winmax W1 brake pads, front and rear, used, $120 | retrosmiths | Brakes, Suspension, Chassis | 5 | 09-02-2014 12:32 PM |
FS: Winmax brake pads new | BeltedBiscuit | Brakes, Suspension, Chassis | 0 | 03-06-2014 02:24 AM |
