Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
11-03-2014, 11:19 AM | #29 | |
Drives: '11 Cayman , '14 Camry, '11 Tacoma
1) The compressor disengages at high RPM, because the compressors are not designed to operate at full engine RPM. 2) It also disengages at WOT, regardless of engine speed. As you stated, this reduces engine load when you call for max power (WOT). |
The Following User Says Thank You to billwot For This Useful Post: | jdubz13frs (11-03-2014) |
11-03-2014, 01:52 PM | #30 | |
That guy
Drives: Ultramarine mt FR-S
Ultramarine mt FR-S
P&L stage 1 turbo Prime Motoring Flex fuel Jr Tuned 506whp @17psi (e73) |
11-03-2014, 03:06 PM | #31 |
Drives: 1992 Nissan Skyline GTS-t Type-M
Yes, yes, I hate it too since it bogs down the engine
11-03-2014, 03:09 PM | #32 |
Sometimes I'm wrong.
Drives: '13 FR-S/'96 240SX
11-03-2014, 04:04 PM | #33 |
Drives: 2014 BRZ Limited
11-03-2014, 05:12 PM | #34 |
Drives: Neptune GR86
Would have made more sense if he quoted the original necro bump.
11-03-2014, 05:24 PM | #35 |
chicken tonight
subbed!
11-03-2014, 07:56 PM | #36 |
Benched 86lb
Drives: Ultramarine FR-S
Indeed it's an old thread. I resurrected it because A) it's completely relevant, and B) it's number one on Google if you search for "frs air conditioning defrost dumb feature"
11-03-2014, 08:25 PM | #37 |
Drives:
Annoying that the AC light stays dark even though the compressor is running in defog mode. Where I come from, "off" means "off"
11-04-2014, 07:44 AM | #38 |
Benched 86lb
Turns out my approach is imperfect: the condenser fan still runs.
lol |
11-04-2014, 09:02 AM | #39 |
Drives: 2013 BRZ Limited
It is actually more beneficial for any refrigeration system to run on occasion then sit. It helps keep moisture out and the seals wet so they don't fail. I would hate to have to buy a new A/C compressor a couple years down the road.
Someone said something about electrical load. The only electrical load the compressor has is the small amount for the clutch, the rest is the mechanical load of compressing something to upwards of 400 psi.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears 1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust 1993 Honda CB750 Nighthawk |
11-04-2014, 09:03 AM | #40 |
The great part is everybody will disconnect it and then we will start getting all sorts of posts that say "windshield keeps fogging up what can I do?".
The Following 5 Users Say Thank You to Tcoat For This Useful Post: | billwot (11-05-2014), CoupedUpSubie (11-04-2014), extrashaky (11-05-2014), flippy (11-05-2014), Ultramaroon (11-04-2014) |
11-04-2014, 01:05 PM | #41 |
chicken tonight
I hear that from women all the time. So depressing.
11-05-2014, 11:44 AM | #42 | ||
High side operating pressure for a 134A system will typically be around 200-225 on a 90F day. But the low side will still be about 30, so the actual pumping load (pressure differential across the compressor) will be about 175-200. The system high pressure switch is probably set at 250, maybe 300. I agree with the rest of your post. |
The Following User Says Thank You to billwot For This Useful Post: | CoupedUpSubie (11-05-2014) |
Similar Threads | ||||
Odometer Functions - "S" & "G" What are they? | kablammo | BRZ First-Gen (2012+) -- General Topics | 59 | 12-01-2013 12:28 AM |
NEW Volk Racing TE37SL "Black Edition" Different finish, same low price! | Speed Element | Wheels and Tires | 19 | 07-19-2012 02:27 PM |
Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) | Hachiroku | BRZ First-Gen (2012+) -- General Topics | 67 | 11-09-2011 05:58 PM |
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" | JDMinc | Scion FR-S / Toyota 86 GT86 General Forum | 76 | 04-17-2010 03:58 AM |
