Software Tuning Discuss all software tuning topics. |
10-14-2014, 09:25 PM | #43 | |
Drives: FT86
http://datazap.me/u/steve99/test-sol...zoom=1767-2066 |
10-14-2014, 09:32 PM | #44 | |
Chronic Flashturbator
Drives: '13 Scion FR-S MT
Hmm well that clarifies a lot! I now know I have something that actually measures my AFR while in OL. That solid 11.25 AFR only solidified my uneducated assumption that it was a commanded AFR. In fact, my commanded AFR is probably exactly what is from the Open Loop Fueling Table! I will have the new log in the next 24hrs... er... Hopefully that commanded AFR reading is from OFT and not something else... Is this all a misunderstanding now? lol |
10-14-2014, 10:00 PM | #45 | |
Drives: FT86
AFR = measured AFR from front o2 sensor Wideband AFR = AFR measured by rear 02 sensor (calibration my be off as its for an Bosch Wideband o2 sensor (LSU4.2) with controller) Last edited by steve99; 10-22-2014 at 08:51 AM. |
The Following User Says Thank You to steve99 For This Useful Post: | BuBlake (10-14-2014) |
10-14-2014, 10:20 PM | #46 |
Drives: '13 BRZ Ltd
I've also seen threads like this
http://www.ft86club.com/forums/showthread.php?t=60225 That indicate the stock o2 is inaccurate under anything less than low 12's. So I'm not sure how much to believe the stock AFR numbers. Since the trims and AFR are fine in ranges where commanded is about low 12's, and since OFT commands afr's in the high 11's during OL, maybe it's just the inaccuracy of the stock o2 at afr's that low. Of course, that wouldn't explain why others are hitting afr targets in the high 11's. Hmm. |
10-14-2014, 10:28 PM | #47 |
I never looked for commanded AFR. I thought that the "AFR" output was doing double duty: showing commanded as well as measured depending on whether it was CL or OL. Now that I know the "AFR" output is purely measured and there is a separate output in logs for commanded AFR, this changes my game plan entirely!
10-14-2014, 11:01 PM | #48 | |
Seņor Member
1974 TA22 Celica
2013 86 GT |
10-14-2014, 11:53 PM | #49 | |
Drives: FR-S Whiteout
10-15-2014, 12:13 AM | #50 |
FA20club intake is the best, don't go back to the stock intake just because everyone else have seen the logs.
You know best.
10-15-2014, 07:18 AM | #51 | |
Drives: UK GT86
The AFR is the output from the front O2 sensor. It is still active in open loop, however it makes no compensations from what it reads. As far as the O2 effectiveness, it is more accurate (it seems) at higher AFRs but isn't bad at a ballpark figure. However, in the low 11s I would take it's reading with a pinch of salt.
.: Stealth 86 :.
10-15-2014, 01:06 PM | #52 | |
My logs are worse than I thought.. Looks like every WOT run I did in 3rd from 2k-7k rpm the AFR was dropping to <=11.25:1 consistently everywhere above 3.5k rpm. Probably just measuring too high of a CFM at >3v or so on the MAF scale... Is the excel spreadsheet even necessary? Isn't it possible to make a pretty good correction by just using common sense and the logs? |
10-15-2014, 04:33 PM | #53 | |
Drives: FT86
10-21-2014, 01:59 PM | #54 |
Awesome. Haven't had a chance to do anything but have a look at the utility yet. It has MAF scaling down to a science. Brilliant! haha I need to take care of an air leak on my exhaust first. Seems that all the backfiring has finally taken its toll and blown a seal somewhere around the catback.
10-21-2014, 03:55 PM | #55 |
Alright I used the utility and got a new curve. Love it! It is so well designed and easy to use. Even has in-program instructions.
The new curve adjusted to make it assume around 10% lower cfms per voltage above around 2.5v. Example: 280cfm at 5v corrected instead of the current 315cfm at 5v. Does this mean the Fa20club flows worse than the stock intake? Only problem I am having now is I cannot copy/paste the new curve into RR. I highlight the corrected mass flow cells in the scaler, ctrl+C, then highlight the mass flow in RR, ctrl+V and nothing happens. Seems like a fairly simple issue, but it's driving me out of my mind. lol (edit, figured it out.. derp!: just highlighted all corrected cells including voltages, then right clicked to select "copy romraider", then went to maf scale in RR and clicked edit/paste and all values were successfully implemented.) Going to flash the new file and see what happens now! Last edited by BuBlake; 10-21-2014 at 04:18 PM. |
10-21-2014, 04:58 PM | #56 |
Kid Gt86
Drives: SRT / Pulley / Tuned / Drop in
While using this tool I happened to come across this aswell.
The problem is that RR for some reason start with: [Selection1D] Instead of the actual numbers. My advice to you would be to use notepad. copy and paste the new numbers as follows: [Selection1D] 0.85 1.0025 1.1875 1.4024999999999999 From there just copy and paste to RR. Cheers |
The Following User Says Thank You to v86 For This Useful Post: | BuBlake (10-21-2014) |
Similar Threads | ||||
Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps | DeliciousTuning | Software Tuning | 1212 | 03-10-2023 11:07 PM |
Mann Engineering 2nd Quarter Tuning Days April 25th & 26th by Bill (Delicious Tuning) | DesertFrs | Northern California | 14 | 04-24-2014 03:15 AM |
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) | DeliciousTuning | Announcements, Contests, Giveaways | 6 | 09-19-2013 05:55 PM |
Visconti Tuning - Latest Forced Induction Tuning Info | Visconti | Forced Induction | 340 | 04-30-2013 06:33 PM |
2000 mile review, road trip to Road Atlanta & a chat with Randy Pobst. | Mtechnik | BRZ First-Gen (2012+) -- General Topics | 0 | 08-03-2012 11:07 AM |
