Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
08-04-2014, 03:36 AM | #1 |
Drives: '13 UM86
Stock wheels + Upgraded Tires vs. Wider wheels + upgraded tires
Lets say I want to stick with the stock wheels but upgrade to Super Sports (215/45ZR17)
Would I be at a huge disadvantage vs. getting an 8" - 8.5" wheel + super sports? How much slower would I be in a track or autoX setting? I know there is more grip/contact patch with a wider wheel/tire combo, but at what point is it a diminishing return? I don't want this to come off as a dumb question.... just want to know do I really NEED wider wheels if I have great preforming tires? And to spice things up a bit. Lets say I have Bilstein B8 + RCE Tarmacs on Stock Wheel w/ Super Sports vs. Bilstein B8 + RCE Tarmacs on 8.5" wheel w/ Super Sport How owned would I get on stock vs. the 8.5" (generally speaking) Last edited by themajesticone; 08-04-2014 at 03:47 AM. |
08-04-2014, 03:52 AM | #2 | |
Time Traveller
If you're going to be AutoXing, then wider is generally considered better. Get them as wide as you can. If you're staying on the street, then I'd look at cheaper (slightly less sticky) tires all around than PSS like BFG COMP2s, Direzza DZ102s, Hankook V12 Evo 2, etc. but that's me trying to save you money. |
The Following 2 Users Say Thank You to DAEMANO For This Useful Post: | themajesticone (08-04-2014), TJ3000 (08-04-2014) |
08-04-2014, 03:57 AM | #3 | |
Drives: '13 UM86
08-04-2014, 03:59 AM | #4 |
Time Traveller
I'd go RE-11A at stock width or go to a 225" section but nothing wider on stock power, brakes and suspension. That should be plenty of tire.
The Following User Says Thank You to DAEMANO For This Useful Post: | themajesticone (08-04-2014) |
08-04-2014, 04:02 AM | #5 |
Time Traveller
Hit up @ATL BRZ 's build thread, he tracked on RaceComp yellows + RE-11A's extensively before upgrading to RaceComp Tarmac 2s.
HERE http://www.ft86club.com/forums/showthread.php?t=13157 |
The Following 2 Users Say Thank You to DAEMANO For This Useful Post: | ATL BRZ (08-04-2014), themajesticone (08-04-2014) |
08-04-2014, 10:40 AM | #6 |
Drives: FRS
The bigger wheel, means more weight, and more expensive tires. On top of that, unless its the same compound, you can get the same grip with a lighter, cheaper setup.
The Following 2 Users Say Thank You to Firestorm_86 For This Useful Post: | themajesticone (08-04-2014), ZionsWrath (08-04-2014) |
08-04-2014, 11:15 AM | #7 |
Thanks
I just weighed my new wheel/tire
17x8 with 225/45 and on my super accurate nano technology 10 year old sister's bathroom scale 43.5 lb I believe stock is ~40.5 lbs I can weigh my stocks when I change brake pads tomorrow. (but not too accurate as they have some street and track time on them)
The Following User Says Thank You to ZionsWrath For This Useful Post: | themajesticone (08-04-2014) |
08-04-2014, 11:18 AM | #8 |
Drives: '13 UM86
08-04-2014, 11:19 AM | #9 |
Drives: ‘22 BRZ Limited
Stock size will be faster: http://www.roadandtrack.com/special-...transformation
08-04-2014, 11:22 AM | #10 |
Thanks
tirerack, they mount and balance free and for me close enough to drive and pick up so no shipping charge, just gas/time
08-04-2014, 11:50 AM | #11 | |
Drives: FRS
@themajesticone My wheels came from Vivid Racing, but I'd just as readily recommend CounterSpace Garage. Tires, I went with a local place that'll price match and has good service, but I used to use Costco. @ZionsWrath what wheels/tire are you running? Also, a word on wheels. You can go with the cheap stuff, but you'll likely pay for it in weight. You'll balance looks and performance. If you want both, it's $$$. You can go Rota, and get the same look, but you'll be hard pressed to get the same performance/weight. On the other hand, you can sell a kidney and get Volks. Inbetween, there's WedsSport, SSR, and Enkei, among many others. |
08-04-2014, 11:55 AM | #12 |
Thanks
17x8 +45 Enkei PF01
225/45 RE11A I haven't use them yet, I'm registered for track event on the 13. Waiting on brake pads to show up, I hope they fucking do lol
08-04-2014, 11:59 AM | #13 | |
Drives: FRS
The RE11's are too much tire (or not enough?) for my DD and mountain run uses. If I ever move back to a place where it doesn't get to freezing I'll run summers. |
The Following User Says Thank You to Firestorm_86 For This Useful Post: | ZionsWrath (08-04-2014) |
08-04-2014, 12:05 PM | #14 |
Thanks
BLAAACK
Similar Threads | ||||
Wider tires on stock wheels | buzznasa | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 30 | 01-21-2019 01:55 PM |
Upgraded to HRE wheels on our Turbo BRZ | Crawford Performance | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 28 | 04-03-2014 11:22 PM |
17” OZ Alleggerita wheels with stock 215/45-17 tires… 17x7.5 or 17x8 wheels? | SteveH | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 02-14-2013 10:26 PM |
Track Test: Edmunds 2013 Scion FR-S with Upgraded Wheels and Tires Pulls 1.0g! | poormans_LFA | Scion FR-S / Toyota 86 GT86 General Forum | 38 | 09-08-2012 12:46 AM |
Retaining driving dynamic with upgraded tires? - frs | nixeighty6 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 12-22-2011 01:44 AM |
