86SPEED
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Scion FR-S / Toyota 86 > Scion FR-S / Toyota 86 GT86 General Forum
Old 08-27-2012, 02:34 AM   #1
poormans_LFA
FT86Club.com O.G.
poormans_LFA's Avatar
Drives: Gunmetal Gundam Wing Zero Custom
Track Test: Edmunds 2013 Scion FR-S with Upgraded Wheels and Tires Pulls 1.0g!
Here's their write up since the upgrade:
VIDEO:
Inside Line tests hundreds of vehicles a year. Cars, trucks, SUVs, we run them all, and the numbers always tell a story. With that in mind we present "IL Track Tested," a quick rundown of all the data we collect at the track, along with comments direct from the test drivers. Enjoy.
It's been a goal since Day One with our 2013 Scion FR-S: Improve upon what the factory gave us. More importantly, do it in a way that doesn't detract from the car's inherent goodness. Our first step? New wheels and tires.
The idea behind changing the tires will be obvious to anyone who has spent time in an FR-S/BRZ — the stock tires limit the car's potential. We've often said there's more chassis than tire. So we set out to put this notion to the test.
We installed as wide a wheel-and-tire combo as possible on Project FR-S, subject to a few requirements. They had to fit under the stock fenders, retain a near-stock wheel offset, have stock rolling diameter (so as not to affect gearing), retain some sidewall for impact absorption and minimize the weight gain.
After careful calculations, we chose to replace the stock wheels and tires with Rays Volk Racing TE37SL wheels. They are the same diameter (17 inches) as the factory wheels, but 1.5 inches wider (8.5 inches compared to 7 inches). The forged Volk Racing wheels are also lighter at 16.2 pounds apiece (the stock wheels are 22 pounds each). Offset is 45mm compared to 48mm stock.
Picking tires was no easy task, but we settled on Yokohama Advan Neova AD08 sized 245/40 all around. These are far more aggressive summer tires than the stock Michelin Primacy HP tires, but more importantly they're still street tires, not overly aggressive R-compounds.
After some scrub in miles we headed for our test track to see how it would measure up against the stock setup. As you can see, the results were impressive. It stopped shorter, was easier to weave through the slalom and turned in a skid pad performance that is unprecedented for a car in this price range.
Keep in mind that these results were achieved with the stock alignment, and it is possible that grip and slalom speed could be improved further still with changes to the alignment.
Scion FR-S Scion FR-S Modified
0-30 (sec): 2.3 2.3
0-45 (sec): 4.2 4.2
0-60 (sec): 6.5 6.5
0-60 with 1-ft Rollout (sec): 6.2 6.2
0-75 (sec): 9.6 9.7
1/4-mile (sec @ mph): 14.8 @ 93.6 14.8 @ 93.7
30-0 (ft): 28 28
60-0 (ft): 114 107
Skid Pad Lateral Accel (g): 0.89 1.0
Slalom: 67.5 70.3
Vehicle: 2013 Scion FR-S
Odometer: 5,038
Date: 8-21-2012
Driver: Josh Jacquot
Price: $24,930
Specifications:
Drive Type: Rear-wheel drive
Transmission Type: Six-speed manual
Engine Type: Longitudinal, naturally aspirated flat-4
Displacement (cc/cu-in): 1,998/122
Redline (rpm): 7,400
Horsepower (hp @ rpm): 200 @ 7,000
Torque (lb-ft @ rpm): 151 @ 6,600
Brake Type (front): 11.7-inch vented discs with two-piston sliding calipers
Brake Type (rear): 11.5-inch discs with single-piston sliding calipers
Suspension Type (front): Independent MacPherson struts, coil springs, lower control arms, stabilizer bar
Suspension Type (rear): Independent multilink, coil springs, stabilizer bar
Tire Size (front): 245/40 R17 (91W)
Tire Size (rear): 245/40 R17 (91W)
Tire Brand: Yokohama
Tire Model: Advan Neova AD08
Wheel Size: 17-by-8.5 inches front and rear
Tire Type: Summer performance
As tested Curb Weight (lb): 2,737
Comments:
Acceleration: Additional grip changes launch technique slightly. Best launch was at 5,500 rpm. Tires hook up quicker and there's no real bog. Otherwise, nothing has changed from the original setup.
Braking: Definitely got better result here. Solid, consistent pedal feel. I suspect additional grip would mean dead brakes sooner on a track.
Handling:
Skid pad: At last, real grip! After several trial-and-error tire pressure experiments we settled at 38.5 psi when hot which produced the best feedback, response and balance.
We started the tires at 37.5 psi warm (street driving plus one lap of the pad in each direction after entering the speedway) because that's roughly where the tire shop left them — 35 psi cold, I presume. However, after five or six slalom passes they apparently warmed up even more — to 40 psi. After establishing both slalom and skid pad numbers at that pressure we dropped it — significantly. Went down to 34.5 psi. Did this for two reasons. First, we wanted to make a big enough change so that we could feel it. Second, 40 seemed way too high at this point.
At 34.5 psi hot there was significantly less response to steering input and the balance suffered on the pad. Understeer was more prominent and the car felt sluggish to come back from an understeering condition. Slalom times didn't change much but times around the pad slowed down measurably. It made the big change we were looking for, but it wasn't good. So we pumped them back up to 38.5 psi hot.
At 38.5 the skid pad times improved again and both response and feel were back. This seemed to be the sweet spot where both skid pad lap times and feel were the best so that's where I left it. From there, we experienced immense grip without compromise — very impressive for a wheel/tire swap.
Slalom: Feels marginally less tail happy compared to the stock trim. Confident in quick transitions and retains the excellent feedback of stock setup. Predictable, quick and fairly easy to drive here. First run was quicker than stock.
http://www.insideline.com/scion/fr-s...rack-test.html
I totally WANT these wheels now in this exact specification. The stock setup handles so well already. Want to stay close to that.
Article here:
Video:
http://bcove.me/6mhj9q2e
poormans_LFA is offline   Reply With Quote
The Following 17 Users Say Thank You to poormans_LFA For This Useful Post:
Akai (09-07-2012), Apex Chase (08-27-2012), Bonburner (08-27-2012), civicdrivr (09-06-2012), DjDATZ (09-08-2012), Guff (09-06-2012), Gums (09-07-2012), MarkRacerX (09-06-2012), RebootWindows (09-06-2012), RRnold (09-06-2012), Sigh-on-Rice (08-27-2012), Snoopyalien24 (09-06-2012), Symbiont (09-06-2012), TRD_07 (09-09-2012), tripjammer (09-07-2012), yayforaddison (09-07-2012), YukiHachiRoku (08-27-2012)
Old 08-27-2012, 01:04 PM   #2
vh_supra26
Drives: Supra
2013 Scion FR-S Track Test... pulls 1.0g!
0-30 (sec): 2.3 2.3
0-45 (sec): 4.2 4.2
0-60 (sec): 6.5 6.5
0-75 (sec): 9.6 9.7
30-0 (ft): 28 28
60-0 (ft): 114 107
Slalom: 67.5 70.3
Odometer: 5,038
Date: 8-21-2012
Price: $24,930
Specifications:
Comments:
Handling:
vh_supra26 is offline   Reply With Quote
The Following 8 Users Say Thank You to vh_supra26 For This Useful Post:
avusblue (09-06-2012), BRZranger (08-27-2012), Fly Guy (08-29-2012), RebootWindows (09-06-2012), RRnold (09-06-2012), Sigh-on-Rice (08-27-2012), tripjammer (09-07-2012), yayforaddison (09-07-2012)
Old 08-27-2012, 01:47 PM   #3
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Interesting results
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 08-27-2012, 01:50 PM   #4
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: FR-S Whiteout MT
Wow. 1.0 g!
Sigh-on-Rice is offline   Reply With Quote
Old 08-27-2012, 01:56 PM   #5
ill86
ill86's Avatar
Drives: iG FR-S
Originally Posted by Sigh-on-Rice View Post
Wow. 1.0 g!
Of course. Skid pad diameter plays a part though. Not taking anything away from the tire.
Old 08-27-2012, 01:59 PM   #6
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Without the numbers, this is what I found when going to 14.5lb 17x7s with 215 R-S3s. The level grip is amazing. I need numbers on how much G load I'm pulling
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 08-27-2012, 02:01 PM   #7
poormans_LFA
FT86Club.com O.G.
http://www.ft86club.com/forums/showthread.php?t=15739
The Following User Says Thank You to poormans_LFA For This Useful Post:
RRnold (09-06-2012)
Old 08-28-2012, 01:40 PM   #8
vh_supra26
Drives: Supra
^^^opps my bad. I guess could mods just merged or deleted thread. Thanks
Old 08-28-2012, 01:46 PM   #9
empower-auto
Kouki-Monster
empower-auto's Avatar
If someone wanted to absolutely dominate a skid pad test (high speed high g) on a DOT / street tire, what should they be looking at for gear?
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 08-28-2012, 02:09 PM   #10
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
So response and feel can change based on tire pressure?
SUB-FT86 is offline   Reply With Quote
Old 08-28-2012, 07:17 PM   #11
Kido1986
Dodging cones
Kido1986's Avatar
#1, good tires like R-S3s or Star Specs. #2 would be light, wider wheels. #3 would be quality coilovers. KWs or JRZs. To go more extreme, remove weight from the car.
Very much so. The same tire as 32 psi and 36 psi will feel much different in response. In autocross where you make short jogs, you use high pressure before higher pressure tires tend to turn in better than lower as they have less surface resistance. But too high will sacrifice a lot of grip so it's a balance. Every tire compound is different. On road course where you build up a lot of heat, run lower pressure since more heat adds more pressure. I start at 30-32 on my RS3s on track vs 35-36 on autocross.
The Following 2 Users Say Thank You to Kido1986 For This Useful Post:
RebootWindows (09-06-2012), Snoopyalien24 (09-06-2012)
Old 08-28-2012, 08:57 PM   #12
SpeedR
First86 / boat thief
Drives: MKIV Supra
nice very helpfull info
SpeedR is offline   Reply With Quote
Old 08-28-2012, 11:16 PM   #13
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
I don't put any faith into insideline 0-60 times or anything timed for that matter.
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 08-29-2012, 04:42 AM   #14
SuperDave
SuperDave's Avatar
Drives: DAT Rally Blue BRZ
nice wheels and tires. damn firestorm look so sexy...i sometimes wish i had it but i love rally blue too.
SuperDave is offline   Reply With Quote
Search this Thread:
Advanced Search
Widest Track tires for stock wheels?? track_warrior Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 56 10-11-2015 11:01 AM
2013 Scion FR-S Video Road Test vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 1 08-22-2012 03:53 PM
2013 Scion FR-S Full Test... brz_guy Scion FR-S / Toyota 86 GT86 General Forum 1 04-25-2012 03:28 AM
Retaining driving dynamic with upgraded tires? - frs nixeighty6 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 12-22-2011 02:44 AM
Road & Track Test Drive Review of 2013 Subaru BRZ Hachiroku Subaru BRZ General Forum 39 12-05-2011 10:45 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
