03-17-2014, 09:19 PM | #71 |
Drives: 13 Asphalt FRS AT
😀 thought about putting both on an a/b switch and having one of my maps with both disabled. Or I can just move over one county where emissions aren't a factor and property taxes are a fraction of what they are here.
Sent from my Nexus 7 using Tapatalk
The Following User Says Thank You to pixel67 For This Useful Post: | Sportsguy83 (03-17-2014) |
03-17-2014, 09:22 PM | #72 |
Has anyone tried using the ground wire from the OEM rear AF sensor? There is a 12v power which you can use for wideband / flex fuel already, using the ground would make wiring wonderfully easy.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
03-17-2014, 10:01 PM | #73 |
Automotive Connoisseur
Drives: too many cars
Interesting idea. The input could be switched between two different signals and then you would switch from one map to the other via cruise control for the correlating custom map. Suppose if you just set the min and max both to 0.1-4.9v (or whatever you want) you could still maintain the DTC associated with that one input just to have some diag if something goes wrong with that particular input (That's the way I like to set em up anyway). I would be curious to see how this worked in practice. I am also in need of an additional input so perhaps I will give this a go and see how it reacts to a switched input while running and switching maps.
LSx Powered 86/ASE Master Certified Automotive Technician
03-17-2014, 10:26 PM | #74 |
Drives: 2JZ FRS
The visconti v2 flex fuel kit uses power/ground/ecu input from the rear o2 plug for the flex sensor. Works fine on my car. Made for a real easy install. Just one connection to plug in on the car itself
The Following User Says Thank You to spitfire481 For This Useful Post: | Sportsguy83 (03-17-2014) |
03-17-2014, 10:32 PM | #75 |
blowhard
Drives: frs, project forester
Now, assuming this was set up with plugs it could be reversible in a few minutes going back to the stock o2 sensor at inspection/emissions time right?
03-17-2014, 10:36 PM | #76 |
I Love custom Turbo kits
Drives: Limited BRZ
Correct.
03-17-2014, 10:47 PM | #77 | |
03-19-2014, 11:46 PM | #78 |
Drives: Limited BRZ
Took log tonight. Mine was at 4.49 V, so really on point.
04-06-2014, 05:51 AM | #79 |
Drives: Toyota 86
Are you guys leaving the stock rear o2 sensor in place, or did you remove it so that you can hook up the wideband to that secondary o2 bung?
04-06-2014, 07:59 AM | #80 |
Drives: Limited BRZ
I have a third bung welded on my Overpipe for the Wideband O2 but you can remove the rear O2 and install your wideband O2 in its place.
The Following User Says Thank You to Sportsguy83 For This Useful Post: | HRTROB (04-06-2014) |
04-06-2014, 10:36 AM | #81 |
Drives: 2023 WRB BRZ (MT)
04-06-2014, 10:51 AM | #82 | |
Drives: Limited BRZ
Sent from my SM-N900A using Tapatalk
04-06-2014, 11:13 AM | #83 |
Grip>Slip
anyone know where one could find the male end of the secondary o2 harness to make for a plug and play install? Would like to tidy up some wiring and that would be a big help.
The Following User Says Thank You to xjohnx For This Useful Post: | Ryan P (04-06-2014) |
04-06-2014, 11:33 AM | #84 |
Drives: Limited BRZ
It's a long shot, but Visconti and Moto Mike get them so they now where from... Now getting that info from them.....
Similar Threads | ||||
BRZ Front and Rear LED Turn Signal Bulbs | convoy | Cosmetic Modification (Interior/Exterior/Lighting) | 23 | 11-25-2013 07:51 AM |
Aftermarket Rear Diffuser | Realm | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 05-08-2013 11:23 PM |
FS: BNIB Concept Three LED Amber/White signal bulbs Front and Rear with Relay | xxscaxx | Exterior Parts (Aero, Lighting, Etc.) | 10 | 03-27-2013 10:17 AM |
DIY: front and rear LED turn signal bulbs | jjdrivesajazz | DIY (Do-It-Yourself) Guides | 6 | 10-15-2012 09:53 PM |
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** | Titanmotorsports | Audio/Visual, Electronics, Infotainment, NAV | 2 | 09-14-2012 12:42 PM |
