Brian@Vortech
Old 04-17-2013, 10:53 PM   #295
Sonolin
Originally Posted by swift996 View Post
I'm hoping some people can make a safe 270-280 whp on 93 octane...if so I'll be all over one, still waiting to see some tuner developments but I like how things are progressing. I'd love the power curve of a PD or a turbo, but above all I want something safe and less to maintain.
Same here!
Sonolin is offline   Reply With Quote
Old 04-18-2013, 12:34 AM   #296
Sithspawn
Drives: '14 Hot Lava FR-S w/Flappy Paddles
Originally Posted by Sonolin View Post
I'm curious about this speculation - if this kit can max out ~20psi, why isn't there a smaller pulley available?
My impressions were that the current smallest pulley available by Vortech, which I think is 12psi, is the max.
Just inquiring, and I could have definitely read that wrong (read: I'm not a mechanic and don't know much if anything about this stuff). If this kit can handle 20psi then that would be great. My dillemma is that I want a F/I kit that comes ~250 whp stock, but with the ability to push past that if needed (maybe 300-350whp with possibly e85). Right now its mostly a waiting game to see if this is possible, but I'd like to hear more about the upper limits of this system
Thanks guys, this system is looking great so far. Definitely impressed with Vortech's customer service & the results I've seen so far.
Just because the smallest pulley Vortech makes will do 12psi, doesn't mean you can't make a smaller one.
If the map is any indication of the max revs of this unit, it can spin to 55k rpm. How long the bearings can continuously be spun to that rpm is a different question.
Another possible limiting factor to making the theoretical maximum power is pressure drop in the system. Even if the supercharger unit itself is working at a given pressure ratio of 2.35, you may not be seeing that 20psi of boost in the intake manifold. In that case, the supercharger would be consuming the power required for it to produce that pressure ratio but the engine wouldn't actually be seeing that pressure. Therefore, you wouldn't see the power you were expecting. You would then need to find the restriction(s) and get rid of it/them if you are looking to max out the system. Keep in mind the law of diminishing returns though...it could require a lot of R&D and upgraded parts to eliminate all the restrictions and ultimately not be worth the trouble for a few extra ponies. I'm sure someone will find a way though...people always want more.
Just remember, Vortech designed their system to improve performance, meet emissions and be relatively safe and reliable. Pushing the envelope beyond their intended design will involve extra cost and risk of failure.
Sithspawn is offline   Reply With Quote
The Following 4 Users Say Thank You to Sithspawn For This Useful Post:
Brian@Vortech (04-18-2013), Mnoland9 (04-18-2013), RedAlert (04-18-2013), sw20kosh (04-18-2013)
Old 03-16-2014, 06:37 PM   #297
zenny
Drives: brz 2013
is it possible to hit 400-500 on these kits with e85 i can upgrade impeller to if thats an option pm me for pricing
zenny is offline   Reply With Quote
Old 03-16-2014, 06:51 PM   #298
nelsmar
With the engine oil fed unit 400-500 is obtainable on E85. Close to 400WHP has been had on E85 without over-spinning the self-oiled unit.
My flickr - Canibeat
Local magazine scout
Old 03-16-2014, 10:58 PM   #299
zenny
Drives: brz 2013
what would i need to hit 400 and what if i wanted more?
i have vortech 9psi
perrin font cat pipe soon to be cut off for no cat
perrin over pipe
borla uel soon to be el
and perrin 3 inch exhaust unresonated
perrin lightwieght pulley
what am i missing
Old 03-16-2014, 11:05 PM   #300
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
i have vortech 9psi
perrin over pipe
what am i missing
2.87 pulley, e85, fuel pump, minimum 540cc injectors and a good tune
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 03-16-2014, 11:47 PM   #301
jack43
jack43's Avatar
Drives: Sterling Silver BRZ Limited MT
Sorry about adding some obvious stuff:
clutch
cooling mods: new radiator, oil cooler
catch can
engine mounts + tranny support & bushings
gauges incl wideband if possible
axles (according to some folks but not me so far)
Lastly you might be surprised about the wheelspin even on sticky tires. With 255 or 265mm at the most without rolling the fenders, 1st gear is very Dukes of Hazzard.
jack43 is offline   Reply With Quote
Old 03-17-2014, 12:04 AM   #302
zenny
Drives: brz 2013
clutch
catch can
ya ill be doing all those after im done getting the power so i know that they work just how i am lol
Old 03-17-2014, 12:19 AM   #303
nelsmar
With good tuner 3.00" pulley might work, this is an 8 RIB though. But @evo4g63 is spot on. 3.00 could possibly tap roughly 380-410WHP on a dynojet with a good tune and a nice free flowing exhaust. if you want more power 2.87 can work but is pushing the blower past its limits and you may want to consider doing the race upgrade (engine oil fed) to sustain the 2.87 or go even lower. A number of users however have been using the 2.87 for a period of time and I don't know if anyone has had any issues as of yet. @Brian@Vortech would have to fill us in on that subject if anyone has damaged one from over spinning it with that pulley yet.
The Following 2 Users Say Thank You to nelsmar For This Useful Post:
Cal3000 (03-17-2014), evo4g63 (03-17-2014)
Old 03-18-2014, 10:47 AM   #304
STS-V
What about those of us that dont live in E85 areas?
STS-V is offline   Reply With Quote
Old 03-18-2014, 02:38 PM   #305
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
Long term 2.87" here. Been running it since day one.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
The Following User Says Thank You to AZFA20 For This Useful Post:
nelsmar (03-18-2014)
Old 03-18-2014, 05:58 PM   #306
jack43
jack43's Avatar
@kiichiro or anyone else do you have a wastegate setup?
I am tempted to go oil-fed and 2.6" but would like to have some control over boost at different revs & in different conditions.
Old 03-18-2014, 10:12 PM   #307
Suko
Drives: 2014 subaru brz
Since you guys are partnered with Vishnu will the new set up be the one included in the openflash 300 setup?
Suko is offline   Reply With Quote
Old 03-18-2014, 11:48 PM   #308
nelsmar
the "new" setup has been the only setup. There are however two setups. A standard and a race version. The race version uses oil fed from the engine and can rev higher than the standard unit. The standard unit will probably work for 98% of people as it his quite a bit of overhead on it. Upwards of 400WHP on E85 can be achieved with the standard unit. However OFT currently doesn't support non MAF based tuning so there is a tuning limitation. This post is about vortech switching the actual blower as the original unit was different on the original release. I don't know of anyone that has had the original unit as they offered to replace anyone who had the original with the new one.
Questions and Discussion on Vortech Supercharging Systems Brian@Vortech Forced Induction 1462 01-27-2017 02:05 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
aFe Power/Takeda Air Intake System and Exhaust aFePower Engine, Exhaust, Bolt-Ons 10 08-06-2012 03:03 PM
