Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
08-04-2013, 06:45 PM | #15 | |
Drives: 2023 WRB BRZ (MT)
also the reverse signal from Acc. is that the red wire with silver on it that u tap into for reverse camera power |
08-04-2013, 11:15 PM | #16 |
Drives: 2013 Subaru BR-Z Limited
That's not the reverse signal wire. That's accessory power.
08-04-2013, 11:44 PM | #17 |
got it working. my relay had the NO and COM ports switched and i didnt realize it at 1st. but once that was solved it works perfectly
The Following User Says Thank You to lbroskee For This Useful Post: | MmmDieselFumes (08-12-2013) |
08-12-2013, 12:23 PM | #18 |
Drives: .
08-12-2013, 12:27 PM | #19 |
Yup. I used a regular A/V switch box instead of the 2 relay setup tho, but on/off switch works perfectly. Thanks for the great diagram. Audio is the only snnoying part
08-12-2013, 02:05 PM | #20 |
Drives: .
Good deal, glad they helped! Wasn't sure if they'd be understandable to anyone else lol.
Out of curiosity, what'd you wind up hooking up to the new input? I'm sure I could draw up another diagram if you're wanting audio. If you want to test something for me, try playing some music (ipod/phone) through the AUX cord while in AUX mode, and see if it still plays while it's in "reverse-mode". |
The Following User Says Thank You to MmmDieselFumes For This Useful Post: | lbroskee (08-12-2013) |
08-12-2013, 02:16 PM | #21 |
Drives: .
Also, which A/V switch did you use? I'll draw up another diagram showing that option as well.
08-12-2013, 05:03 PM | #22 | |
well for audio i was jus gonna use 1 of those things that link to a blank radio station because on BeSpoke there is no AUX (the port is only used with iphones and that stupid cable they give you for the video/pandora/ipod), but audio on all sources never cuts out. as of now it's for my SNES and maybe a DVD player. have yet to test anything in quality over SNES other then my old macbook, but that looks crappy on a TV as for A/V i used this from RadioShack. I keep it on A for the camera and B for whatever else. $18 so cheaper then all the relays, switch, and wiring i would need and imma jus velcro it to the inner top of the glove box so i can take it out if i wanna change something |
08-13-2013, 07:10 PM | #23 | |
08-13-2013, 11:05 PM | #24 |
ya i know. i saw the diagram... pretty straight forward, but the switcher was 18 and the relays and switch alone are almost that much. then theres the wire taps and all the time itll take to set it up. i just dont feel like going thru all that for now at least. audio still sucks tho bc i have to stream it
Similar Threads | ||||
So where will the fog light switch go... | Asphalt | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 04-08-2019 07:09 PM |
Brake switch adjustment ? | photomike | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 02-20-2013 01:49 AM |
Switch Back LEDs for BRZ | DNAPoPo | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 02-07-2013 08:11 PM |
86 centre switch cover | Ryan86 | AFRICA | 47 | 12-06-2012 12:23 PM |
Anyone going to switch badges? | DougieFresh | Scion FR-S / Toyota 86 GT86 General Forum | 60 | 09-28-2011 02:56 AM |
