follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 2
1
2
Showing results 1 to 30 of 36
Search took
0.43
seconds.
Search:
Posts Made By:
T0rt0r0
Forum:
Tracking / Autocross / HPDE / Drifting
10-26-2023, 03:55 PM
21
low grip/low stress track tire setup?
3,033
Posted By
dave99rt
The pressure drops happen to quickly for someone...
The pressure drops happen to quickly for someone to lift throttle and it matter.
It would happen in a turn. You aren't just going to lift in the middle of a turn when pulling 1.0+ g.
It seems...
Forum:
DIY (Do-It-Yourself) Guides
10-10-2023, 12:07 PM
301
Official FT86Club 3D printing thread!
136,185
Posted By
DocWalt
Whipped up a quick rain tray design and added it...
Whipped up a quick rain tray design and added it to the folders in the link above :)
https://i.postimg.cc/0NPMHvjR/370226027-7465926226767760-2576328562574619968-n.png
Forum:
04-06-2023, 11:03 PM
2
Independent washer/wiper control
1,209
Posted By
Luns
The wiper/washer controls of cars I've owned seem to have made progressively less sense over the years.
With my '94 Corolla, pulling the stalk will run the washer (just the washer, only the...
Forum:
Member's Car Journals
09-17-2022, 05:31 AM
403
Joel's BRZ - Low Budget Time Attack Build
111,325
Posted By
DIY
Some more work on the firewall replacement today....
Some more work on the firewall replacement today. I have now finished cutting and bending all the sheet metal so now it's just a matter of welding it all in place.
Forum:
07-14-2022, 11:03 PM
403
111,325
Posted By
DIY
Just a small update for you guys. I have...
I have mocked up the replacement firewall using cardboard templates. Removed the engine and now I am busy transferring those templates over to sheet metal to be...
Forum:
05-01-2022, 06:15 AM
403
111,325
Posted By
DIY
Some small updates for you guys. I've been...
Some small updates for you guys. I've been working on the oil and fuel tanks and getting them mounted in the car.
The dry sump oil tank is just an off the shelf item I imported from the UK. I did...
Forum:
03-07-2022, 04:06 AM
403
111,325
Posted By
DIY
A bit of an update on some of the smaller jobs...
A bit of an update on some of the smaller jobs I've been doing.
I have replaced all the rod end spacers in the suspension with a much better design that now fits perfectly between the mounting...
Forum:
05-03-2021, 08:25 AM
403
111,325
Posted By
DIY
The transmission mount is now finished so the...
The transmission mount is now finished so the engine and trans are 100% in the chassis.
Here is what it took to finish it off.
Start by cutting out some 5mm thick flat bar and drilling a hole...
Forum:
Software Tuning
03-29-2021, 01:52 PM
10
Getting the ECU to quickly learn idle stability after a reflash
4,557
Posted By
Compelica
Figured that it would be applicable to post this here in the Software Tuning section as we deal with these issues more often.
After a reflash the ECU takes some time to relearn fuel trims, and...
Forum:
Engine Swaps
10-24-2020, 04:19 PM
1,305
Another V8 Swap
323,603
Posted By
DustinS
Well I haven't been on in way too long. Lots has...
Well I haven't been on in way too long. Lots has happened. Tore down the LS and eventually sold it and have gone head first into the 2jz swap. Building the engine myself this time so I only have...
Forum:
Engine, Exhaust, Transmission
05-26-2020, 12:06 AM
80
OEM Oil Cooler Kit and Installation DIY
42,816
Posted By
N_Raged
https://www.ft86club.com/forums/showpost.php?p=329...
https://www.ft86club.com/forums/showpost.php?p=3293911&postcount=3
Forum:
05-25-2020, 09:26 AM
80
42,816
Posted By
T-Steve
Agreed. I bypassed the throttle body on my '14...
Agreed. I bypassed the throttle body on my '14 about four years ago and have had no problems in temperatures as low as 0 F.
(Incidentally I did the same mod to my Forester as well with no...
Forum:
Engine Swaps
05-25-2020, 12:21 AM
186
Veldin's 2014 Subaru BRZ gets a 2JZ.
88,079
Posted By
Clash0901
You may very well be right, but this car will...
You may very well be right, but this car will rarely see miles put on it so I don't imagine it fading quickly. Plus I looked it over and it really looks nice. And it was recommended to me by a friend...
Forum:
05-24-2020, 01:10 PM
80
42,816
Posted By
86TOYO2k17
It’s only purpose is to warm up the TB when it’s...
It’s only purpose is to warm up the TB when it’s below freezing and you park outside. Otherwise the 190f+ coolant will heat soak the TB, a lot of people just delete it from the loop. It isn’t going...
Forum:
Issues | Warranty | Recalls / TSB
04-11-2020, 04:32 PM
6
Seat squeaking
1,941
Posted By
Hmmm......good thought, I hadn't thought about...
Hmmm......good thought, I hadn't thought about the air bag - :iono:
"Saddle soap" is a cleaner/conditioner that used to be used on leather products like boots and saddles. Saddle is to a horse as...
Forum:
04-11-2020, 03:09 PM
6
Seat squeaking
1,941
Posted By
Well, you might try some silicone spray. ...
Well, you might try some silicone spray. However, the soapy water might disperse a bit further. - :iono:
Bubba also suggests injecting saddle soap - get it, "saddle" soap - :D
Forum:
04-11-2020, 12:36 AM
6
Seat squeaking
1,941
Posted By
Bubba says to mix up a soapy water solution, fill...
Bubba says to mix up a soapy water solution, fill up a syringe and inject the soapy water into the seat where it is squeaking and work it in.
humfrz for Bubba
Forum:
03-02-2020, 09:42 PM
0
DIY Plug & Play Strobing Third Tail Light For Cheap
5,309
Posted By
caballo_glue
This is my first DIY How To on this forum so please forgive any annoying formatting issues.
DISCLAIMER: I claim no responsibility for breaking anything. This is what I did and it worked for me. I...
Forum:
Electronics | Audio | NAV | Infotainment
01-26-2020, 02:47 AM
6
Third brake light connectors
1,617
Posted By
EndlessAzure
They should look like this one ...
https://www.easternbeaver.com/Main/Elec__Products/Connectors/TS090/ts090.html
Here's an image from the light on my car. Notice that the keying is on the left...
Forum:
01-22-2020, 11:52 AM
380
Sticky:
Official Component Weights & Weight Reduction Thread
392,715
Posted By
ML
Just wanted to share some work I did with the...
Just wanted to share some work I did with the center console to save some weight.
184268
184269
Forum:
01-16-2020, 10:34 AM
6
1,617
Posted By
EndlessAzure
Sumitomo/Yazaki 090 II Series, Unsealed, Two pin ...
I believe the one on the car is keyed. You'll have to find one that has matching key orientation or grind the keying notch off
Forum:
01-15-2020, 05:01 PM
6
1,617
Posted By
tarzan_nojane
The small blade connectors (both male and...
The small blade connectors (both male and female), are standard pieces available at the local electronics shop. Was able to leave the factory wiring untouched and add the appropriate connectors to...
Forum:
Software Tuning
12-12-2019, 03:33 PM
46
Car runs terrible after switching from OFT to ECUTEK
9,778
Posted By
tomm.brz
Yes if you disconnect battery for a while, ecu...
Yes if you disconnect battery for a while, ecu kind of reset and vvt will take longer to activate
The hotter engine oil is, the shorter it takes
Even if you just reset DTC will do the same
Forum:
10-14-2019, 05:16 PM
5
Dash/firewall creak
1,896
Posted By
norcalpb
This ended up being the pillow ball bearing in my...
This ended up being the pillow ball bearing in my camber plates.
The main bearing was smacking against its races whenever I would hit any kind of bump.
Forum:
09-01-2019, 11:16 AM
107
FRS/BRZ EPS Motor Coupler Replacement (Rattle Fix)
86,520
Posted By
ermax
I updated the original post to include a link to...
I updated the original post to include a link to the OEM coupler. Toyota doesn’t sell this as an individual part for our car but luckily they have other cars which use the exact same coupler so we...
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
03-20-2019, 10:34 PM
144
Electric Power Steering (EPS) noisy
64,045
Posted By
ermax
HRTROB is our savior! It freaking worked. It’s a 100% fix. It’s like a whole new car now. Man I can’t thank Rob enough for discovering that this Hyundai coupler is nearly a perfect fit. Just like Rob...
Forum:
03-17-2019, 11:49 AM
144
64,045
Posted By
ermax
Yeah I figured you wouldn’t be in a rush to put...
Yeah I figured you wouldn’t be in a rush to put your original EPS back in the car seeing how your used replacement fixed your noise. I just placed an order for this rubber part. It should be here...
Forum:
03-16-2019, 01:52 AM
144
64,045
Posted By
HRTROB
I just got the Hyundai bushing today. It’s a...
I just got the Hyundai bushing today. It’s a perfect fit on the joints but there is some trimming that still needs to be done. The worm side of the joint has a protruding area in the center and...
Forum:
02-16-2019, 01:19 PM
144
64,045
Posted By
ermax
Making progress. When you pop this cap off it looks exactly like the other Toyota EPS units. My first experiment was to cut a wedge out of wood and then drive it up in there between the bearing and...
Forum:
02-15-2019, 12:55 PM
144
64,045
Posted By
ermax
Is this the rubber you are referring to? ...
https://i.imgur.com/E8SYUoF.png
I found a video talking about this problem on the Corolla. Unfortunately it's in Russian and doesn't translate well. From...
Page 1 of 2
1
2
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
09:33 AM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
