Old 05-30-2022, 01:54 AM   #379
DIY
DIY's Avatar
Drives: BRZ, WRX
Speaking of DIY, yesterday I made this adaptor to mount my Bosch DBW throttle body to the new intake manifold.
It turned out pretty neat and now I can finish making the cold side tube to connect it to the intercooler.
Follow me on Instagram: @brzdiy
My Build Thread
DIY is offline   Reply With Quote
The Following 6 Users Say Thank You to DIY For This Useful Post:
ballsdeep (07-20-2022), DustinS (10-22-2022), Irace86.2.0 (05-31-2022), jflogerzi (05-30-2022), RedReplicant (11-20-2022), Wally86 (11-21-2022)
Old 05-30-2022, 08:20 AM   #380
SuperTom
SuperTom's Avatar
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
Originally Posted by jflogerzi View Post
Low Budget cause he is doing all the work himself which leave room for quality parts.
Oh I get it. I wouldnt have half the mods on my car if I was paying someone to do the work.
Joel the intake looks amazing by the way
SuperTom is offline   Reply With Quote
The Following User Says Thank You to SuperTom For This Useful Post:
DIY (05-30-2022)
Old 05-30-2022, 09:18 PM   #381
RuyGuy2
Dysentery Enthusiast
RuyGuy2's Avatar
Drives: 2017 toyota 86
I really just can't wait to see this thing on a track somewhere. I'm in awe of your commitment and investment of time into your car.
RuyGuy2 is offline   Reply With Quote
The Following User Says Thank You to RuyGuy2 For This Useful Post:
DIY (05-30-2022)
Old 05-31-2022, 02:57 AM   #382
ballsdeep
ballsdeep's Avatar
Drives: Ocho-Seis
Epic build, the role model for all K series swaps!
Do you have a clever idea for a cold air intake or airbox??
ballsdeep is offline   Reply With Quote
Old 05-31-2022, 05:16 AM   #383
DIY
DIY's Avatar
Drives: BRZ, WRX
Thanks mate.
I haven't put these photos up on here yet but I already have made a 4" pipe going into the turbo, I had to use some tight radius bends to clear the steering linkage. On the other end will be a large pod filter inside some kind of box that will take fresh air from the front bumper.
My Build Thread
The Following 4 Users Say Thank You to DIY For This Useful Post:
Aroundomaha (06-05-2022), Irace86.2.0 (06-07-2022), RToyo86 (04-01-2023), Wally86 (11-21-2022)
Old 05-31-2022, 09:23 AM   #384
Wrecky_Flowers_
Wrecky_Flowers_'s Avatar
Drives: '02 S2000; '22 GR86
What valve cover is that? Loving this build!
Wrecky_Flowers_ is offline   Reply With Quote
Old 05-31-2022, 07:54 PM   #385
DIY
DIY's Avatar
Drives: BRZ, WRX
It is actually the standard K24 cover but I cut it up and welded it back together to replicate the Honda HPD covers.
My Build Thread
Old 06-09-2022, 02:46 AM   #386
DIY
DIY's Avatar
Drives: BRZ, WRX
I have finished all the intercooler and turbo plumbing now.
Part of the reason I changed to a center feed intake manifold is that it moves the throttle body away from the front of the engine and as you can see in the photo below I now have unrestricted space behind the radiator for a fully ducted hood exit.
Next thing I'm doing is to replace the firewall in the engine bay. I've bought some big sheets of cardboard for making templates, then I will have to remove the engine and weld in the sheet metal based off those cardboard templates.
This video is a pretty good overview of where the car is at now
https://www.instagram.com/tv/CedWQES..._web_copy_link
My Build Thread
The Following 8 Users Say Thank You to DIY For This Useful Post:
Ash_89 (07-16-2022), Busybee (08-20-2022), Code Monkey (06-09-2022), Irace86.2.0 (06-11-2022), RedReplicant (11-20-2022), RToyo86 (04-01-2023), TheBoss77 (06-09-2022), Wally86 (11-21-2022)
Old 07-14-2022, 11:03 PM   #387
DIY
DIY's Avatar
Drives: BRZ, WRX
Just a small update for you guys.
I have mocked up the replacement firewall using cardboard templates. Removed the engine and now I am busy transferring those templates over to sheet metal to be welded into the car.
Removing the engine is fast and easy with the way I have designed everything.
My Build Thread
The Following 14 Users Say Thank You to DIY For This Useful Post:
AgentBlue243 (07-19-2022), Ash_89 (07-16-2022), ballsdeep (07-20-2022), Busybee (08-20-2022), Code Monkey (07-15-2022), H380 (07-15-2022), Irace86.2.0 (07-18-2022), Kiske (07-17-2022), Racecomp Engineering (07-16-2022), RedReplicant (11-20-2022), RToyo86 (07-15-2022), T0rt0r0 (07-15-2022), TheBoss77 (07-15-2022), Wally86 (11-21-2022)
Old 08-20-2022, 07:56 PM   #388
DIY
DIY's Avatar
Drives: BRZ, WRX
I've had a bit of a break from working on the car but yesterday I spent the day turning my cardboard templates into a steel firewall. I don't really have much experience working with sheet metal and I don't have any tools for it either but I'm pretty happy with how this is coming together.
Just a video of the process for now, I'll get some photos once everything is complete.
https://www.instagram.com/reel/CheY7...d=MDJmNzVkMjY=
My Build Thread
The Following 2 Users Say Thank You to DIY For This Useful Post:
Busybee (08-20-2022), Wally86 (08-22-2022)
Old 09-17-2022, 05:31 AM   #389
DIY
DIY's Avatar
Drives: BRZ, WRX
Some more work on the firewall replacement today. I have now finished cutting and bending all the sheet metal so now it's just a matter of welding it all in place.
I ended up using more than one piece of sheet metal to do the tunnel replacement, simply because it's easier to manipulate smaller pieces rather than one big complex shape.
I found that even if my cardboard template fits perfectly there was no guarantee I would be able to make the steel bend in the same way, at least with my skills anyway.
My Build Thread
Ash_89 (10-20-2022), Busybee (10-20-2022), gt5759 (09-19-2022), Jdmjunkie (09-17-2022), RedReplicant (09-17-2022), T0rt0r0 (09-19-2022)
Old 10-20-2022, 03:26 AM   #390
DIY
DIY's Avatar
Drives: BRZ, WRX
Time for an update.
The firewall is finished. If you are late to the game the reason for the new firewall was that I am allowed to move the motor back 51mm behind the original firewall under the WTAC rules.
The original firewall was cut out, the engine was mounted in its permanent position, cardboard templates where made with the engine in place and then a new firewall was made based on those templates.
I used a plug weld technique to attach the new sheet metal basically mimicking the original construction. It was a lot of drilling around all of the perimeters. I used a weld-through primer on the back side before doing the plug welds with my MIG.
After welding there was a lot of grinding with a flap disc to give a smooth finish but I think it came up really good.
The whole lot has been primed now to prevent any surface rust while the build continues.
Here is a video of the inside and out
https://www.instagram.com/reel/Cjw7d..._web_copy_link
With the firewall finished I am moving on with the front pushrod suspension. I have purchased all the rod ends and bearings for the bellcranks and pushrods. A friend at work has been putting my bellcrank design into Fusion360 so we can first 3D print the bellcranks for testing and mounting and then later have them CNC machined from aluminium.
My Build Thread
The Following 12 Users Say Thank You to DIY For This Useful Post:
AgentBlue243 (10-25-2022), Ash_89 (10-20-2022), Busybee (10-20-2022), Code Monkey (10-20-2022), gt5759 (10-20-2022), Irace86.2.0 (10-21-2022), jay_reef15 (10-20-2022), Jdmjunkie (10-20-2022), ML (10-20-2022), RToyo86 (11-21-2022), villainous_frx (10-20-2022), Wally86 (11-21-2022)
Old 10-30-2022, 06:33 AM   #391
DIY
DIY's Avatar
Drives: BRZ, WRX
A little streamlining of the wheel well exits to help the air evacuate. After doing all that sheet metal work on the firewall I figured now was the perfect time to finish this job.
Both sides came out really nice.
My Build Thread
AgentBlue243 (10-30-2022), Busybee (04-03-2023), Code Monkey (10-30-2022), DustinS (10-31-2022), gt5759 (11-03-2022), ML (10-30-2022), RToyo86 (04-01-2023), Wally86 (11-21-2022)
Old 11-20-2022, 07:25 PM   #392
DIY
DIY's Avatar
Drives: BRZ, WRX
I have been working on the front pushrod suspension. The design I made for the bellcranks have been transferred into CAD software and then 3D printed by my friend at work. This allows me to fabricate shock mounts and bellcrank mounts on the main frame rail and also the pushrod mounts on the lower control arms.
Some revisions will be made and this is the beauty of 3D printing them first but eventually they will be CNC machined from aluminium alloy.
My Build Thread
AgentBlue243 (11-20-2022), Busybee (04-03-2023), Code Monkey (11-20-2022), DustinS (11-21-2022), Dzmitry (11-22-2022), gt5759 (11-21-2022), Irace86.2.0 (11-24-2022), Jdmjunkie (11-20-2022), RedReplicant (11-20-2022), RToyo86 (11-21-2022), Takumi788 (11-21-2022), Wally86 (11-21-2022)
