Old 01-12-2016, 09:43 PM   #1
Dacfrs
Drives: Reddy Whip
0W-30 Oil
Just wondering if any club members have run heavier weight oil in their cars. I do a lot of hi-way driving (80 mph @ 3500 rpm)...live in the midwest, winters can be somewhat brutal. 0w-30 just seems like it would be a better choice?
Dacfrs is offline   Reply With Quote
Old 01-12-2016, 09:57 PM   #2
http://www.ft86club.com/forums/forumdisplay.php?f=41
Old 01-12-2016, 10:27 PM   #3
stevesnj
stevesnj's Avatar
My 2016 Build thread
Old 01-12-2016, 10:29 PM   #4
JB86'd
JB86'd's Avatar
Drives: JAWS
Yeah you should run heavier oil for a colder climate.
/sarcasm
Old 01-13-2016, 10:28 AM   #5
bluesubie
Highway driving is the easiest on an engine, even if you are going 80. In most temps, say from freezing and above, a 0W30 will usually be thicker than the 0W20. But when it gets to freezing and well below, the cold cranking viscosity on both oils is tested at -35C.
PQIA Cold Crank Viscosity
Of course at operating temp, the 0W-30 will be thicker than the 0W-20, but possibly not by very much. You have thick xW-20's and thin xW-30's and the operational viscosity may or may not be that different. The second number on the bottle represents a viscosity range.
That said, 0W-20's do very well in these cars if you are stock and are not on a race track.
bluesubie is offline   Reply With Quote
