Old 01-12-2016, 03:48 PM   #1
knopper91
Drives: 13 FRS
Stop flywheel from moving? (automatic)
I need to somehow, seize the flywheel so I can change the crank pulley. The new pulley is the Kartboy, so the crank tool isnt an option. Any help?
knopper91 is offline   Reply With Quote
Old 01-12-2016, 04:32 PM   #2
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Hi. welcome.
Not super relevant, but you don't have a flywheel. It's an automatic. You have a torque converter and a flexplate.
A few solutions for you:
If you have the crank tool, use it to get the stock pulley off. If you don't, be creative.
If you need to jam the motor in place, you can pop the starter off and use something to jam the ring gear. It's attached to the flexplate in your car, and would be attached to a flywheel if you had one. I wouldn't do that, but it's what came to mind.
Otherwise, I recommend you use the tool to remove the stock pulley, put the kartboy pulley on, and tighten the pulley most of the way... The motor doesn't turn over that easy. after that, the pulley will be held in a fixed postion relative to the crankshaft (by the keyway in the back of the crank spacer and the key pin in the front).. use a big strap wrench (the rubber ones for oil filters) to hold the crank shaft pulley in place while you torque the bolt.
If you don't like either of those suggestions, you could pull the transmission entirely, unmount the torque converter, and grab a flexplate bolt with a socket. The torque converter mounting bolts will not work as they are rear-facing and turn the wrong way for what you are doing, so it'll be a bit of a process.
Oh, and I have one suggestion that's even worse than all of those. You're going to hate it. Hell, I hate it, but it involves throwing out the torque setting and using a impact wrench to tighten it, as the wrench will deliver torque faster than the crank and rotating assembly can comply. It'll be tight... I'm only suggesting that for a laugh. Please don't do it. But hell, I don't see a great reason to do the mod in the first place, I'm just helping. I'll leave my opinion out of it.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following User Says Thank You to Spartarus For This Useful Post:
wparsons (01-12-2016)
Using handbrake with automatic gt86 and other issues with the automatic version Tommygt86 Scion FR-S / Toyota 86 GT86 General Forum 9 04-06-2015 04:42 AM
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate PineappleFriedRice Transmission and Driveline 0 11-08-2013 04:54 PM
Moving to Tx brz007 Southwest 3 08-26-2013 09:47 PM
Tips to stop stuff from moving around in the trunk Stu L Tissimus Cosmetic Modification (Interior/Exterior/Lighting) 8 06-02-2013 08:42 PM
Automatic Shuddering when slowing to stop Craig Issues | Warranty | Recalls / TSB 0 11-14-2012 06:40 PM
