Old 01-12-2016, 06:03 AM   #1
nphillip
nphillip's Avatar
LEDs gone out on the Valenti's
Currently using the Valenti tail lights, I have 2 brake LEDs and 2 indicator LEDs go out. I've had the lights for about a year now.
Does anyone know what sort of bulbs they are so I can have them replaced? Or will I need to replace the whole LED light strip which I assume will not be possible to find.
Cheers.
nphillip is offline   Reply With Quote
Old 01-12-2016, 08:51 AM   #2
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I would contact your dealer if you bought new.
Old 01-12-2016, 09:28 AM   #3
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Cheers.
This is the main reason I've been holding back on the valentis, burned out LEDs. The only real fix would be to bake open the tailight if you're really electrically savvy and replace the LED with ones you can find. The only other fix works if you have a good reputation with your vendor and they will do a warranty replacement.
Old 01-12-2016, 12:19 PM   #4
slyphen
Drives: Man
Send a message via AIM to slyphen Send a message via Yahoo to slyphen
i remember first generation of these had a lot of problems with burnt out LEDs. the newer generation has fixed this issue. perhaps you got one of the older stocks?
slyphen is offline   Reply With Quote
Old 01-12-2016, 12:23 PM   #5
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
well at least that didn't happen
fumanchu1 is offline   Reply With Quote
The Following User Says Thank You to fumanchu1 For This Useful Post:
soulreapersteve (01-12-2016)
Old 01-12-2016, 05:26 PM   #6
nphillip
nphillip's Avatar
When I first received the lights I noticed a minor chip on the side of one of them. I contacted the vendor but they ignored my emails. I didn't bother too much after sending them about 3 emails because the chip wasn't that bad.
I've had the lights for a year now so the chances are this vendor def won't do sh*t.
I guess I'll look into other tail light options now, I've been wanting to swap them out anyway. I guess I have a reason to now.
Old 01-12-2016, 05:38 PM   #7
zc06_kisstherain
Drives: SWP BRZ
post that vendor to vendor review section so other members dont get ripped off
Old 01-12-2016, 05:44 PM   #8
DAEMANO
Time Traveller
...ok I'll do it...
He said Valenti not Visconti! >rimshot!<
The Following User Says Thank You to DAEMANO For This Useful Post:
Ultramaroon (01-16-2016)
Old 01-12-2016, 05:45 PM   #9
stevesnj
stevesnj's Avatar
Contact Valenti direct, complain how one of their retailers is ignoring you and say you want a replacement. You're the customer, this product is faulty, you have the upper hand.
My 2016 Build thread
Old 01-12-2016, 05:51 PM   #10
fumanchu1
I know just like trolling and visconti was close enough
Sent from my SGH-M919V using Tapatalk
Old 01-15-2016, 12:47 AM   #11
Zhangy
Drives: 2015 FRS
The thing about LED is that they are best not used in an enclosure, because heat shortens their life.
Zhangy is offline   Reply With Quote
Old 01-15-2016, 01:39 AM   #12
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
So, to repair do you individually change or is it a strip? Cant find a DIY section... thats whats stopping me from buying.
Packofcrows is offline   Reply With Quote
Old 01-15-2016, 07:06 PM   #13
extrashaky
Drives: 2014 BRZ Limited
It's probably the driver. LEDs are powered by a little circuit board. The LEDs themselves don't throw off a lot of IR heat, but the driver boards do produce heat. If you seal them up in an enclosure with nowhere for that heat to go, the driver boards will cook themselves. If you leave a chimney for the heat to escape, water gets in them. There's no really good solution other than to use high quality drivers and fewer LEDs rather than trying to light the car up like a Christmas tree. The Valentis probably go out in groups like they do because a single driver is running multiple LEDs.
A bunch of builders in Florida jumped on the LED bandwagon and installed LED street lamps and parking lot lights, which promptly failed. Since they were off during the day, they were cool enough for seagulls to perch on. The seagulls shit all over the heat sinks on top so that they overheated at night and cooked the boards.
The Following 3 Users Say Thank You to extrashaky For This Useful Post:
chaoskaze (01-16-2016), Tcoat (01-16-2016), Ultramaroon (01-16-2016)
Old 01-15-2016, 08:45 PM   #14
Packofcrows
So in other words, no matter how I buy them, the LED's will sh!t on me eventually compared to oem ones?
If they only lasted me 3yrs w/o issues id consider them.... Guess maybe TOM's are in my future?
The Following User Says Thank You to Packofcrows For This Useful Post:
Tcoat (01-16-2016)
