Old 01-08-2016, 12:13 PM   #1
Tor
Tor's Avatar
Drives: Toyota GT86
Is this a camber adjustable crash bolt or a regular?
I pulled a wheel for the first time since I bought the car a year ago. I took some pictures since I plan to do a coilover upgrade.
I am puzzled why the top bold is a different color. Did my predecessor install camber bolts, or does it look like this stock?
Tor is offline   Reply With Quote
Old 01-08-2016, 12:19 PM   #2
Cole
Not a troll
Cole's Avatar
You could mark the bolt head and the strut (so you keep adjustment) and take it out to check...
Old 01-08-2016, 12:26 PM   #3
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Both of mine are silver. It's a 2015.
jawn is offline   Reply With Quote
Old 01-08-2016, 12:30 PM   #4
Tor
Tor's Avatar
Drives: Toyota GT86
Yes I put the wheel back on and it's dark here now. But I found I took a picture from the other side. :doh:
It's just the normal bolt where the black pain has peeled off. Probably just had an alignment at some point. *Phew*, got worried for a second, after all it's called a CRASH bolt.
Anyway, sorry for wasting your time.
Old 01-08-2016, 01:24 PM   #5
Nickosport
Drives: 2015 WRB BRZ Premium
All the aftermarket camber bolts I've seen for this car have a logo on the head, except for Subaru OE crash bolts. Whats funny is that all of the aftermarket ones i've seen have SPC on them, even the Whiteline ones straight from the package. I guess they are probably easy to buy and rebrand.
2015 WRB BRZ - Nameless - Raceseng - Eibach - Whiteline - Cusco - Perrin
Nickosport is offline   Reply With Quote
Old 01-08-2016, 03:57 PM   #6
ansibe
Drives: White BRZ
How can I get a set of Subaru OE camber (!) bolts? Does anyone know the PN and cost?
I've heard the Whiteline bolts corrode quickly, is there any truth to that?
ansibe is offline   Reply With Quote
Old 01-08-2016, 05:22 PM   #7
strat61caster
strat61caster's Avatar
My whiteline/spc bolts have been on for a year and ~15k of DD miles and they look flawless, came off a few weeks ago with minimal effort.
But, California means no snow and minimal muddy crappy roads so take it with(out) a grain of salt.
Googling got me this P/N:
901000394
http://parts.subaru.com/p/Subaru_201...901000394.html
IMO, I like the cam on the spc bolts for adjustment purposes, with the OE bolt it's undersized and you're just pushing the upright/strut around and tightening it and hoping it's good, then you do the other side, check both, fix the one that's off, repeat. I'd only run the OE crash bolt if a ruleset required it (like the CS or stock classes in some competitive groups).
Edit: Also this thread:
http://www.ft86club.com/forums/showthread.php?t=22201
ineedyourdiddly
Old 01-11-2016, 12:26 AM   #8
Ashikabi
Ashikabi's Avatar
If you're doing coils you should have camber plates so you won't need camber bolts unless you want some crazy camber up front
:popcorn:, tagz and things
FS: 14mm camber (crash) bolt frslee Brakes, Suspension, Chassis 1 05-06-2015 10:32 AM
Adjustable Camber Arms vs. Whiteline Camber Bushings digital_assassin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 70 06-02-2013 06:06 AM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 12:19 PM
