Old 01-01-2016, 06:21 PM   #1
stevesnj
stevesnj's Avatar
Antenna Delete no Weld Version with Carbon Plaque
So I hate the look of the antenna on the roof, just think it ruins the fine shape of this car... anyway I used a Carbon Fiber Console Plaque. It was meant for that purpose but I changed a design. So I bought the center plaque from http://www.innovateddynamics.com/pro...-holder-plaque
For $15 it is a steal. It's hand made to order. So I decided to give it a try using it to use as a cover for the hole well it worked. I plan to paint it when the weather outside allows as I do not have a garage. So it can be very easy or slightly difficult. Easy version, remove old antenna, clean area the size of the plaque use 3M DS tape and add silicone sealant around the rectangular hole for peace of mind and done!
For even more peace of mind I epoxied a 3/4" long 1/4-20 thread cut off a bolt. This takes more time and I secure it with a flat washer and wing nut. Overkill but I'd rather make sure it doesn't fly off. But tape should be fine.
I will upload more detailed pics later but here's the result before I paint it this spring. I have the simple install instructions in my build thread page 12
My 2016 Build thread
Old 01-01-2016, 06:42 PM   #2
Cole
Not a troll
Cole's Avatar
Haha. You think the antenna ruins the lines of the car so you stick a rectangular piece of metal on there that doesn't sit flush? Logic.
The Following 3 Users Say Thank You to Cole For This Useful Post:
FRSBRZGT86FAN (01-02-2016), go_a_way1 (01-01-2016), hmong337 (01-02-2016)
Old 01-01-2016, 07:00 PM   #3
DIM
Sorry that looks terrible IMO.
DIM is offline   Reply With Quote
The Following 4 Users Say Thank You to DIM For This Useful Post:
FRSBRZGT86FAN (01-02-2016), go_a_way1 (01-01-2016), hmong337 (01-02-2016), stevesnj (01-01-2016)
Old 01-01-2016, 07:04 PM   #4
stevesnj
stevesnj's Avatar
If welding and painting was $15 I'd do that. Lol. This is not the best way but the best I could figure out that is cost effective.
Old 01-01-2016, 07:04 PM   #5
stevesnj
stevesnj's Avatar
You're so good looking!!
Old 01-01-2016, 07:20 PM   #6
stevesnj
stevesnj's Avatar
Originally Posted by new2subaru View Post
My guess is you wouldn't be a big fan of these
Nah I'll pass. :]
The Following User Says Thank You to stevesnj For This Useful Post:
new2subaru (01-01-2016)
Old 01-01-2016, 07:56 PM   #7
JoeC
Drives: Subaru BRZ Limited
If the objective was to remove the antennae and cover the hole, it looks like a success. But aesthetically speaking, the solution does not look good.
JoeC is offline   Reply With Quote
Old 01-01-2016, 08:03 PM   #8
stevesnj
stevesnj's Avatar
Actually I don't use the radio so this is a win win. I don't like the sharkfin antenna and I needed to cover the hole. I looked for some type of plug but couldn't find anything. I would wanted something smaller but there is nothing out there and welding and repaint is the best alternative which i don't have the $$ to spend on a hole. It accomplished my goal but to me it looks 100% better than the sharkfin.
JoeC (01-01-2016)
Old 01-01-2016, 08:33 PM   #9
D_Thissen
D_Thissen's Avatar
OP as long as you're happy, that's all that matters. Unfortunately this is a public forum so when you post something like this, you will get opinions from others. Some of those opinions may disagree with yours. Its your car, as long as you like it
The Following 2 Users Say Thank You to D_Thissen For This Useful Post:
FRSBRZGT86FAN (01-02-2016), Phantobe (01-02-2016)
Old 01-01-2016, 08:55 PM   #10
stevesnj
stevesnj's Avatar
Thank's, yeh I don't take offence, I let them speak their minds it doesn't bother me. Thanks!
Old 01-01-2016, 09:02 PM   #11
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Ok I will bite.
Or you could just vinyl wrap the whole roof?? Personally I dont like the whole wrap thing but at least it wont be such an eye sore. Wrap can be had cheap and you can install yourself.
Cole (01-01-2016)
Old 01-01-2016, 09:06 PM   #12
stevesnj
stevesnj's Avatar
Ok I will bite.
I thought about wrap also but being a 1x1 1/2" hole it seems expensive to do that for a hole. This is much less of an eyesore than that hunk of plastic jutting out of th roof..lol Thanks man
Old 01-01-2016, 09:14 PM   #13
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
You can buy enough to do the whole roof for $25 off ebay I bet haha. Yeah each to his own, to be totally honest I hate the stock antenna as well, and dislike my sharkfin but I live with it for now. Oneday I might have to hole filled and roof painted.
Old 01-02-2016, 02:13 PM   #14
8R6
8R6's Avatar
Drives: FRS
Ok I will bite.
if you do only vinyl and wrap the roof, the hole area will still be visible as that part will "sink" in compared to the rest of the roof. plus the vinyl will be so thin that if anything scratches it or even if theres enough air pressure, it'll puncture and make a hole.
8R6 is offline   Reply With Quote
***NEW***Beatsonic Version 2 Sharkfin Antenna FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 29 03-27-2016 04:32 PM
FS: Beatsonic Sharkfin Antenna - Sterling Silver/Argento FDA9 (Version 2) chermo12 Canada Classifieds 3 06-02-2015 08:45 AM
"86" Dash Plaque - VG Shark fin antenna - Hot Lava seven Interior Parts (Incl. Lighting) 3 04-16-2013 11:24 PM
VG Shark fin antenna - Hot Lava - "86" Dash Plaque seven Exterior Parts (Aero, Lighting, Etc.) 1 04-16-2013 11:24 PM
1st 86 Final Gift : Carbon look Coin Tray badge, Plaque, FR-S Book, CNC Aluminum Box MarkRacerX Interior Parts (Incl. Lighting) 3 12-14-2012 12:30 PM
