Old 12-30-2015, 12:16 AM   #1
Slo_frs
Slo_frs's Avatar
Drives: Racecar
Center console measurements
Can somebody tell me the measurements of the center console where someone would put the plaque my car is in the body shop and im trying to mock up some fighter pilot switches for fog lights
Slo_frs is offline   Reply With Quote
Old 12-30-2015, 12:25 AM   #2
lukey86
Built Not Bought
lukey86's Avatar
Drives: 2012 Toyota 86 ZN6
60mm x 75mm
lukey86 is offline   Reply With Quote
Old 12-30-2015, 12:28 AM   #3
humfrz
About a fat 2.25" x 4.0".
6.0 x 10.0 mm (roughly)
On my 2013 FR-S
humfrz
Old 12-30-2015, 12:45 AM   #4
lukey86
Built Not Bought
lukey86's Avatar
On my 2013 FR-S
humfrz
Hmm mine's only 75mm on my 2012 86, a weird thing to be different sizes across models
Old 12-30-2015, 12:47 AM   #5
Slo_frs
Slo_frs's Avatar
Drives: Racecar
Thank you 👍🏾
Old 12-30-2015, 12:48 AM   #6
Slo_frs
Slo_frs's Avatar
Drives: Racecar
Hmmmm thats weird i dont think there would be a different from 13 to 16 maybe the usdm ones are different?
Old 12-30-2015, 12:52 AM   #7
humfrz
Originally Posted by Slo_frs View Post
Thank you ����
Wait up, @Slo_frs ...... someone is measuring the wrong thing .....
Exactly, what do you want measured .. ??
humfrz
Old 12-30-2015, 12:59 AM   #8
Slo_frs
Slo_frs's Avatar
Drives: Racecar
Yeah lol i need the center console the little rectangle things thats empty i think it differs in the country's i need the usa one lol
Old 12-30-2015, 01:02 AM   #9
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
If you want exact measurements of the fillet radius as well as sizing and such I could probably cut a template out tomorrow on accucadd if I get time.
Old 12-30-2015, 01:04 AM   #10
humfrz
OK, I'll go with the 60mm x 75mm.
My bad!
UGH - ask an old, half blind man, to go out to a cold, dark garage and measure anything ...... will get you iffy results (let alone trying a conversion) .......
humfrz
Cole (12-30-2015), lukey86 (12-30-2015)
Old 12-30-2015, 01:07 AM   #11
lukey86
Built Not Bought
lukey86's Avatar
In this thread the general consensus is 3" x 2 3/8"
http://www.ft86club.com/forums/showthread.php?t=35840
All of the plaques I've seen available make no mention of different sizes for different applications
Old 12-30-2015, 01:16 AM   #12
Slo_frs
Slo_frs's Avatar
Drives: Racecar
That'd be amazing!
Old 12-30-2015, 12:39 PM   #13
Th3rdSun
Drives: 2013 FR-S MT Hot Lava
I've made quite a few plaques here at work with the laser cutter we have. different thicknesses of materials have a slightly different dimension.Also,I switch between CorelDraw and AI.http://www.ft86club.com/forums/showt...onsole+plaques
If you are using CorelDraw,I've found that 3x2.365 with a corner radius of 31(my version of Corel,for some reason uses whole numbers instead of decimals) works pretty well,but that was for 1/4 inch acrylic.
I've done engrave stock that's .06 inches thick,and I've used a size of 2.35x2.95 with
In AI,I used .3 for the corners,but I think it should be closer to .325. I will have to find my measurements again.
Th3rdSun is offline   Reply With Quote
Old 12-30-2015, 12:43 PM   #14
FRSBRZGT86FAN
Coreldraw and AI were dope back in high school, our engineering teacher gave us free reign with the laser cutting table and it taught us alot, the same went for the 3d printers. Most school today don't do that I believe.
My idea for a center arm rest / console cover / center cup holder ravenblackfrs Cosmetic Modification (Interior/Exterior/Lighting) 67 02-13-2016 04:00 PM
need help on jpm center console Jhon19lopez Cosmetic Modification (Interior/Exterior/Lighting) 4 06-24-2013 08:57 PM
red center console? gusbarragan Cosmetic Modification (Interior/Exterior/Lighting) 13 02-19-2013 09:03 PM
Center Console help mbh1101 Cosmetic Modification (Interior/Exterior/Lighting) 2 08-22-2012 10:56 AM
Center Console encity5 Electronics | Audio | NAV | Infotainment 1 06-10-2012 10:22 AM
