Old 12-28-2015, 06:06 PM   #1
msmont
Drives: 2013 Suburu BRZ
Where is the fuze for the rear amp
I have a 2014 BRZ Limited with the Fujitsu 10 radio. I am doing a sub and amp in the trunk. I am just taking my time over the holiday break and doing things slowly so I've taken the spare tire, styrofoam, etc out of the trunk. Routed my new 4 gauge wire from the battery to my new amp. I unhooked the radio just to look behind it and also unplugged the harness for the stock amp in the back and then plugged it back in. Went to start my car and the door speakers aren't coming on, radio itself and other speakers are fine. I double checked that harness for the stock amp is fully plugged in, same with all the harnesses on the back of the radio. I think I probably blew the fuze for the stock amp. Where is the fuze for that thing? I checked the manual on the fuzes on the kick panel and the ones in the engine bay and none of them sound like they are for the amp. There is a 7.5 fuze for the radio, but the radio itself turns on fine.
msmont is offline   Reply With Quote
Old 12-28-2015, 06:34 PM   #2
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
It's not the one that's highlighted. It's on the bottom right in that picture - 15a
murdoc is offline   Reply With Quote
Old 12-28-2015, 07:17 PM   #3
msmont
Ah yes, those tricky bastards labeled the one for the amp as "amp". It was blown too. For some reason in my mind when I went over the list I sort of read that as an extra fuse for some reason.
USDM - Rear foglight indicator in cluster? Trying to do a quality rear fog light inst nalc Cosmetic Modification (Interior/Exterior/Lighting) 8 12-10-2015 04:48 PM
Installed Rear Roof Visor and replica STi style Rear Spat wrb Cosmetic Modification (Interior/Exterior/Lighting) 11 10-13-2014 07:51 PM
system not recognizing my Sansa Fuze MP3 pantdino Electronics | Audio | NAV | Infotainment 2 07-27-2014 04:16 PM
Free-Rear bumper cover (entire rear facia) replaced after slight rear-end collision n7011n Exterior Parts (Aero, Lighting, Etc.) 7 03-26-2014 04:46 AM
WTB: REAR window top Brake Light (just top half with leds) or full rear deck Kayzer Soze Exterior Parts (Aero, Lighting, Etc.) 1 08-31-2013 02:23 PM
