Old 12-23-2015, 05:40 PM   #1
Astroboy
Astroboy's Avatar
Drives: None
Torque specs on exedy stg 2 clutch?
I recently ordered an exedy stage 2 clutch for my frs and am wondering what the torque specs are for when I install it. Which bolts require torque specs that I need to look out for, and how much are they. I know I am going to need to remove the shifter, and remove remove the starter if necessary I believe. But if I remove the starter, would I need to tighten it at a certain spec? Also, when i re bolt the transmission back on the block, will i need to torque it down at a curtain spec? I know for sure the clutch and clutch disk need to be torqued down, but at what spec? Thanks
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
Exedy Clutch KAR Engine, Exhaust, Transmission 28 01-03-2016 07:27 PM
FX300/FX350 Clutch or Exedy Stage 1/2 Clutch? bren5279 Engine, Exhaust, Transmission 8 09-22-2015 10:36 AM
OEM Exedy clutch on backorder radroach Engine, Exhaust, Transmission 1 03-13-2015 11:30 AM
Anyone know the wheel specs on the exedy toyota 86? JasonCDC Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-09-2013 02:33 PM
Exedy BRZ specs sheet ayau BRZ Photos, Videos, Wallpapers, Gallery Forum 2 11-07-2012 09:56 PM
