| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2015 Subaru BRZ Series.Blue CWS
1320 Performance Headers Review
Anyone with the 1320 headers have any reviews on them?
![]() 1320 Performance Headers & Overpipe | HKS Hi-Power Spec-L Catback Exhaust | Delicious Tuning Flex Fuel Kit | Delicious Tuning Stage 2 Tune | Tein Flex A Coilovers | 20 & 25 MM Spacers |
Drives: CWP 2015 BRZ Stock
I have a friend of mine that's running the 1320 in his FRS. He likes to Rev it out and has taken it to the mountains a few times, so he drives it pretty hard. He hasn't had any issues with it. He did use the grimmspeed gaskets for the install as well. I'm looking to get one soon.
I just installed my headers on my BRZ and have a problem with the header to overpipe gasket. I put a grimspeed one but it doesn't seem to fit flush and created an exhaust leak. Not sure what to do. Can't get it flush any way I try.
#4 | |
I got the 1320 overpipe and it fits flush but the gasket almost seems too thin because there is a leak. Ask him if he just used one or two please!
He didn't get the 1320 overpipe, but he did only use one gasket between the overpipe and header. You might need to do some fine tuning to make it work. If push comes to shove, then use two and hopefully that would work
Drives: 14' Firestorm FR-S
I'm the friend with the 1320 header. I installed header, then over pipe, then front pipe in that order.
I made sure the the header/op fit correct before bolting back up the oem front pipe. Idk if when installed with the front pipe on make its harder to line up the over pipe or what, but that's the way I did it and I haven't had any issues yet. Sent from my SM-G900V using Tapatalk |
Drives: '22 BRZ
I'm pretty against the Grimmspeed gaskets on any connection on our car as I've had them leak like crazy for no reason... I'd recommend using a Remflex 6005 instead. Requires the holes to be modified slightly to fit, but no leaks.
#10 |
I'm starting to believe that, the groom speed are a perfect fit, yet when I tighten everything down I still have a leak in the gasket will still move in between the flanges
#11 |
Lol grim speed**
#12 | |
#13 |
No I Took it directly from the bag I received it and put it between the pipes and tightened it up. When I started up the car I still got a slight leak from the pipe. I just used a universal 2.5 gasket from grimspeed
#14 | |
After that, if it still isnt fixed, its time to check the flanges and make sure they are not warped or anything. |
| 1320 Performance UEL Header? | Ronin Sascha | Engine, Exhaust, Transmission | 53 | 06-27-2018 06:39 AM |
| 1320 uel header, opinions? | Mr_YUzU_FRS | Engine, Exhaust, Transmission | 2 | 09-30-2015 06:00 PM |
| Headers RS performance | paoness | Engine, Exhaust, Transmission | 2 | 04-06-2015 04:41 PM |
| Lachute performance headers! | grostoine | Engine, Exhaust, Transmission | 0 | 04-23-2013 07:05 PM |
| Lachute Performance Headers | Cotnoir | Engine, Exhaust, Transmission | 54 | 08-02-2012 10:23 PM |
