Drives: 2014 Scion FR-S Monogram (Whiteout)
Did I screw up Shark Fin install?
So I just got a shark fin that had no instructions. The installation itself went fine, but I just realized I installed it on a newly waxed car. I didn't clean off the wax and this thing has a lot of adhesive. What are the chances it'll fall off?
And yes I'm an idiot. |
| The Following User Says Thank You to iNcontroL For This Useful Post: | Tcoat (12-21-2015) |
Drives: Subaru BRZ Limited
I think you'll be fine. Don't worry about it.
Not Bаnned Anymore
Drives: Heavily Modified FRS
In before totalled
you should be fine, check it in a few weeks |
Drives: 2013 Subaru brz limited
If i remember correctly it does have to be cleaned off of all chemicals for the "best results" but it should be fine if you can apply a good amount of pressure to the wing and it doesnt move. Just cross your fingers when your on the highway
Drives: 2013 Firestorm FR-S AT
If its a Beatsonic its on forever. If it's one of those cheap Chinese Alibaba or eBay fins then when you hit 60MPH it's going to fly off and embed itself in the windshield of the car behind you.
Seriously, most that can happen is that it will lift slightly. Too late, but you should have used IPA (isopropyl alcohol) to clean the area first. |
Drives: Asphalt 2013 FR-S
worse comes to worse you get to spend an hour cleaning the old tape off, reapplying new tape, and then properly placing it on
Drives: 2014 Scion FRS
just double sided tape... ive taken mine off a few times with no problems using the same tape over again...
| TCS screw size | pseudo | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 09-22-2014 08:51 AM |
| Lost a screw... | Kody | Issues | Warranty | Recalls / TSB | 8 | 04-25-2014 04:31 PM |
| Is the car dealership trying to screw me? | revil | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 03-07-2014 05:14 PM |
| Beat-sonic JDM shark fin antenna install. | jadewbj | Cosmetic Modification (Interior/Exterior/Lighting) | 23 | 05-23-2013 01:12 AM |
| What is this screw for? | chenshuo | BRZ First-Gen (2012+) — General Topics | 13 | 02-17-2013 10:15 AM |
