Old 12-17-2015, 01:50 PM   #1
KennethTheJet
Drives: 2014 Raven Scion FRS
I can't find any wheels with the same specs as mine!
Hey guys! I just need some quick help/recommendations on tires.
I have a set of 18x8+30 fronts and 18x9+30 rears coming in. I was thinking about a 225/40/18 in the front and a 245/35/18 in the rears. With that set up, would I need to roll my fenders? Would I have any clearance issues? Hopefully someone can help. Thanks for all the help guys!
BTW I am sitting on TRD Springs which I don't know the official drop.
KennethTheJet is offline   Reply With Quote
Old 12-17-2015, 01:52 PM   #2
strat61caster
strat61caster's Avatar
http://www.ft86club.com/forums/forumdisplay.php?f=24
http://www.ft86club.com/forums/showthread.php?t=15007
http://www.ft86club.com/forums/showthread.php?t=7535
ineedyourdiddly
JohnJuan (12-17-2015)
Old 12-17-2015, 01:55 PM   #3
8R6
8R6's Avatar
Drives: FRS
do you at least have camber bolts up front? the front wheels/tires will poke out from the fender at stock 0 camber and look goofy. camber bolts will help gain around -1 deg of camber to make it better fitting/looking and handling even.
8R6 is offline   Reply With Quote
Old 12-17-2015, 02:16 PM   #4
KennethTheJet
I actually don't have any camber bolts.. I was hoping to stay stock with everything other than the springs, but it's tough with an aggressive offset.
Old 12-17-2015, 02:23 PM   #5
8R6
8R6's Avatar
Drives: FRS
camber bolts are only like $30. you can even install them yourself really easily at home. then just take it to a good alignment shop and done.
Old 12-17-2015, 02:36 PM   #6
KennethTheJet
Yeah I've seen a couple for like $25-$30. So basically, it'll work with the wheels and tires, but with a bit too much poke and it looks stupid/goofy.
Old 12-18-2015, 08:58 AM   #7
Ashikabi
Ashikabi's Avatar
Get camber bolts. Or better yet coil overs. Let the modding begin!
245/40/17 ZII Star Specs on OEM Wheels..Need advice please ButteR Tracking / Autocross / HPDE / Drifting 9 03-23-2015 02:39 AM
Specs on PRS BRZ Wheels Bach415 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 12-01-2014 01:54 PM
Can't find wheels in the size I want PoWn3d_0704 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-09-2014 07:33 PM
JRP- New Wheels from Enkei w/Dunlop Star Specs ready to roll!! Stav Canada Classifieds 6 05-02-2013 07:31 PM
Not mine, but now it is (aka, another "got mine" thread) brianbot5000 Northwest 2 07-01-2012 01:50 PM
