Old 12-14-2015, 05:13 PM   #1
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
3D Printer Arduino Case
I made this little case here to hold an Arduino Uno, a 4xAA battery case, a momentary pushbutton, and a standard 16x2 OLED screen. I couldn't find one out there I liked that had a place for a battery box, so I made this one.
Hope someone else here can find it useful! The STL files are attached in the zip file below.
Jake
GSpeed is offline   Reply With Quote
Old 12-14-2015, 05:36 PM   #2
philooo
Drives: 13' Scion FRS Track car
what kind of printer do you have ? I am asking because I know you guys make some serious research so I figured you picked a good one
philooo is offline   Reply With Quote
Old 12-14-2015, 05:46 PM   #3
srizzors25
Daedalus Moto
srizzors25's Avatar
Good looking case man! Looks like your printer has pretty decent resolution which is nice. The tricky part now is trying to actually thread screws in there... good lucky trying to pull that lid off more than once!
if you put some helicoil inserts in the base for the screws to go into, you'll be in good shape. did that a bunch at my last job works great!
Old 12-14-2015, 10:13 PM   #4
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
One I designed and made. 18" x 18" x 18" build volume, heated bed, E3Dv6 hotend with Bulldog XL extruder, Smoothieboard controller. It's working pretty well so far! I've printed two uprights in the past week. Took forever, but the Smoothieboard did GREAT. I've used one for the past two years or so, and I really can't recommend it enough.
Thanks. I need to buy some plastic threading screws, I've used those with some success too.
Jake
3D printer ideas for the toyobaru mechaghost Cosmetic Modification (Interior/Exterior/Lighting) 82 09-03-2017 08:00 AM
Arduino Gauge, Looking for Colab Akya2120 DIY (Do-It-Yourself) Guides 29 09-20-2016 01:15 PM
Dashlinq4 and Arduino: LED Control System nickw14 Electronics | Audio | NAV | Infotainment 6 01-05-2015 02:31 PM
Anyone local with a 3d printer? m.box.design Northwest 7 11-10-2013 03:07 AM
anyone have a 3d printer? Xdragonxb0i Cosmetic Modification (Interior/Exterior/Lighting) 8 01-25-2013 06:51 PM
