Drives: 2015 Turbo FR-S
Clutch Recommendations
I'm looking into clutch options for the FI setup I'm putting together. I'll be runnning 10psi on the SBD kit - 275 to 300 WHP (no more than 225-250 ft-lbs) is the target.
I've looked into the heavier-duty Exedy as well as ACT clutches, but I've seen a few negative issues in regard to both on this forum. Currently it looks like the best choice will be the Exedy Stage 1. Can anyone recommend a clutch that will be suitable for my purposes, that hopefully isn't going to give me trouble? Thanks!! Last edited by FirestormFlex; 12-14-2015 at 08:54 AM. |
Drives: Rb25 neo brz
It all depends on how similar you want the clutch to be to the stock feel, if your alright with an aggressive clutch grab i'd go with the ACT XT
Im ok with something more aggressive as long as it's still driveable. Any thoughts on the ACT XT street disk vs the 6 puck?
The drive-ability of the 6 puck at least in my opinion is not friendly at all even with the streetlite flywheel its not an easy drive so i'd go with the Streetlite and the HD disk. Anything above that skip right over to the exedy twin disk
Drives: 2013 FRS / 2013 427 Vert
I've had the ACT 6 puck for several months now and it gets smoother over time. I track the car monthly and usually drive it to work a couple times per week often in slow crawl traffic. Occasionally it acts up at a stop, the clutch releases abruptly, sometimes resulting in a stall. When this happens the shift to second gear has to be forced but then no more issues after that shift.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
| Need clutch installed - recommendations | midnight23 | Southern California | 2 | 08-07-2013 09:37 PM |
| Clutch recommendations | ngabdala | Engine, Exhaust, Transmission | 0 | 12-03-2012 08:45 PM |
| Special Deals on Clutch Masters Clutch & Flywheel Combo! | KronosPerformance | Transmission and Driveline | 15 | 08-25-2012 12:22 PM |
| Clutch Masters Clutch Kits | Island Import Performance | IslandImportPerformance | Transmission and Driveline | 1 | 07-20-2012 12:06 PM |
