Old 12-09-2015, 11:45 AM   #1
afohlin
Drives: 2013 BRZ Limited
Cusco LCA Bolt
I bought a set of Cusco LCA's used and they didn't come with any hardware. I reused the stock bolts but the outer bolt from the LCA to the knuckle is too short. Does anyone know the correct size of the bolt that comes with the Cusco LCA's, or at least the size of the stock bolt so I can get one that's a little longer?
afohlin is offline   Reply With Quote
Old 12-09-2015, 03:13 PM   #2
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I dont think new one comes with any hardware either.
i got mine used as well but havent installed yet since i am going to install them with my coilovers together.
is it too short to nut to tighten it up?
keep me updated!
Old 12-09-2015, 03:46 PM   #3
Jeff@Racer X Fab
Drives: Subaru BRZ, Toyota MR2 Turbo
I do not know the specific size for the Cusco arms, but the OEM bolt is M12x1.25. We use 90mm length for our rear lower control arms, but that is longer than needed for the Cusco arm. I would suggest 80mm in length, and the more common thread pitch at most hardware stores will be M12x1.75.
Hope that helps.
Jeff@Racer X Fab is offline   Reply With Quote
Old 12-11-2015, 02:45 PM   #4
afohlin
Hope that helps.
Thank you!!! I checked Home Depot, Lowes and Fastenal and could only find M12x1.75. I bought both 80MM and 90MM, plus washers and nyloc nuts. I'll install this weekend and will feel a lot better about having the right hardware
Old 12-13-2015, 11:00 PM   #5
afohlin
Update: 80mm bolt worked perfect. Thanks racerx1715!
Old 12-14-2015, 11:23 AM   #6
Jeff@Racer X Fab
Glad the bolt length worked out for you.
Old 12-15-2015, 10:52 AM   #7
zc06_kisstherain
Drives: SWP BRZ
Great! I guess i need to go to Homedepot and buy when i need to install
FT86 Suspension- D2/BC/Cusco/Megan/Tanabe/Tein/KW/Cusco/Ksport/Eibach/Perrin JM Auto Racing Brakes, Suspension, Chassis 271 03-22-2014 12:17 PM
Cusco Front Strut Bar with MC stopper and Cusco Power Brace edsbreezy Brakes, Suspension, Chassis 2 03-06-2014 11:06 PM
Cusco Engine Mounts and Cusco Rear Diff Brace - Stiffen up your BRZ/FR-S!!! RallySport Direct Transmission and Driveline 10 03-12-2013 02:11 PM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 12:19 PM
