Old 12-05-2015, 11:30 AM   #1
mcrane
mcrane's Avatar
How many containers of Motul 300?
I will be changing the manual transmission and diff fluid on my 2013 FR-S. My question is more regarding the amount of total containers to purchase for the Motul 300 fluid.
Motul 300 sells in 1L containers. The FR-S manual calls for 2.2 liters full for the tranny and 1.3 full for the diff.
That being said, if I buy 3 containers I will be .5 liters short altogether. For those that have done this service with Motul 300, did you order 4 containers for the extra .5 or just go with 3? Is the extra .5 total absolutely required?
I only ask because I could not find this specific topic/question anywhere. With Motul 300 being a bit pricey, if I can save on a fourth container, that would be ideal.
Thanks Guys!
mcrane is offline   Reply With Quote
Old 12-05-2015, 12:11 PM   #2
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
I ordered 4 when I had my car. That way next time you change it you'll only need to buy 3.
When it comes to lubricants, always use the directed amount. Never under or over fill, it'll only cause heartache and cost even more money in the long run.
Sent from my Nexus 5X using Tapatalk
Bobblehead is offline   Reply With Quote
Old 12-05-2015, 12:38 PM   #3
mcrane
mcrane's Avatar
Thanks Bobblehead! I really appreciate the feedback. And you're right, do it right the first time.
The Following User Says Thank You to mcrane For This Useful Post:
Bobblehead (12-05-2015)
Old 12-05-2015, 02:17 PM   #4
Bobblehead
Bobblehead's Avatar
No problem!
motul 300 vs motul 300ls about to buy some need help. NickFRS Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 03-24-2016 10:51 PM
Please delete Scuba86 Mechanical Maintenance and Tools 1 11-22-2015 11:50 PM
motul 300v 86Tony Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 06-04-2015 11:04 AM
Motul fluids Filipino Royale Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 88 04-20-2014 09:36 PM
motul Oil whitefrs Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 05-24-2013 10:12 AM
